Prefabricate admin in wizard_spec.rb
diff --git a/spec/components/wizard/wizard_spec.rb b/spec/components/wizard/wizard_spec.rb
index f0b543e..bf5490a 100644
--- a/spec/components/wizard/wizard_spec.rb
+++ b/spec/components/wizard/wizard_spec.rb
@@ -4,6 +4,8 @@ require 'rails_helper'
 require 'wizard'
 describe Wizard do
+  fab!(:admin) { Fabricate(:admin) }
   before do
     SiteSetting.wizard_enabled = true
@@ -118,19 +120,16 @@ describe Wizard do
     it "it's false when the wizard is disabled" do
       SiteSetting.wizard_enabled = false
-      admin = Fabricate(:admin)
       expect(build_simple(admin).requires_completion?).to eq(false)
     it "its false when the wizard is bypassed" do
       SiteSetting.bypass_wizard_check = true
     it "its automatically bypasses after you reach topic limit" do
       Fabricate(:topic)
       wizard = build_simple(admin)
       wizard.max_topics_to_require_completion = Topic.count - 1
@@ -140,7 +139,6 @@ describe Wizard do
     it "it's true for the first admin who logs in" do
       second_admin = Fabricate(:admin)
       UserAuthToken.generate!(user_id: second_admin.id)
@@ -149,14 +147,14 @@ describe Wizard do
     it "is false for staff when complete" do
-      wizard = build_simple(Fabricate(:admin))
+      wizard = build_simple(admin)
       updater = wizard.create_updater('simple', name: 'Evil Trout')
       updater.update
       expect(wizard.requires_completion?).to eq(false)
       # It's also false for another user
GitHub sha: 6e11ae06
