PERF: Backup with lots of uploads stored on S3 was slow
Creating the backup needs a lot more disk space after this change, but it is a lot faster.
diff --git a/lib/backup_restore/backuper.rb b/lib/backup_restore/backuper.rb
index dd4f81c..80e45da 100644
--- a/lib/backup_restore/backuper.rb
+++ b/lib/backup_restore/backuper.rb
@@ -291,20 +291,17 @@ module BackupRestore
           log "Failed to download file with upload ID #{upload.id} from S3", ex
-        if File.exists?(filename)
-          Discourse::Utils.execute_command(
-            'tar', '--append', '--file', tar_filename, upload_directory,
-            failure_message: "Failed to add #{upload.original_filename} to archive.", success_status_codes: [0, 1],
-            chdir: @tmp_directory
-          File.delete(filename)
-        end
         count += 1
         log "#{count} files have already been downloaded. Still downloading..." if count % 500 == 0
+      log "Appending uploads to archive..."
+      Discourse::Utils.execute_command(
+        'tar', '--append', '--file', tar_filename, upload_directory,
+        failure_message: "Failed to append uploads to archive.", success_status_codes: [0, 1],
+        chdir: @tmp_directory
       log "No uploads found on S3. Skipping archiving of uploads stored on S3..." if count == 0
GitHub sha: ad670977
