PERF: backoff background requests when overloaded (PR #10888)
It is probably better for you to specify what to run prettier on:
let g:ale_fixers = {'scss': ['prettier'], 'javascript': ['eslint', 'prettier'] }
That’s what I do.
This variable is never initialized. We should add retryRateLimited: null at the beginning of the class. I would go further and suggest this._retryRateLimited because it’s never observed and is private.
We should also initialize this variable in the class, and probably use an underscore to mark it private.
I think I run the prettier vim plugin I wonder if I should just remove it, that said I don’t think we will be prettier-ing and ruby files any time soon.
Will try to get the other changes into my existing PR
