PERF: Cache PrettyText instance for rendering composer preview (PR #9987)
Previously we were building pretty-text from scratch on every keypress. In my browser, this cuts cooking a simple post from 2.5ms to 0.5ms
Before: Screenshot 2020-06-05 at 11 20 05
After: Screenshot 2020-06-05 at 11 59 01
GitHub
You could probably make it even simpler by setting this.cookFunction in an init() method when the component is created and then you could call it without checking if it exists every time. I doubt it would change performance much but it would be simpler code.
The problem is that loading pretty-text is asynchronous. So we can’t set it synchronously during init.
I guess we could trigger the loadScript during init, but then we would still have to check whether loading is done before cooking anything.
Ah yes, of course!
