PERF: reduce exclusive locking when changing tables
posts and topics tables can be huge, this migration change ensures the migration performs less work in one giant transaction reducing risk of deadlocks
Migration is re-runnable thanks to NOT EXISTS checks
diff --git a/db/migrate/20200429095034_add_topic_thumbnail_information.rb b/db/migrate/20200429095034_add_topic_thumbnail_information.rb
index be34f93..ee48265 100644
--- a/db/migrate/20200429095034_add_topic_thumbnail_information.rb
+++ b/db/migrate/20200429095034_add_topic_thumbnail_information.rb
@@ -1,19 +1,36 @@
 # frozen_string_literal: true
 class AddTopicThumbnailInformation < ActiveRecord::Migration[6.0]
-  def change
-    add_reference :posts, :image_upload
-    add_reference :topics, :image_upload
+  disable_ddl_transaction!
-    add_column :theme_modifier_sets, :topic_thumbnail_sizes, :string, array: true
+  def up
-    create_table :topic_thumbnails do |t|
-      t.references :upload, null: false
-      t.references :optimized_image, null: true
-      t.integer :max_width, null: false
-      t.integer :max_height, null: false
+    # tables are huge ... avoid holding on to large number of locks by doing one at a time
+    execute <<~SQL
+      ALTER TABLE posts
+      ADD COLUMN IF NOT EXISTS image_upload_id bigint
+    SQL
+    execute <<~SQL
+      ALTER TABLE topics
+    SQL
+    ActiveRecord::Base.transaction do
+      add_column :theme_modifier_sets, :topic_thumbnail_sizes, :string, array: true
+      create_table :topic_thumbnails do |t|
+        t.references :upload, null: false
+        t.references :optimized_image, null: true
+        t.integer :max_width, null: false
+        t.integer :max_height, null: false
+      end
+      add_index :topic_thumbnails, [:upload_id, :max_width, :max_height], name: :unique_topic_thumbnails, unique: true
+  end
-    add_index :topic_thumbnails, [:upload_id, :max_width, :max_height], name: :unique_topic_thumbnails, unique: true
+  def down
+    raise IrriversibleMigration
GitHub sha: aa2a9da4
