No need to clear excon stubs
diff --git a/spec/lib/posts_bouncer_spec.rb b/spec/lib/posts_bouncer_spec.rb
index 1a85568..3d213ba 100644
--- a/spec/lib/posts_bouncer_spec.rb
+++ b/spec/lib/posts_bouncer_spec.rb
@@ -89,10 +89,6 @@ describe DiscourseAkismet::PostsBouncer do
   describe '#check_post' do
     let(:client) { Akismet::Client.build_client }
-    after do
-      clear_stubs
-    end
     it 'Creates a new ReviewableAkismetPost when spam is confirmed by Akismet' do
       subject.move_to_state(post, 'new')
@@ -154,10 +150,6 @@ describe DiscourseAkismet::PostsBouncer do
       Excon.defaults[:mock] = true
       Excon.stub({ host: /rest.akismet.com/ }, response)
-    def clear_stubs
-      Excon.stubs.clear
-    end
   describe "#to_check" do
GitHub sha: 61ec7424
