REFACTOR: Move rendering to client-side (#7)
This commit changes from rendering alerts in post markdown to rendering them directly in the JS app. This means that updating the database with incoming alert data is much cheaper, and also gives us the flexibility to improve the alert UI in future without being restricted by markdown.
diff --git a/app/jobs/concerns/alert_post_mixin.rb b/app/jobs/concerns/alert_post_mixin.rb
index f0eb0dc..650fd6e 100644
--- a/app/jobs/concerns/alert_post_mixin.rb
+++ b/app/jobs/concerns/alert_post_mixin.rb
@@ -6,102 +6,9 @@ module AlertPostMixin
   FIRING_TAG = "firing".freeze
   HIGH_PRIORITY_TAG = "high-priority".freeze
   NEXT_BUSINESS_DAY_SLA = "nbd".freeze
-  MAX_DISPLAY_GROUP_SIZE = 100
-  FIRING_COLLAPSE_THRESHOLD = 100
-  HISTORY_COLLAPSE_THRESHOLD = 50
   private
-  def render_alerts(alert_history)
-    firing_alerts = []
-    resolved_alerts = []
-    silenced_alerts = []
-    stale_alerts = []
-    alert_history.each do |alert|
-      status = alert['status']
-      case
-      when is_firing?(status)
-        firing_alerts << alert
-      when status == 'resolved'
-        resolved_alerts << alert
-      when status == 'stale'
-        stale_alerts << alert
-      when is_suppressed?(status)
-        silenced_alerts << alert
-      end
-    end
-    output = ""
-    if firing_alerts.present?
-      output += "## :fire: #{I18n.t("prom_alert_receiver.post.headers.firing")}\n\n"
-      output = generate_alert_items(firing_alerts, output, collapse: firing_alerts.length > FIRING_COLLAPSE_THRESHOLD)
-    end
-    if silenced_alerts.present?
-      output += "\n\n# :shushing_face: Silenced Alerts\n\n"
-      output = generate_alert_items(silenced_alerts, output, collapse: silenced_alerts.length > HISTORY_COLLAPSE_THRESHOLD)
-    end
-      "history" => resolved_alerts,
-      "stale" => stale_alerts
-    }.each do |header, alerts|
-      if alerts.present?
-        header = I18n.t("prom_alert_receiver.post.headers.#{header}")
-        output += "\n\n## #{header}\n\n"
-        output = generate_alert_items(alerts, output, collapse: alerts.length > HISTORY_COLLAPSE_THRESHOLD)
-      end
-    end
-    output
-  end
-  def thead(alerts, datacenter, external_link)
-    headers = "| [#{datacenter}](#{external_link}) | |"
-    cells = "| --- | --- |"
-    if alerts.any? { |alert| alert['description'] }
-      headers += " |"
-      cells += " --- |"
-    end
-    headers += " |"
-    cells += " --- |"
-    "#{headers}\n#{cells}"
-  end
-  def alert_item(alert)
-    item = "| [#{alert['id']}](#{alert_link(alert)}) | #{alert_time_range(alert)} |"
-    if description = alert['description']
-      item += " #{description} |"
-    end
-    actions = []
-    link = logs_link(alert)
-    actions << "[:file_folder:](#{link})" if link.present?
-    link = grafana_link(alert)
-    actions << "[:bar_chart:](#{link})" if link.present?
-    item += " <div>#{ actions.join(" ") }</div> |" if actions.present?
-    item
-  end
-  def alert_time_range(alert)
-    if alert['ends_at']
-      "#{local_date(alert['starts_at'])} to #{local_date(alert['ends_at'], alert['starts_at'])}"
-    else
-      "active since #{local_date(alert['starts_at'])}"
-    end
-  end
   def local_date(time, starts_at = nil)
     parsed = Time.zone.parse(time)
     format = "L HH:mm"
@@ -119,43 +26,6 @@ module AlertPostMixin
     date
-  def alert_link(alert)
-    url = URI(alert['graph_url'])
-    url_params = CGI.parse(url.query)
-    begin_t = Time.parse(alert['starts_at'])
-    end_t   = Time.parse(alert['ends_at']) rescue Time.zone.now
-    url_params['g0.range_input'] = "#{(end_t - begin_t).to_i + 600}s"
-    url_params['g0.end_input']   = "#{(end_t + 300).strftime("%Y-%m-%d %H:%M")}"
-    url_params['g0.tab'] = ["0"]
-    url.query = URI.encode_www_form(url_params)
-    url.to_s
-  end
-  def logs_link(alert)
-    return if alert['logs_url'].blank?
-    url = "#{alert['logs_url']}#/discover"
-    "#{url}?_g=(time:(from:'#{begin_t.to_s(:iso8601)}',mode:absolute,to:'#{end_t.to_s(:iso8601)}'))"
-  end
-  def grafana_link(alert)
-    return if alert['grafana_url'].blank?
-    url = URI(alert['grafana_url'])
-    url_params = CGI.parse(url.query || "")
-    url_params['from'] = "#{begin_t.to_i}000"
-    url_params['to'] = "#{end_t.to_i}000"
-    url.to_s
-  end
   def get_grafana_dashboard_url(alert, grafana_url)
     return if alert.blank? || grafana_url.blank?
@@ -190,7 +60,8 @@ module AlertPostMixin
     output = ""
     output += "#{topic_body}\n\n"
     output += "#{prev_topic_link(prev_topic_id)}\n\n" if prev_topic_id
-    output += "#{render_alerts(alert_history)}\n"
+    output
   def revise_topic(topic:, title:, raw:, datacenters:, firing: nil, high_priority: false)
@@ -236,10 +107,6 @@ module AlertPostMixin
-  def is_suppressed?(status)
-    "suppressed".freeze == status
-  end
   def is_firing?(status)
     status == "firing".freeze
@@ -249,32 +116,4 @@ module AlertPostMixin
       set << alert['datacenter'] if alert['datacenter']
     end.to_a
-  def generate_alert_items(grouped_alerts, output, collapse: false)
-    output += "<div data-plugin='prom-alerts-table'>\n\n"
-    grouped_alerts
-      .group_by { |alert| [alert['datacenter'], alert['external_url']] }
-      .each do |(datacenter, external_url), alerts|
-      total_count = alerts.length
-      is_truncated = truncated_count = nil
-      if total_count > MAX_DISPLAY_GROUP_SIZE
-        is_truncated = true
-        truncated_count = alerts.length - MAX_DISPLAY_GROUP_SIZE
-        alerts = alerts.first(MAX_DISPLAY_GROUP_SIZE)
-      end
-      output += "[details=#{datacenter} (#{total_count})]\n" if collapse
-      output += "#{thead(alerts, datacenter, external_url)}\n"
-      output += alerts.first(MAX_DISPLAY_GROUP_SIZE).map { |alert| alert_item(alert) }.join("\n")
-      output += "\n|[#{I18n.t("prom_alert_receiver.post.more", count: truncated_count)}](#{external_url})|" if is_truncated
-      output += "\n[/details]" if collapse
-      output += "\n\n"
-    end
-    output += "</div>"
-    output
-  end
diff --git a/app/jobs/regular/process_alert.rb b/app/jobs/regular/process_alert.rb
index 7160229..66d3e82 100644
--- a/app/jobs/regular/process_alert.rb
+++ b/app/jobs/regular/process_alert.rb
@@ -84,6 +84,7 @@ module Jobs
       # explicitly declared as JSON fields, so we have to wrap our array in
       # a single-element hash.
       topic.custom_fields[::DiscoursePrometheusAlertReceiver::ALERT_HISTORY_CUSTOM_FIELD] = { 'alerts' => alert_history }
+      topic.custom_fields[::DiscoursePrometheusAlertReceiver::ALERT_HISTORY_VERSION_CUSTOM_FIELD] = 2
       topic.save_custom_fields
       MessageBus.publish("/alert-receiver",
diff --git a/app/jobs/regular/process_grouped_alerts.rb b/app/jobs/regular/process_grouped_alerts.rb
index dfd1344..dbd15e2 100644
--- a/app/jobs/regular/process_grouped_alerts.rb
+++ b/app/jobs/regular/process_grouped_alerts.rb
           if updated
             topic.save_custom_fields(true)
             klass = DiscoursePrometheusAlertReceiver
diff --git a/assets/javascripts/discourse/initializers/initialize-discourse-prometheus-alert-receiver.js.es6 b/assets/javascripts/discourse/initializers/initialize-discourse-prometheus-alert-receiver.js.es6
index 7f83ae9..e37ac8a 100644
--- a/assets/javascripts/discourse/initializers/initialize-discourse-prometheus-alert-receiver.js.es6
+++ b/assets/javascripts/discourse/initializers/initialize-discourse-prometheus-alert-receiver.js.es6
@@ -1,4 +1,5 @@
 import { withPluginApi } from "discourse/lib/plugin-api";
+import { observes } from "discourse-common/utils/decorators";
 export default {
@@ -15,6 +16,28 @@ export default {
GitHub sha: 688c5d56
This commit appears in #7 which was merged by davidtaylorhq.
