PERF: Improve quality of `PostSearchData#raw_data`. (#7275)
PERF: Improve quality of PostSearchData#raw_data. (#7275)
This commit fixes the follow quality issue with PostSearchData#raw_data:
  1. URLs are being tokenized and links with similar href and characters are being duplicated in the raw data.
Post#cooked:
<p><a href=\"https://meta.discourse.org/some.png\" class=\"onebox\" target=\"_blank\" rel=\"nofollow noopener\">https://meta.discourse.org/some.png</a></p>
PostSearchData#raw_data Before:
This is a test topic 0 Uncategorized https://meta.discourse.org/some.png discourse org/some png https://meta.discourse.org/some.png discourse org/some png
PostSearchData#raw_data After:
This is a test topic 0 Uncategorized https://meta.discourse.org/some.png meta discourse org
  1. Ligthbox being included in search pollutes the PostSearchData#raw_data unncessarily.
From 28 March 2018 to 28 March 2019, searches for the term image on meta.discourse.org had a click through rate of 2.1%. Non-lightboxed images are not included in indexing for search yet we were indexing content within a lightbox. Also, search for terms like image was affected we were using Pasted image as the filename for uploads that were pasted.
Post#cooked
<p>Let me see how I can fix this image<br>\n<div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"https://meta.discourse.org/some.png\" title=\"some.png\" rel=\"nofollow noopener\"><img src=\"https://meta.discourse.org/some.png\" width=\"275\" height=\"299\"><div class=\"meta\">\n<svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">some.png</span><span class=\"informations\">1750×2000</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg>\n</div></a></div></p>
This is a test topic 0 Uncategorized Let me see how I can fix this image some.png png https://meta.discourse.org/some.png discourse org/some png some.png png 1750×2000
In terms of indexing performance, we now have to parse the given HTML through nokogiri twice. However performance is not a huge worry here since a string length of 194170 takes only 30ms to scrub plus the indexing takes place in a background job.
diff --git a/app/jobs/regular/process_post.rb b/app/jobs/regular/process_post.rb
index d6b3afa..cd99dec 100644
--- a/app/jobs/regular/process_post.rb
+++ b/app/jobs/regular/process_post.rb
@@ -32,7 +32,7 @@ module Jobs
           # TODO suicide if needed, let's gather a few here first
           Rails.logger.warn("Cooked post processor in FATAL state, bypassing. You need to urgently restart sidekiq\norig: #{orig_cooked}\nrecooked: #{recooked}\ncooked: #{cooked}\npost id: #{post.id}")
         else
-          post.update_column(:cooked, cp.html)
+          post.update!(cooked: cp.html)
           extract_links(post)
           post.publish_change_to_clients! :revised
diff --git a/app/models/post.rb b/app/models/post.rb
index c738204..b835fea 100644
--- a/app/models/post.rb
+++ b/app/models/post.rb
@@ -603,7 +603,11 @@ class Post < ActiveRecord::Base
     new_cooked = cook(raw, topic_id: topic_id, invalidate_oneboxes: invalidate_oneboxes)
     old_cooked = cooked
-    update_columns(cooked: new_cooked, baked_at: Time.new, baked_version: BAKED_VERSION)
+    self.update!(
+      cooked: new_cooked,
+      baked_at: Time.zone.now,
+      baked_version: BAKED_VERSION
     if invalidate_broken_images
       custom_fields.delete(BROKEN_IMAGES)
diff --git a/app/services/search_indexer.rb b/app/services/search_indexer.rb
index c7b07c5..f731e52 100644
--- a/app/services/search_indexer.rb
+++ b/app/services/search_indexer.rb
@@ -19,11 +19,16 @@ class SearchIndexer
     # insert some extra words for I.am.a.word so "word" is tokenized
     # I.am.a.word becomes I.am.a.word am a word
     raw.gsub(/[^[:space:]]*[\.]+[^[:space:]]*/) do |with_dot|
-      split = with_dot.split(".")
-      if split.length > 1
-        with_dot + ((+" ") << split[1..-1].join(" "))
+      if with_dot.match?(PlainTextToMarkdown::URL_REGEX)
+        "#{with_dot} #{URI.parse(with_dot).hostname.gsub('.', ' ')}"
       else
-        with_dot
+        split = with_dot.split(".")
+        if split.length > 1
+          with_dot + ((+" ") << split[1..-1].join(" "))
+        else
+          with_dot
+        end
@@ -183,19 +188,34 @@ class SearchIndexer
     def self.scrub(html, strip_diacritics: false)
       return +"" if html.blank?
+      document = Nokogiri::HTML("<div>#{html}</div>", nil, Encoding::UTF_8.to_s)
+      document.css(
+        "div.#{CookedPostProcessor::LIGHTBOX_WRAPPER_CSS_CLASS}"
+      ).remove
+      document.css("a[href]").each do |node|
+        node.remove_attribute("href") if node["href"] == node.text
+      end
       me = new(strip_diacritics: strip_diacritics)
-      Nokogiri::HTML::SAX::Parser.new(me).parse("<div>#{html}</div>")
+      Nokogiri::HTML::SAX::Parser.new(me).parse(document.to_html)
       me.scrubbed.squish
     ATTRIBUTES ||= %w{alt title href data-youtube-title}
-    def start_element(_, attributes = [])
+    def start_element(_name, attributes = [])
       attributes = Hash[*attributes.flatten]
-      ATTRIBUTES.each do |name|
-        if attributes[name].present?
-          characters(attributes[name]) unless name == "href" && UrlHelper.is_local(attributes[name])
+      ATTRIBUTES.each do |attribute_name|
+        if attributes[attribute_name].present? &&
+            attribute_name == "href" &&
+            UrlHelper.is_local(attributes[attribute_name])
+          characters(attributes[attribute_name])
diff --git a/lib/cooked_post_processor.rb b/lib/cooked_post_processor.rb
index 364f1fc..68a3055 100644
--- a/lib/cooked_post_processor.rb
+++ b/lib/cooked_post_processor.rb
@@ -8,6 +8,7 @@ require_dependency 'quote_comparer'
 class CookedPostProcessor
   INLINE_ONEBOX_LOADING_CSS_CLASS = "inline-onebox-loading"
   INLINE_ONEBOX_CSS_CLASS = "inline-onebox"
+  LIGHTBOX_WRAPPER_CSS_CLASS = "lightbox-wrapper"
   LOADING_SIZE = 10
   LOADING_COLORS = 32
@@ -367,7 +368,7 @@ class CookedPostProcessor
   def add_lightbox!(img, original_width, original_height, upload, cropped: false)
     # first, create a div to hold our lightbox
-    lightbox = create_node("div", "lightbox-wrapper")
+    lightbox = create_node("div", LIGHTBOX_WRAPPER_CSS_CLASS)
     img.add_next_sibling(lightbox)
     lightbox.add_child(img)
diff --git a/spec/services/search_indexer_spec.rb b/spec/services/search_indexer_spec.rb
index d748ec6..3034586 100644
--- a/spec/services/search_indexer_spec.rb
+++ b/spec/services/search_indexer_spec.rb
@@ -61,7 +61,7 @@ describe SearchIndexer do
     scrubbed = scrub(html)
-    expect(scrubbed).to eq("Discourse 51%20PM Untitled design (21).jpg Untitled%20design%20(21) Untitled design (21).jpg 1280x1136 472 KB")
+    expect(scrubbed).to eq("Discourse 51%20PM")
   it 'correctly indexes a post according to version' do
@@ -110,5 +110,41 @@ describe SearchIndexer do
         post.save!(validate: false)
       end.to_not change { PostSearchData.count }
+    it "should not tokenize urls and duplicate title and href in <a>" do
+      post = Fabricate(:post, raw: <<~RAW)
+      https://meta.discourse.org/some.png
+      RAW
+      post.rebake!
+      post.reload
+      topic = post.topic
+      expect(post.post_search_data.raw_data).to eq(
+        "#{topic.title} #{topic.category.name} https://meta.discourse.org/some.png meta discourse org"
+    end
+    it 'should not include lightbox in search' do
+      Jobs.run_immediately!
+      SiteSetting.max_image_height = 2000
+      SiteSetting.crawl_images = true
+      FastImage.expects(:size).returns([1750, 2000])
+      src = "https://meta.discourse.org/some.png"
+      Let me see how I can fix this image
+      <img src="#{src}" width="275" height="299">
+      RAW
+      post.rebake!
+      post.reload
+        "#{topic.title} #{topic.category.name} Let me see how I can fix this image"
+    end
GitHub sha: cfd50782
DEV: Correct spec added in cfd507822f9330967f3ed9f970505e7f4896b523.
Hmmm should we be stripping this?
^^^ look at the title of that image.
Do you mean the alt or the title?
I guess it is alt, as long as we are keeping that…
FIX: Keep `alt` and `title` in lightbox when indexing for search.
