PERF: Introduce absolute limit of digests per 30 minutes (PR #10845)
To avoid blocking the sidekiq queue a limit of 10,000 digests per 30 minutes is introduced.
This acts as a safety measure that makes sure we don’t keep pouring oil on a fire.
On multisites it is recommended to set the number way lower so sites do not dominate the backlog. A reasonable default for multisites may be 100-500.
This can be controlled with the environment var
DISCOURSE_MAX_DIGESTS_ENQUEUED_PER_30_MINS_PER_SITE
GitHub
LGTM :+1: There are failed tests but seems unrelated.
