More JS files
More JS files
diff --git a/app/assets/javascripts/admin/routes/admin-api-keys-new.js b/app/assets/javascripts/admin/routes/admin-api-keys-new.js
new file mode 100644
index 0000000..3969615
--- /dev/null
+++ b/app/assets/javascripts/admin/routes/admin-api-keys-new.js
@@ -0,0 +1,7 @@
+import Route from "@ember/routing/route";
+export default Route.extend({
+  model() {
+    return this.store.createRecord("api-key");
diff --git a/app/assets/javascripts/onpopstate-handler.js b/app/assets/javascripts/onpopstate-handler.js
index 0000000..f722a97
--- /dev/null
+++ b/app/assets/javascripts/onpopstate-handler.js
@@ -0,0 +1,7 @@
+// discourse-skip-module
+window.onpopstate = function(event) {
+  // check if Discourse object exists if not take care of back navigation
+  if (event.state && !window.hasOwnProperty("Discourse")) {
+    window.location = document.location;
diff --git a/app/assets/javascripts/onpopstate-handler.js.es6 b/app/assets/javascripts/onpopstate-handler.js.es6
deleted file mode 100644
index f722a97..0000000
--- a/app/assets/javascripts/onpopstate-handler.js.es6
+++ /dev/null
@@ -1,7 +0,0 @@
-// discourse-skip-module
-window.onpopstate = function(event) {
-  // check if Discourse object exists if not take care of back navigation
-  if (event.state && !window.hasOwnProperty("Discourse")) {
-    window.location = document.location;
diff --git a/app/assets/javascripts/wizard-start.js b/app/assets/javascripts/wizard-start.js
index 0000000..79c022f
--- /dev/null
+++ b/app/assets/javascripts/wizard-start.js
@@ -0,0 +1,5 @@
+(function() {
+  var wizard = require("wizard/wizard").default.create();
+  wizard.start();
diff --git a/app/assets/javascripts/wizard-start.js.es6 b/app/assets/javascripts/wizard-start.js.es6
index 79c022f..0000000
--- a/app/assets/javascripts/wizard-start.js.es6
+++ /dev/null
@@ -1,5 +0,0 @@
-(function() {
-  var wizard = require("wizard/wizard").default.create();
-  wizard.start();
GitHub sha: 4876884f
