PERF: Avoid looking up the same category twice in `TopicCreator`.
PERF: Avoid looking up the same category twice in TopicCreator.
diff --git a/lib/topic_creator.rb b/lib/topic_creator.rb
index f65f302..71655b0 100644
--- a/lib/topic_creator.rb
+++ b/lib/topic_creator.rb
@@ -119,7 +119,6 @@ class TopicCreator
     topic_params[:subtype] = TopicSubtype.moderator_warning if @opts[:is_warning]
     category = find_category
     @guardian.ensure_can_create!(Topic, category) unless (@opts[:skip_validations] || @opts[:archetype] == Archetype.private_message)
     topic_params[:category_id] = category.id if category.present?
@@ -137,20 +136,22 @@ class TopicCreator
   def find_category
-    # PM can't have a category
-    @opts.delete(:category) if @opts[:archetype].present? && @opts[:archetype] == Archetype.private_message
+    @category ||= begin
+      # PM can't have a category
+      @opts.delete(:category) if @opts[:archetype].present? && @opts[:archetype] == Archetype.private_message
-    if @opts[:shared_draft]
-      return Category.find(SiteSetting.shared_drafts_category)
-    end
+      if @opts[:shared_draft]
+        return Category.find(SiteSetting.shared_drafts_category)
+      end
-    # Temporary fix to allow older clients to create topics.
-    # When all clients are updated the category variable should
-    # be set directly to the contents of the if statement.
-    if (@opts[:category].is_a? Integer) || (@opts[:category] =~ /^\d+$/)
-      Category.find_by(id: @opts[:category])
-    else
-      Category.find_by(name_lower: @opts[:category].try(:downcase))
+      # Temporary fix to allow older clients to create topics.
+      # When all clients are updated the category variable should
+      # be set directly to the contents of the if statement.
+      if (@opts[:category].is_a? Integer) || (@opts[:category] =~ /^\d+$/)
+        Category.find_by(id: @opts[:category])
+      else
+        Category.find_by(name_lower: @opts[:category].try(:downcase))
+      end
GitHub sha: 742decc2
Oh awesome! Thanks for doing this. I found the same behavior early but never got around to fixing it :+1:.
