PERF: Async notify users after inviting group (PR #12697)
Inviting a group generates a notification for each member. If this happens synchronously it may take a while, leading to a poor user experience.
GitHub
if post is nil this will blow up :boom:
I like to exit early like this
      return unless user = User.find_by(id: args[:user_id])
      return unless group = Group.find_by(id: args[:group_id])
      return unless post = Post.find_by(id: args[:post_id])
      return unless topic = post.topic
Do you need to create a new PostAlerter instance for every group member?
This bit could also be generated once outside the loop.
Yay :raised_hands: Async + moar perf :tada:
