Investigate possible retained memory in presence (PR #14770)
GitHub
I noticed that no calling unsubscribe on a channel was preventing state to be released:
I commented out unexisting channel for now, as we actually can’t call unsubscribe on them.
just a note but I think it might actually be a good idea to use different channel names in each test so it’s easier to track
Capture d’écran 2021-10-29 à 17 10 24
It seems like we can’t GC this as it’s holding reference to presence service which is also not released
@davidtaylorhq This is only a draft and I doubt it will be more than this, whatever I tried to do, I failed to removed the remaining PresenceService / ComposerPresenceManager objects, I somehow wonder if there’s not some kind of circular reference here, with objects using both services and composer presence manager having a reference to presence service.
This not actually fixing the issue, but if we are not going to run this in tests, maybe just better not adding the listener at all ?
