Improve Vanilla import script. (#11701)
- import groups and group users
- import uploads/attachments
- improved code tag parsing
- improved text formatting
- mark topics as solved
diff --git a/script/import_scripts/vanilla_body_parser.rb b/script/import_scripts/vanilla_body_parser.rb
index af9d2c4..ba4608e 100644
--- a/script/import_scripts/vanilla_body_parser.rb
+++ b/script/import_scripts/vanilla_body_parser.rb
@@ -24,6 +24,17 @@ class VanillaBodyParser
private
def clean_up(text)
+ # <pre class="CodeBlock">...</pre>
+ text = text.gsub(/\<pre class="CodeBlock"\>(.*?)\<\/pre\>/im) { "\n```\n#{$1}\n```\n" }
+ # <pre>...</pre>
+ text = text.gsub(/\<pre\>(.*?)\<\/pre\>/im) { "\n```\n#{$1}\n```\n" }
+ # <code></code>
+ text = text.gsub("\<code\>\</code\>", "").gsub(/\<code\>(.*?)\<\/code\>/im) { "#{$1}" }
+ # <div class="Quote">...</div>
+ text = text.gsub(/\<div class="Quote"\>(.*?)\<\/div\>/im) { "\n[quote]\n#{$1}\n[/quote]\n" }
+ # [code], [quote]
+ text = text.gsub(/\[\/?code\]/i, "\n```\n").gsub(/\[quote.*?\]/i, "\n" + '\0' + "\n").gsub(/\[\/quote\]/i, "\n" + '\0' + "\n")
text.gsub(/<\/?font[^>]*>/, '').gsub(/<\/?span[^>]*>/, '').gsub(/<\/?div[^>]*>/, '').gsub(/^ +/, '').gsub(/ +/, ' ')
@@ -58,7 +69,7 @@ class VanillaBodyParser
return parse_quote(insert) if quoting
embed = embed_type.in? ['image', 'link', 'file']
- parse_embed(insert) if embed
+ parse_embed(insert, embed_type) if embed
def parse_mention(mention)
@@ -87,9 +98,6 @@ class VanillaBodyParser
# In the Quill format used by Vanilla Forums, a line is rendered as `code`
# when it's followed by a fragment with attributes: {'code-block': true}.
- # So we open our ``` block when the next fragment has a 'code-block'
- # attribute and the previous one didn't and we close the ``` block when
- # the second next fragment does not contain the 'code-block' attribute
def parse_code(text, fragment, index)
next_fragment = next_fragment(index)
@@ -98,18 +106,27 @@ class VanillaBodyParser
previous_fragment = previous_fragment(index)
previous_code = previous_fragment.dig(:attributes, :'code-block')
- # if next is code and previous is not, prepend ```
- text = "\n```#{text}" unless previous_code
+ if previous_code
+ text = text.gsub(/\\n(.*?)\\n/) { "\n```\n#{$1}\n```\n" }
+ else
+ last_pos = text.rindex(/\n/)
+ if last_pos
+ array = [text[0..last_pos].strip, text[last_pos + 1 .. text.length].strip]
+ text = array.join("\n```\n")
+ else
+ text = "\n```\n#{text}"
+ end
+ end
current_code = fragment.dig(:attributes, :'code-block')
if current_code
second_next_fragment = second_next_fragment(index)
second_next_code = second_next_fragment.dig(:attributes, :'code-block')
# if current is code and 2 after is not, prepend ```
- text = "\n```#{text}" unless second_next_code
+ text = "\n```\n#{text}" unless second_next_code
text
@@ -174,7 +191,7 @@ class VanillaBodyParser
"[quote#{quote_info}]\n#{embed[:body]}\n[/quote]\n\n"""
- def parse_embed(insert)
+ def parse_embed(insert, embed_type)
embed = insert.dig(:'embed-external', :data)
url = embed[:url]
@@ -193,7 +210,13 @@ class VanillaBodyParser
- "\n[#{embed[:name]}](#{url})\n"
+ if embed_type == "link"
+ "\n[#{embed[:name]}](#{url})\n"
+ elsif embed_type == "image"
+ "\n<img src=\"#{url}\" alt=\"#{embed[:name]}\">\n"
+ else
+ "\n<a href=\"#{url}\">#{embed[:name]}</a>\n"
+ end
def normalize(full_text)
diff --git a/script/import_scripts/vanilla_mysql.rb b/script/import_scripts/vanilla_mysql.rb
index f2b4e6e..1a290ec 100644
--- a/script/import_scripts/vanilla_mysql.rb
+++ b/script/import_scripts/vanilla_mysql.rb
@@ -45,16 +45,37 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
SiteSetting.max_tags_per_topic = 10
+ import_groups
import_users
import_avatars
+ import_group_users
import_categories
import_topics
import_posts
import_messages
update_tl0
+ mark_topics_as_solved
create_permalinks
+ import_attachments
+ end
+ def import_groups
+ puts "", "importing groups..."
+ groups = mysql_query <<-SQL
+ SELECT RoleID, Name
+ FROM #{TABLE_PREFIX}Role
+ ORDER BY RoleID
+ SQL
+ create_groups(groups) do |group|
+ id: group["RoleID"],
+ name: @htmlentities.decode(group["Name"]).strip
+ end
def import_users
@@ -147,7 +168,7 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
photo_real_filename = nil
parts = photo.squeeze("/").split("/")
- if parts[0] == "cf:"
+ if parts[0] =~ /^[a-z0-9]{2}:/
photo_path = "#{ATTACHMENTS_BASE_DIR}/#{parts[2..-2].join('/')}".squeeze("/")
elsif parts[0] == "~cf"
photo_path = "#{ATTACHMENTS_BASE_DIR}/#{parts[1..-2].join('/')}".squeeze("/")
@@ -200,6 +221,24 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
nil
+ def import_group_users
+ puts "", "importing group users..."
+ group_users = mysql_query("
+ SELECT RoleID, UserID
+ FROM #{TABLE_PREFIX}UserRole
+ ").to_a
+ group_users.each do |row|
+ user_id = user_id_from_imported_user_id(row["UserID"])
+ group_id = group_id_from_imported_group_id(row["RoleID"])
+ if user_id && group_id
+ GroupUser.find_or_create_by(user_id: user_id, group_id: group_id)
+ end
+ end
+ end
def import_categories
puts "", "importing categories..."
@@ -272,7 +311,7 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
batches(BATCH_SIZE) do |offset|
comments = mysql_query(
"SELECT CommentID, DiscussionID, Body, Format,
- DateInserted, InsertUserID
+ DateInserted, InsertUserID, QnA
FROM #{TABLE_PREFIX}Comment
WHERE CommentID > #{@last_post_id}
ORDER BY CommentID ASC
@@ -286,13 +325,20 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
next unless t = topic_lookup_from_imported_post_id("discussion#" + comment['DiscussionID'].to_s)
next if comment['Body'].blank?
user_id = user_id_from_imported_user_id(comment['InsertUserID']) || Discourse::SYSTEM_USER_ID
+ mapped = {
id: "comment#" + comment['CommentID'].to_s,
user_id: user_id,
topic_id: t[:topic_id],
raw: VanillaBodyParser.new(comment, user_id).parse,
created_at: Time.zone.at(comment['DateInserted'])
+ if comment['QnA'] == "Accepted"
+ mapped[:custom_fields] = { is_accepted_answer: "true" }
+ end
+ mapped
@@ -395,6 +441,104 @@ class ImportScripts::VanillaSQL < ImportScripts::Base
+ def import_attachments
+ if ATTACHMENTS_BASE_DIR && File.exists?(ATTACHMENTS_BASE_DIR)
+ puts "", "importing attachments"
+ start = Time.now
+ count = 0
+ # https://us.v-cdn.net/1234567/uploads/editor/xyz/image.jpg
+ cdn_regex = /https:\/\/us.v-cdn.net\/1234567\/uploads\/(\S+\/(\w|-)+.\w+)/i
+ # [attachment=10109:Screen Shot 2012-04-01 at 3.47.35 AM.png]
+ attachment_regex = /\[attachment=(\d+):(.*?)\]/i
+ Post.where("raw LIKE '%/us.v-cdn.net/%' OR raw LIKE '%[attachment%'").find_each do |post|
+ count += 1
+ print "\r%7d - %6d/sec" % [count, count.to_f / (Time.now - start)]
+ new_raw = post.raw.dup
+ new_raw.gsub!(attachment_regex) do |s|
+ matches = attachment_regex.match(s)
+ attachment_id = matches[1]
+ file_name = matches[2]
+ next unless attachment_id
+ r = mysql_query("SELECT Path, Name FROM #{TABLE_PREFIX}Media WHERE MediaID = #{attachment_id};").first
+ next if r.nil?
+ path = r["Path"]
+ name = r["Name"]
+ next unless path.present?
GitHub sha: bd7cbcd8
