Improve output for QUnit tests in CI:
  • Uses fewer lines of output
  • Always outputs error at the end even if timeout
  • Support for QUNIT_FAIL_FAST ENV var to quit at first failure
diff --git a/test/run-qunit.js b/test/run-qunit.js
index 42e4ff1..14e9046 100644
--- a/test/run-qunit.js
+++ b/test/run-qunit.js
@@ -91,8 +91,8 @@ async function runAllTests() {
   Runtime.consoleAPICalled(response => {
     const message = response["args"][0].value;
-    // If it's a simple test result, write without newline
-    if (message === "." || message === "F") {
+    // Not finished yet, don't add a newline
+    if (message && message.startsWith && message.startsWith("↪")) {
       process.stdout.write(message);
     } else if (
       message &&
@@ -110,7 +110,13 @@ async function runAllTests() {
   Page.loadEventFired(async () => {
     await Runtime.evaluate({
-      expression: `(${qunit_script})()`
+      expression:
+        `const QUNIT_FAIL_FAST = ` +
+        (process.env.QUNIT_FAIL_FAST === "true").toString() +
+    await Runtime.evaluate({
+      expression: `(${qunit_script})();`
     if (args[0].indexOf("report_requests=1") > -1) {
@@ -161,43 +167,47 @@ runAllTests().catch(e => {
 // The following functions are converted to strings
 // And then sent to chrome to be evalaluated
 function logQUnit() {
-  var moduleErrors = [];
-  var testErrors = [];
-  var assertionErrors = [];
+  let testErrors = [];
+  let assertionErrors = [];
   console.log("\nRunning: " + JSON.stringify(QUnit.urlParams) + "\n");
   QUnit.config.testTimeout = 10000;
-  QUnit.moduleDone(function(context) {
-    if (context.failed) {
-      var msg = "Module Failed: " + context.name + "\n" + testErrors.join("\n");
-      moduleErrors.push(msg);
-      testErrors = [];
   let durations = {};
+  let inTest = false;
   QUnit.testStart(function(context) {
-    console.log("\n" + context.module + "::" + context.name);
+    console.log("↪ " + context.module + "::" + context.name);
+    inTest = true;
   QUnit.testDone(function(context) {
     durations[context.module + "::" + context.name] = context.runtime;
-      var msg = "  Test Failed: " + context.name + assertionErrors.join("    ");
-      /* QUNIT_RESULT */
+      const msg =
+        "  Test Failed: " +
+        context.name +
+        assertionErrors.join("    ") +
+        "\n" +
+        context.source;
       testErrors.push(msg);
-      console.log("F");
-      QUnit.config.queue.length = 0;
+      // Pass QUNIT_FAIL_FAST on the command line to quit after the first failure
+      if (QUNIT_FAIL_FAST) {
+        QUnit.config.queue.length = 0;
+      if (inTest) {
+        console.log(" [✘]");
     } else {
-      console.log(".");
+      if (inTest) {
+        console.log(" [✔]");
+    inTest = false;
   QUnit.log(function(context) {
@@ -221,10 +231,13 @@ function logQUnit() {
   QUnit.done(function(context) {
     console.log("\n");
-    if (moduleErrors.length > 0) {
-      for (var idx = 0; idx < moduleErrors.length; idx++) {
-        console.error(moduleErrors[idx] + "\n");
+    if (testErrors.length) {
+      console.log("Test Errors");
+      console.log("----------------------------------------------");
+      testErrors.forEach(e => {
+        console.error(e);
+      console.log("\n");
     console.log("Slowest tests");
@@ -248,7 +261,11 @@ function logQUnit() {
       console.log("\nUse this filter to run in the same order:");
-      console.log("QUNIT_SEED=" + QUnit.config.seed + " rake qunit:test\n");
+      console.log(
+        "QUNIT_FAIL_FAST=true QUNIT_SEED=" +
       console.log("If you have a web environment running, you can visit:");
       console.log(
         "http://localhost:3000/qunit?hidepassed&seed=" +
GitHub sha: 0c8365a1
