Optimise responses to CORS preflight requests
Respond prior to authentication and subscription setup. Our response doesn’t depend on these, so there’s no point executing them, especially since they may be heavy routines which perform I/O.
diff --git a/lib/message_bus/rack/middleware.rb b/lib/message_bus/rack/middleware.rb
index 809bfc1..216a8bb 100644
--- a/lib/message_bus/rack/middleware.rb
+++ b/lib/message_bus/rack/middleware.rb
@@ -81,6 +81,22 @@ class MessageBus::Rack::Middleware
     client_id = env['PATH_INFO'][@base_route_length..-1].split("/")[0]
     return [404, {}, ["not found"]] unless client_id
+    headers = {}
+    headers["Cache-Control"] = "must-revalidate, private, max-age=0"
+    headers["Content-Type"] = "application/json; charset=utf-8"
+    headers["Pragma"] = "no-cache"
+    headers["Expires"] = "0"
+    if @bus.extra_response_headers_lookup
+      @bus.extra_response_headers_lookup.call(env).each do |k, v|
+        headers[k] = v
+      end
+    end
+    if env["REQUEST_METHOD"] == "OPTIONS"
+      return [200, headers, ["OK"]]
+    end
     user_id = @bus.user_id_lookup.call(env) if @bus.user_id_lookup
     group_ids = @bus.group_ids_lookup.call(env) if @bus.group_ids_lookup
     site_id = @bus.site_id_lookup.call(env) if @bus.site_id_lookup
@@ -111,22 +127,6 @@ class MessageBus::Rack::Middleware
-    headers = {}
-    headers["Cache-Control"] = "must-revalidate, private, max-age=0"
-    headers["Content-Type"] = "application/json; charset=utf-8"
-    headers["Pragma"] = "no-cache"
-    headers["Expires"] = "0"
-    if @bus.extra_response_headers_lookup
-      @bus.extra_response_headers_lookup.call(env).each do |k, v|
-        headers[k] = v
-      end
-    end
-    if env["REQUEST_METHOD"] == "OPTIONS"
-      return [200, headers, ["OK"]]
-    end
     long_polling = @bus.long_polling_enabled? &&
                    env['QUERY_STRING'] !~ /dlp=t/ &&
                    @connection_manager.client_count < @bus.max_active_clients
GitHub sha: 570e542b
This commit appears in #244 which was approved by SamSaffron. It was merged by SamSaffron.
