README: Fix typo (#486)
diff --git a/README.md b/README.md
index 61b93b2..a5e4053 100644
--- a/README.md
+++ b/README.md
@@ -197,7 +197,7 @@ There are two additional `pp` options that can be used to analyze memory which d
 In a complex web application, it's possible for a request to trigger rare conditions that result in poor performance. Mini Profiler ships with a feature to help detect those rare conditions and fix them. It works by enabling invisible profiling on one request every N requests, and saving the performance metrics that are collected during the request (a.k.a snapshot of the request) so that they can be viewed later. To turn this feature on, set the `snapshot_every_n_requests` config to a value larger than 0. The larger the value is, the less frequently requests are profiled.
-Mini Profiler will exclude requests that are made to skippd paths (see `skip_paths` config below) from being sampled. Additionally, if profiling is enabled for a request that later finishes with a non-2xx status code, Mini Profiler will discard the snapshot and not save it (this behavior may change in the future).
+Mini Profiler will exclude requests that are made to skipped paths (see `skip_paths` config below) from being sampled. Additionally, if profiling is enabled for a request that later finishes with a non-2xx status code, Mini Profiler will discard the snapshot and not save it (this behavior may change in the future).
 After enabling snapshots sampling, you can see the snapshots that have been collected at `/mini-profiler-resources/snapshots` (or if you changed the `base_url_path` config, substitute `mini-profiler-resources` with your value of the config). You'll see on that page a table where each row represents a group of snapshots with the duration of the worst snapshot in that group. The worst snapshot in a group is defined as the snapshot whose request took longer than all of the snapshots in the same group. Snapshots grouped by HTTP method and path of the request, and if your application is a Rails app, Mini Profiler will try to convert the path to `controller#action` and group by that instead of request path. Clicking on a group will display the snapshots of that group sorted from worst to best. From there, you can click on a snapshot's ID to see the snapshot with all the performance metrics that were collected.
GitHub sha: cfbcf5d6
This commit appears in #486 which was merged by SamSaffron.
