Merge pull request from GHSA-7cmh-wm9h-j63f
diff --git a/app/controllers/users/omniauth_callbacks_controller.rb b/app/controllers/users/omniauth_callbacks_controller.rb
index cac09b3..9cfaa46 100644
--- a/app/controllers/users/omniauth_callbacks_controller.rb
+++ b/app/controllers/users/omniauth_callbacks_controller.rb
@@ -134,7 +134,10 @@ class Users::OmniauthCallbacksController < ApplicationController
         user.email_tokens.create!(email: user.email)
-      user.activate
+      if !user.active || !user.email_confirmed?
+        user.password = SecureRandom.hex
+        user.activate
+      end
       user.update!(registration_ip_address: request.remote_ip) if user.registration_ip_address.blank?
diff --git a/spec/requests/omniauth_callbacks_controller_spec.rb b/spec/requests/omniauth_callbacks_controller_spec.rb
index 25d9238..f8e2ac8 100644
--- a/spec/requests/omniauth_callbacks_controller_spec.rb
+++ b/spec/requests/omniauth_callbacks_controller_spec.rb
@@ -286,7 +286,7 @@ RSpec.describe Users::OmniauthCallbacksController do
         expect(user.email_confirmed?).to eq(true)
-      it "should activate/unstage staged user" do
+      it "should unstage staged user" do
         user.update!(staged: true, registration_ip_address: nil)
         user.reload
@@ -306,6 +306,22 @@ RSpec.describe Users::OmniauthCallbacksController do
         expect(user.registration_ip_address).to be_present
+      it "should activate user with matching email" do
+        user.update!(password: "securepassword", active: false)
+        user.reload
+        expect(user.active).to eq(false)
+        expect(user.confirm_password?("securepassword")).to eq(true)
+        get "/auth/google_oauth2/callback.json"
+        user.reload
+        expect(user.active).to eq(true)
+        # Delete the password, it may have been set by someone else
+        expect(user.confirm_password?("securepassword")).to eq(false)
+      end
       context 'when user has second factor enabled' do
         before do
           user.create_totp(enabled: true)
GitHub sha: 8e5a8d1d
Revert "Merge pull request from GHSA-7cmh-wm9h-j63f"
