PERF: drop idx_regular_post_search_data during migration
Rebuilding this index while amending the boolean is very expensive.
Avoid this work
diff --git a/db/post_migrate/20200818084329_update_private_message_on_post_search_data.rb b/db/post_migrate/20200818084329_update_private_message_on_post_search_data.rb
index 51d23f0..6c45b3d 100644
--- a/db/post_migrate/20200818084329_update_private_message_on_post_search_data.rb
+++ b/db/post_migrate/20200818084329_update_private_message_on_post_search_data.rb
@@ -18,7 +18,7 @@ class UpdatePrivateMessageOnPostSearchData < ActiveRecord::Migration[6.0]
         JOIN topics t ON t.id = p.topic_id
         WHERE pd.private_message IS NULL OR
           pd.private_message <> CASE WHEN t.archetype = 'private_message' THEN TRUE ELSE FALSE END
-        LIMIT 200000
+        LIMIT 3000000
       ) X
       WHERE X.post_id = post_search_data.post_id
     SQL
@@ -34,6 +34,13 @@ class UpdatePrivateMessageOnPostSearchData < ActiveRecord::Migration[6.0]
   def up
+    # must drop index cause we do not want an enormous amount of work done
+    # as we are changing data
+    execute <<~SQL
+     DROP INDEX IF EXISTS idx_regular_post_search_data
+    SQL
     # Delete post_search_data of orphaned posts
     execute <<~SQL
     DELETE FROM post_search_data
@@ -62,6 +69,11 @@ class UpdatePrivateMessageOnPostSearchData < ActiveRecord::Migration[6.0]
       update_private_message_flag
       change_column_null(:post_search_data, :private_message, false)
+    execute <<~SQL
+      CREATE INDEX CONCURRENTLY idx_regular_post_search_data
+       ON post_search_data USING GIN(search_data) WHERE NOT private_message
+    SQL
   def down
GitHub sha: 628319aa
