PERF: Add partial index for non-pm search.
diff --git a/app/services/search_indexer.rb b/app/services/search_indexer.rb
index 8eb16ca..01a24cc 100644
--- a/app/services/search_indexer.rb
+++ b/app/services/search_indexer.rb
@@ -85,6 +85,7 @@ class SearchIndexer
"search_data" => tsvector,
+ yield params if block_given?
table_name.camelize.constantize.upsert(params)
rescue => e
if Rails.env.test?
@@ -111,7 +112,7 @@ class SearchIndexer
- def self.update_posts_index(post_id, topic_title, category_name, topic_tags, cooked)
+ def self.update_posts_index(post_id:, topic_title:, category_name:, topic_tags:, cooked:, private_message:)
update_index(
table: 'post',
@@ -119,7 +120,9 @@ class SearchIndexer
b_weight: category_name,
c_weight: topic_tags,
d_weight: scrub_html_for_search(cooked)
+ ) do |params|
+ params["private_message"] = private_message
+ end
def self.update_users_index(user_id, username, name)
@@ -204,7 +207,15 @@ class SearchIndexer
if topic
- SearchIndexer.update_posts_index(obj.id, topic.title, category_name, tag_names, obj.cooked)
+ SearchIndexer.update_posts_index(
+ post_id: obj.id,
+ topic_title: topic.title,
+ category_name: category_name,
+ topic_tags: tag_names,
+ cooked: obj.cooked,
+ private_message: topic.private_message?
SearchIndexer.update_topics_index(topic.id, topic.title, obj.cooked) if obj.is_first_post?
@@ -216,7 +227,15 @@ class SearchIndexer
if Topic === obj && (obj.saved_change_to_title? || force)
if obj.posts
if post = obj.posts.find_by(post_number: 1)
- SearchIndexer.update_posts_index(post.id, obj.title, category_name, tag_names, post.cooked)
+ post_id: post.id,
+ topic_title: obj.title,
+ cooked: post.cooked,
+ private_message: obj.private_message?
SearchIndexer.update_topics_index(obj.id, obj.title, post.cooked)
diff --git a/db/migrate/20200813051337_add_private_message_to_post_search_data.rb b/db/migrate/20200813051337_add_private_message_to_post_search_data.rb
new file mode 100644
index 0000000..1d19c5e
--- /dev/null
+++ b/db/migrate/20200813051337_add_private_message_to_post_search_data.rb
@@ -0,0 +1,51 @@
+class AddPrivateMessageToPostSearchData < ActiveRecord::Migration[6.0]
+ def up
+ add_column :post_search_data, :private_message, :boolean
+ # Delete post_search_data of orphaned posts
+ execute <<~SQL
+ DELETE FROM post_search_data
+ WHERE post_id IN (
+ SELECT posts.id
+ FROM posts
+ LEFT JOIN topics ON topics.id = posts.topic_id
+ WHERE topics.id IS NULL
+ SQL
+ # Delete orphaned post_search_data
+ execute <<~SQL
+ SELECT post_search_data.post_id
+ FROM post_search_data
+ LEFT JOIN posts ON posts.id = post_search_data.post_id
+ WHERE posts.id IS NULL
+ SQL
+ execute <<~SQL
+ UPDATE post_search_data
+ SET private_message = true
+ FROM posts
+ INNER JOIN topics ON topics.id = posts.topic_id AND topics.archetype = 'private_message'
+ WHERE posts.id = post_search_data.post_id
+ SQL
+ execute <<~SQL
+ SET private_message = false
+ FROM posts
+ INNER JOIN topics ON topics.id = posts.topic_id AND topics.archetype <> 'private_message'
+ SQL
+ change_column_null(:post_search_data, :private_message, false)
+ end
+ def down
+ raise ActiveRecord::IrreversibleMigration
+ end
+end
diff --git a/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb b/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb
index 0000000..4189f36
--- /dev/null
+++ b/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb
@@ -0,0 +1,17 @@
+class CreatePartialIndexOnPostSearchData < ActiveRecord::Migration[6.0]
+ disable_ddl_transaction!
+ def up
+ execute <<~SQL
+ CREATE INDEX CONCURRENTLY idx_regular_post_search_data ON post_search_data USING GIN(search_data) WHERE NOT private_message
+ SQL
+ end
+ def down
+ execute <<~SQL
+ DROP INDEX IF EXISTS idx_regular_post_search_data;
+ SQL
+ end
+end
diff --git a/lib/search.rb b/lib/search.rb
index 9cf0c85..316ff53 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -818,22 +818,37 @@ class Search
.joins("LEFT JOIN categories ON categories.id = topics.category_id")
is_topic_search = @search_context.present? && @search_context.is_a?(Topic)
posts = posts.where("topics.visible") unless is_topic_search
if type_filter === "private_messages" || (is_topic_search && @search_context.private_message?)
- posts = posts.where("topics.archetype = ?", Archetype.private_message)
+ posts = posts
+ .where(
+ "topics.archetype = ? AND post_search_data.private_message",
+ Archetype.private_message
- unless @guardian.is_admin?
- posts = posts.private_posts_for_user(@guardian.user)
- end
+ unless @guardian.is_admin?
+ posts = posts.private_posts_for_user(@guardian.user)
+ end
elsif type_filter === "all_topics"
- private_posts = posts.where("topics.archetype = ?", Archetype.private_message)
- private_posts = private_posts.private_posts_for_user(@guardian.user)
+ private_posts = posts
+ .where(
+ .private_posts_for_user(@guardian.user)
- posts = posts.where("topics.archetype <> ?", Archetype.private_message).or(private_posts)
+ posts = posts
+ .where(
+ "topics.archetype <> ? AND NOT post_search_data.private_message",
+ .or(private_posts)
else
+ posts = posts.where(
if @term.present?
@@ -1162,6 +1177,8 @@ class Search
query.includes(topic: topic_eager_loads)
+ private
# Limited for performance reasons since `TS_HEADLINE` is slow when the text
# document is too long.
MAX_LENGTH_FOR_HEADLINE = 2500
diff --git a/spec/services/search_indexer_spec.rb b/spec/services/search_indexer_spec.rb
index c359c32..aeee36e 100644
--- a/spec/services/search_indexer_spec.rb
+++ b/spec/services/search_indexer_spec.rb
@@ -21,7 +21,14 @@ describe SearchIndexer do
SiteSetting.default_locale = 'zh_CN'
data = "你好世界"
- SearchIndexer.update_posts_index(post_id, "", "", "", data)
+ post_id: post_id,
+ topic_title: "",
+ category_name: "",
+ topic_tags: "",
+ cooked: data,
+ private_message: false
post_search_data = PostSearchData.find_by(post_id: post_id)
@@ -95,11 +102,27 @@ describe SearchIndexer do
it 'correctly indexes a post according to version' do
# Preparing so that they can be indexed to right version
- SearchIndexer.update_posts_index(post_id, "dummy", "", nil, nil)
+ post_id: post_id,
+ topic_title: "dummy",
+ topic_tags: nil,
+ cooked: nil,
PostSearchData.find_by(post_id: post_id).update!(version: -1)
GitHub sha: 92b7fe4c
