PERF: we don't need to use a huge image to test thumbnails (#11025)
PERF: we don’t need to use a huge image to test thumbnails (#11025)
  • PERF: we don’t need to use a huge image to test thumbnails
Generating images with 5000x5000 dimensions is an expensive operation.
Using smaller images reduce the time of model spec from 11s to 3s and integration spec from 6s to 2s.
diff --git a/spec/integration/topic_thumbnail_spec.rb b/spec/integration/topic_thumbnail_spec.rb
index 2733fab..e517c00 100644
--- a/spec/integration/topic_thumbnail_spec.rb
+++ b/spec/integration/topic_thumbnail_spec.rb
@@ -2,9 +2,12 @@
 require 'rails_helper'
 describe "Topic Thumbnails" do
-  before { SiteSetting.create_thumbnails = true }
+  before do
+    SiteSetting.create_thumbnails = true
+    ImageSizer.stubs(:resize).returns([9, 9])
+  end
-  fab!(:image) { Fabricate(:image_upload, width: 5000, height: 5000) }
+  fab!(:image) { Fabricate(:image_upload, width: 50, height: 50) }
   fab!(:topic) { Fabricate(:topic, image_upload_id: image.id) }
   fab!(:user) { Fabricate(:user) }
@@ -27,9 +30,9 @@ describe "Topic Thumbnails" do
       before do
         theme = Fabricate(:theme)
         theme.theme_modifier_set.topic_thumbnail_sizes = [
-          [100, 100],
-          [200, 200],
-          [300, 300]
+          [10, 10],
+          [20, 20],
+          [30, 30]
         theme.theme_modifier_set.save!
         theme.set_default!
@@ -71,8 +74,8 @@ describe "Topic Thumbnails" do
         # Check first optimized
         expect(thumbnails[1]["max_width"]).to eq(Topic.share_thumbnail_size[0])
         expect(thumbnails[1]["max_height"]).to eq(Topic.share_thumbnail_size[1])
-        expect(thumbnails[1]["width"]).to eq(1024)
-        expect(thumbnails[1]["height"]).to eq(1024)
+        expect(thumbnails[1]["width"]).to eq(9)
+        expect(thumbnails[1]["height"]).to eq(9)
         expect(thumbnails[1]["url"]).to include("/optimized/")
diff --git a/spec/models/topic_thumbnail_spec.rb b/spec/models/topic_thumbnail_spec.rb
index 85b8ead..b89c081 100644
--- a/spec/models/topic_thumbnail_spec.rb
+++ b/spec/models/topic_thumbnail_spec.rb
@@ -2,15 +2,18 @@
 describe "TopicThumbnail" do
-  let(:upload1) { Fabricate(:image_upload, width: 5000, height: 5000) }
+  let(:upload1) { Fabricate(:image_upload, width: 50, height: 50) }
   let(:topic) { Fabricate(:topic, image_upload: upload1) }
-  let(:upload2) { Fabricate(:image_upload, width: 5000, height: 5000) }
+  let(:upload2) { Fabricate(:image_upload, width: 50, height: 50) }
   let(:topic2) { Fabricate(:topic, image_upload: upload2) }
   let(:upload3) { Fabricate(:upload_no_dimensions) }
   let(:topic3) { Fabricate(:topic, image_upload: upload3) }
   before do
+    Topic.stubs(:thumbnail_sizes).returns([[49, 49]])
     topic.generate_thumbnails!(extra_sizes: nil)
     TopicThumbnail.ensure_consistency!
@@ -69,5 +72,4 @@ describe "TopicThumbnail" do
     expect(topic.topic_thumbnails.length).to eq(0)
GitHub sha: 8253f8fc
This commit appears in #11025 which was approved by SamSaffron. It was merged by SamSaffron.
