REFACTOR/FIX: major frontend refactoring
This commit starts from a bug report concerning images not loading when used as foot note.
The source of the bug was discourse lazy-loading library, the image is always hidden before the tooltip is shown and as a result has never been tracked by our lazy-loading library. This commit changes the css of the notes container to be hidden (visbility: hidden) and in absolute position instead of not displayed (display: none).
Moreover this plugin applies the following changes:
  • removes jquery usage
  • uses popper for positioning
  • uses event delegation to have only one listener for the footnot click
  • cleanly removes event listeners
diff --git a/assets/javascripts/initializers/inline-footnotes.js.es6 b/assets/javascripts/initializers/inline-footnotes.js.es6
index bf43ec3..952cb92 100644
--- a/assets/javascripts/initializers/inline-footnotes.js.es6
+++ b/assets/javascripts/initializers/inline-footnotes.js.es6
@@ -1,90 +1,86 @@
 import { withPluginApi } from "discourse/lib/plugin-api";
 import { iconHTML } from "discourse-common/lib/icon-library";
-function showFootnote() {
-  let id = $(this).prev().find("a")[0].href;
-  id = "#" + id.split("#")[1];
-  let html = $(this).parents(".cooked").find(id).html();
-  $("#footnote-tooltip").remove();
-  let $elip = $(this);
-  let $post = $elip.offsetParent();
-  let pos = $elip.offset();
-  let delta = $post.offset();
-  pos.top -= delta.top;
-  pos.left -= delta.left;
-  let retina =
-    window.devicePixelRatio && window.devicePixelRatio > 1
-      ? "class='retina'"
-  $(this).after(
-    "<div id='footnote-tooltip' " +
-      retina +
-      "><div class='footnote-tooltip-pointer'></div><div class='footnote-tooltip-content'>" +
-      html +
-      "</div></div>"
-  $(window).on("click.footnote", (e) => {
-    if ($(e.target).closest("#footnote-tooltip").length === 0) {
-      $(window).off("click.footnote");
-    return true;
+let inlineFootnotePopper;
-  let $tooltip = $("#footnote-tooltip");
-  $tooltip.css({ top: 0, left: 0 });
+function createTooltip() {
+  const tooltip = document.createElement("div");
+  tooltip.id = "footnote-tooltip";
-  let left = pos.left - $tooltip.width() / 2 + $elip.width() + 3;
-  if (left < 0) {
-    $("#footnote-tooltip .footnote-tooltip-pointer").css({
-      "margin-left": left * 2 + "px",
-    left = 0;
+  if (window.devicePixelRatio && window.devicePixelRatio > 1) {
+    tooltip.classList.add("retina");
-  // also do a right margin fix
-  let topicWidth = $post.width();
-  if (left + $tooltip.width() > topicWidth) {
-    let oldLeft = left;
-    left = topicWidth - $tooltip.width();
+  const pointer = document.createElement("div");
+  pointer.classList.add("footnote-tooltip-pointer");
+  tooltip.append(pointer);
-      "margin-left": (oldLeft - left) * 2 + "px",
+  const content = document.createElement("div");
+  content.classList.add("footnote-tooltip-content");
+  tooltip.append(content);
-  $tooltip.css({
-    top: pos.top + 5 + "px",
-    left: left + "px",
-    visibility: "visible",
+  document.body.append(tooltip);
-  return false;
+  return tooltip;
-function inlineFootnotes($elem) {
-  if ($elem.hasClass("d-editor-preview")) {
+function showFootnote(event) {
+  inlineFootnotePopper && inlineFootnotePopper.destroy();
+  let tooltip = document.querySelector("#footnote-tooltip");
+  tooltip && tooltip.classList.remove("is-expanded");
+  if (!event.target.classList.contains("expand-footnote")) {
     return;
-  $elem
-    .find("sup.footnote-ref")
-    .after(
-      `<button class="expand-footnote btn btn-icon no-text">${iconHTML(
-        "ellipsis-h"
-      )}</btn>`
-    .next()
-    .on("click", showFootnote);
-  $elem.addClass("inline-footnotes");
+  const button = event.target;
+  const cooked = button.closest(".cooked");
+  tooltip = tooltip || createTooltip();
+  tooltip.classList.add("is-expanded");
+  const footnoteId = button.dataset.footnoteId;
+  const footnoteContent = tooltip.querySelector(".footnote-tooltip-content");
+  const newContent = cooked.querySelector(`#footnote-${footnoteId}`);
+  footnoteContent.innerHTML = newContent.innerHTML;
+  // eslint-disable-next-line
+  inlineFootnotePopper = new Popper.createPopper(button, tooltip, {
+    modifiers: [
+        name: "offset",
+        options: {
+          offset: [0, 12],
+function inlineFootnotes(elem) {
+  const footnoteRefs = elem.querySelectorAll("sup.footnote-ref");
+  footnoteRefs.forEach((footnoteRef) => {
+    const button = document.createElement("button");
+    button.classList.add("expand-footnote", "btn", "btn-icon", "no-text");
+    button.innerHTML = iconHTML("ellipsis-h");
+    button.dataset.footnoteId = footnoteRef
+      .querySelector("a")
+      .id.replace("footnote-ref-", "");
+    footnoteRef.after(button);
+  if (footnoteRefs.length) {
+    elem.classList.add("inline-footnotes");
+function clearPopper() {
+  inlineFootnotePopper = null;
 export default {
@@ -96,12 +92,28 @@ export default {
     withPluginApi("0.8.9", (api) => {
-      api.decorateCooked(
-        ($elem) => {
-          inlineFootnotes($elem);
-        { id: "inline-footnotes" }
+      api.decorateCookedElement((elem) => inlineFootnotes(elem), {
+        onlyStream: true,
+        id: "inline-footnotes",
+      api.cleanupStream(() => clearPopper);
+    const main = document.querySelector("#main");
+    if (main) {
+      main.addEventListener("click", showFootnote);
+  teardown() {
+    if (main) {
+      main.removeEventListener("click", showFootnote);
+    clearPopper();
diff --git a/assets/stylesheets/footnotes.scss b/assets/stylesheets/footnotes.scss
index 199ed0d..4cfd855 100644
--- a/assets/stylesheets/footnotes.scss
+++ b/assets/stylesheets/footnotes.scss
@@ -10,27 +10,38 @@ $footnote-tooltip-border: var(--primary-medium, $primary-medium);
       dark-light-choose($primary-low-mid, $secondary-high)
     border-radius: 5px;
+    .d-icon {
+      pointer-events: none;
+  // This is hack to work with lazy-loading, we will trick the browser
+  // to believe the image is in the DOM and can be loaded
+  .footnotes-list {
+    position: absolute;
   .footnote-ref,
   .footnotes-sep,
   .footnotes-list,
   .footnote-backref {
+    visibility: hidden;
+#footnote-tooltip {
+  background-color: $footnote-tooltip-background;
+  z-index: z("tooltip");
+  border: 1px solid $footnote-tooltip-border;
+  max-width: 400px;
+  overflow-wrap: break-word;
+  &:not(.is-expanded) {
     display: none;
-  #footnote-tooltip {
-    background-color: $footnote-tooltip-background;
-    position: absolute;
-    z-index: 1000;
-    border: 1px solid $footnote-tooltip-border;
-    max-width: 400px;
-    margin-top: 27px;
-    overflow-wrap: break-word;
-    visibility: hidden;
-    &.retina {
-      border: 0.5px solid $footnote-tooltip-border;
+  &.retina {
+    border: 0.5px solid $footnote-tooltip-border;
   .footnote-tooltip-pointer {
@@ -62,7 +73,6 @@ $footnote-tooltip-border: var(--primary-medium, $primary-medium);
     border-width: 9px;
     left: 50%;
     margin-left: -9px;
-    margin-bottom: -0.5px;
   .footnote-tooltip-content {
@@ -70,5 +80,14 @@ $footnote-tooltip-border: var(--primary-medium, $primary-medium);
     font-size: 0.93em;
     color: var(--primary-medium, $primary-medium);
     line-height: 1.4em;
+    overflow: hidden;
+    img {
+      object-fit: cover;
+    .footnote-backref {
+      display: none;
GitHub sha: 1d18bf28
