Re-generate rubocop todo list
From 1b26c8e42374986c1d98de55cfba6008a62a555d Mon Sep 17 00:00:00 2001
Date: Mon, 3 Dec 2018 13:35:02 -0200
Subject: [PATCH] Re-generate rubocop todo list
diff --git a/.rubocop_todo.yml b/.rubocop_todo.yml
index 98f39dc..d87d849 100644
--- a/.rubocop_todo.yml
+++ b/.rubocop_todo.yml
@@ -1,6 +1,6 @@
 # This configuration was generated by
 # `rubocop --auto-gen-config`
-# on 2018-11-26 16:58:18 +0000 using RuboCop version 0.60.0.
+# on 2018-12-03 15:33:57 +0000 using RuboCop version 0.60.0.
 # The point is for the user to remove these configuration records
 # one by one as the offenses are removed from the code base.
 # Note that changes in the inspected code, or installation of new
@@ -86,11 +86,6 @@ Metrics/BlockLength:
 Metrics/BlockNesting:
   Max: 4
-# Offense count: 9
-# Configuration parameters: CountComments.
-Metrics/ClassLength:
-  Max: 302
 # Offense count: 18
 Metrics/CyclomaticComplexity:
   Max: 30
@@ -109,6 +104,11 @@ Metrics/ModuleLength:
 Metrics/PerceivedComplexity:
   Max: 34
+# Offense count: 1
+Naming/AccessorMethodName:
+  Exclude:
+    - 'lib/message_bus/diagnostics.rb'
 # Offense count: 2
 # Configuration parameters: EnforcedStyleForLeadingUnderscores.
 # SupportedStylesForLeadingUnderscores: disallowed, required, optional
@@ -236,7 +236,7 @@ Style/CommentAnnotation:
     - 'lib/message_bus/backends/redis.rb'
     - 'lib/message_bus/rack/middleware.rb'
-# Offense count: 24
+# Offense count: 19
 Style/Documentation:
   Exclude:
     - 'spec/**/*'
@@ -247,7 +247,6 @@ Style/Documentation:
     - 'lib/message_bus/backends/memory.rb'
     - 'lib/message_bus/backends/postgres.rb'
-    - 'lib/message_bus/diagnostics.rb'
     - 'lib/message_bus/distributed_cache.rb'
     - 'lib/message_bus/em_ext.rb'
     - 'lib/message_bus/rack/diagnostics.rb'
@@ -470,12 +469,11 @@ Style/RedundantReturn:
   Exclude:
-# Offense count: 4
+# Offense count: 3
 # Cop supports --auto-correct.
 Style/RedundantSelf:
   Exclude:
     - 'lib/message_bus/client.rb'
-    - 'lib/message_bus/rack/middleware.rb'
 # Offense count: 3
@@ -510,7 +508,7 @@ Style/RescueStandardError:
     - 'lib/message_bus/timer_thread.rb'
-# Offense count: 17
+# Offense count: 18
 # Configuration parameters: ConvertCodeThatCanStartToReturnNil, Whitelist.
 # Whitelist: present?, blank?, presence, try, try!
@@ -544,7 +542,7 @@ Style/SpecialGlobalVars:
     - 'message_bus.gemspec'
     - 'spec/spec_helper.rb'
-# Offense count: 652
+# Offense count: 657
 # Configuration parameters: EnforcedStyle, ConsistentQuotesInMultiline.
 # SupportedStyles: single_quotes, double_quotes
@@ -652,7 +650,7 @@ Style/ZeroLengthPredicate:
     - 'spec/lib/message_bus_spec.rb'
-# Offense count: 160
+# Offense count: 210
 # Configuration parameters: AllowHeredoc, AllowURI, URISchemes, IgnoreCopDirectives, IgnoredPatterns.
 # URISchemes: http, https
 Metrics/LineLength:
GitHub
