REFACTOR: Migrate `Discourse.Post` to imports
REFACTOR: Migrate Discourse.Post to imports
diff --git a/app/assets/javascripts/discourse/controllers/history.js.es6 b/app/assets/javascripts/discourse/controllers/history.js.es6
index 79203ed563..7d68d2ab66 100644
--- a/app/assets/javascripts/discourse/controllers/history.js.es6
+++ b/app/assets/javascripts/discourse/controllers/history.js.es6
@@ -7,6 +7,7 @@ import { propertyGreaterThan, propertyLessThan } from "discourse/lib/computed";
 import { on, observes } from "discourse-common/utils/decorators";
 import { sanitizeAsync } from "discourse/lib/text";
 import { iconHTML } from "discourse-common/lib/icon-library";
+import Post from "discourse/models/post";
 function customTagArray(fieldName) {
   return Ember.computed(fieldName, function() {
@@ -59,19 +60,19 @@ export default Controller.extend(ModalFunctionality, {
   refresh(postId, postVersion) {
     this.set("loading", true);
-    Discourse.Post.loadRevision(postId, postVersion).then(result => {
+    Post.loadRevision(postId, postVersion).then(result => {
       this.setProperties({ loading: false, model: result });
   hide(postId, postVersion) {
-    Discourse.Post.hideRevision(postId, postVersion).then(() =>
+    Post.hideRevision(postId, postVersion).then(() =>
       this.refresh(postId, postVersion)
   show(postId, postVersion) {
-    Discourse.Post.showRevision(postId, postVersion).then(() =>
+    Post.showRevision(postId, postVersion).then(() =>
diff --git a/app/assets/javascripts/discourse/models/post.js.es6 b/app/assets/javascripts/discourse/models/post.js.es6
index 83a18d9a12..b49aaea747 100644
--- a/app/assets/javascripts/discourse/models/post.js.es6
+++ b/app/assets/javascripts/discourse/models/post.js.es6
@@ -16,7 +16,7 @@ import Composer from "discourse/models/composer";
 import { Promise } from "rsvp";
 const Post = RestModel.extend({
-  // TODO: Remove this once one instantiate all `Discourse.Post` models via the store.
+  // TODO: Remove this once one instantiate all `Post` models via the store.
   siteSettings: Ember.computed({
     get() {
       return Discourse.SiteSettings;
@@ -320,7 +320,7 @@ const Post = RestModel.extend({
     // need to wait to hear back from server (stuff may not be loaded)
-    return Discourse.Post.updateBookmark(this.id, this.bookmarked)
+    return Post.updateBookmark(this.id, this.bookmarked)
       .then(result => {
         this.set("topic.bookmarked", result.topic_bookmarked);
         this.appEvents.trigger("page:bookmark-post-toggled", this);
@@ -417,7 +417,7 @@ Post.reopenClass({
   loadQuote(postId) {
     return ajax(`/posts/${postId}.json`).then(result => {
-      const post = Discourse.Post.create(result);
+      const post = Post.create(result);
       return Quote.build(post, post.raw, { raw: true, full: true });
diff --git a/lib/es6_module_transpiler/tilt/es6_module_transpiler_template.rb b/lib/es6_module_transpiler/tilt/es6_module_transpiler_template.rb
index 382417b8b4..c129e66001 100644
--- a/lib/es6_module_transpiler/tilt/es6_module_transpiler_template.rb
+++ b/lib/es6_module_transpiler/tilt/es6_module_transpiler_template.rb
@@ -91,8 +91,7 @@ JS
          "discourse/models/site",
          "discourse/models/user",
          "discourse/models/session",
-         "discourse/models/model",
-         "discourse/models/post"
+         "discourse/models/model"
diff --git a/test/javascripts/models/composer-test.js.es6 b/test/javascripts/models/composer-test.js.es6
index 78c823b2be..cd3135b74f 100644
--- a/test/javascripts/models/composer-test.js.es6
+++ b/test/javascripts/models/composer-test.js.es6
@@ -2,6 +2,7 @@ import EmberObject from "@ember/object";
 import { currentUser } from "helpers/qunit-helpers";
 import AppEvents from "discourse/services/app-events";
 import createStore from "helpers/create-store";
 QUnit.module("model:composer");
@@ -247,7 +248,7 @@ QUnit.test("editingFirstPost", assert => {
   const composer = createComposer();
   assert.ok(!composer.get("editingFirstPost"), "it's false by default");
-  const post = Discourse.Post.create({ id: 123, post_number: 2 });
+  const post = Post.create({ id: 123, post_number: 2 });
   composer.setProperties({ post: post, action: Composer.EDIT });
   assert.ok(
@@ -265,7 +266,7 @@ QUnit.test("clearState", assert => {
   const composer = createComposer({
     originalText: "asdf",
     reply: "asdf2",
-    post: Discourse.Post.create({ id: 1 }),
+    post: Post.create({ id: 1 }),
     title: "wat"
@@ -329,7 +330,7 @@ QUnit.test("Title length for static page topics as admin", assert => {
   Discourse.SiteSettings.max_topic_title_length = 10;
     post_number: 2,
     static_doc: true
diff --git a/test/javascripts/models/post-stream-test.js.es6 b/test/javascripts/models/post-stream-test.js.es6
index eb99d811af..49b6018e20 100644
--- a/test/javascripts/models/post-stream-test.js.es6
+++ b/test/javascripts/models/post-stream-test.js.es6
@@ -1,7 +1,8 @@
-QUnit.module("model:post-stream");
+QUnit.module("model:post-stream");
 const buildStream = function(id, stream) {
   const store = createStore();
   const topic = store.createRecord("topic", { id, chunk_size: 5 });
@@ -173,7 +174,7 @@ QUnit.test("updateFromJson", assert => {
   assert.equal(postStream.get("posts.length"), 1, "it loaded the posts");
-  assert.containsInstance(postStream.get("posts"), Discourse.Post);
+  assert.containsInstance(postStream.get("posts"), Post);
   assert.equal(postStream.get("extra_property"), 12);
diff --git a/test/javascripts/models/post-test.js.es6 b/test/javascripts/models/post-test.js.es6
index afe69d03ad..5a7aa34520 100644
--- a/test/javascripts/models/post-test.js.es6
+++ b/test/javascripts/models/post-test.js.es6
@@ -1,7 +1,9 @@
-QUnit.module("Discourse.Post");
+QUnit.module("model: Post");
 var buildPost = function(args) {
-  return Discourse.Post.create(
+  return Post.create(
     _.merge(
@@ -14,13 +16,13 @@ var buildPost = function(args) {
 QUnit.test("defaults", assert => {
-  var post = Discourse.Post.create({ id: 1 });
+  var post = Post.create({ id: 1 });
   assert.blank(post.get("deleted_at"), "it has no deleted_at by default");
   assert.blank(post.get("deleted_by"), "there is no deleted_by by default");
 QUnit.test("new_user", assert => {
-  var post = Discourse.Post.create({ trust_level: 0 });
+  var post = Post.create({ trust_level: 0 });
   assert.ok(post.get("new_user"), "post is from a new user");
   post.set("trust_level", 1);
@@ -28,7 +30,7 @@ QUnit.test("new_user", assert => {
 QUnit.test("firstPost", assert => {
-  var post = Discourse.Post.create({ post_number: 1 });
+  var post = Post.create({ post_number: 1 });
   assert.ok(post.get("firstPost"), "it's the first post");
   post.set("post_number", 10);
@@ -36,13 +38,13 @@ QUnit.test("firstPost", assert => {
 QUnit.test("updateFromPost", assert => {
     post_number: 1,
     raw: "hello world"
   post.updateFromPost(
-    Discourse.Post.create({
+    Post.create({
       raw: "different raw",
       wat: function() {
         return 123;
GitHub sha: 7e44065b
