REFACTOR: preferences/account controller (#7698)
diff --git a/app/assets/javascripts/discourse/controllers/preferences/account.js.es6 b/app/assets/javascripts/discourse/controllers/preferences/account.js.es6
index c0a7fc4..ac56e0e 100644
--- a/app/assets/javascripts/discourse/controllers/preferences/account.js.es6
+++ b/app/assets/javascripts/discourse/controllers/preferences/account.js.es6
@@ -2,7 +2,7 @@ import { iconHTML } from "discourse-common/lib/icon-library";
 import CanCheckEmails from "discourse/mixins/can-check-emails";
 import { default as computed } from "ember-addons/ember-computed-decorators";
 import PreferencesTabController from "discourse/mixins/preferences-tab-controller";
-import { setting } from "discourse/lib/computed";
+import { propertyNotEqual, setting } from "discourse/lib/computed";
 import { popupAjaxError } from "discourse/lib/ajax-error";
 import showModal from "discourse/lib/show-modal";
 import { findAll } from "discourse/models/login-method";
@@ -40,9 +40,7 @@ export default Ember.Controller.extend(
     reset() {
-      this.setProperties({
-        passwordProgress: null
+      this.set("passwordProgress", null);
     @computed()
@@ -54,10 +52,7 @@ export default Ember.Controller.extend(
-    @computed("model.availableTitles")
-    canSelectTitle(availableTitles) {
-      return availableTitles.length > 0;
+    canSelectTitle: Ember.computed.gt("model.availableTitles.length", 0),
     @computed("model.is_anonymous")
     canChangePassword(isAnonymous) {
@@ -86,15 +81,10 @@ export default Ember.Controller.extend(
-      return result.filter(value => {
-        return value.account || value.method.get("can_connect");
+      return result.filter(value => value.account || value.method.can_connect);
-    @computed("model.id")
-    disableConnectButtons(userId) {
-      return userId !== this.get("currentUser.id");
+    disableConnectButtons: propertyNotEqual("model.id", "currentUser.id"),
     @computed(
       "model.second_factor_enabled",
@@ -129,25 +119,23 @@ export default Ember.Controller.extend(
         : tokens.slice(0, DEFAULT_AUTH_TOKENS_COUNT);
-    @computed("model.user_auth_tokens")
-    canShowAllAuthTokens(tokens) {
-      return tokens.length > DEFAULT_AUTH_TOKENS_COUNT;
+    canShowAllAuthTokens: Ember.computed.gt(
+      "model.user_auth_tokens.length",
+      DEFAULT_AUTH_TOKENS_COUNT
     actions: {
       save() {
         this.set("saved", false);
-        const model = this.model;
-        model.set("name", this.newNameInput);
-        model.set("title", this.newTitleInput);
+        this.model.setProperties({
+          name: this.newNameInput,
+          title: this.newTitleInput
-        return model
+        return this.model
           .save(this.saveAttrNames)
-          .then(() => {
-            this.set("saved", true);
+          .then(() => this.set("saved", true))
           .catch(popupAjaxError);
@@ -178,17 +166,14 @@ export default Ember.Controller.extend(
       delete() {
         this.set("deleting", true);
-        const self = this,
-          message = I18n.t("user.delete_account_confirm"),
+        const message = I18n.t("user.delete_account_confirm"),
           model = this.model,
           buttons = [
               label: I18n.t("cancel"),
               class: "d-modal-cancel",
               link: true,
-              callback: () => {
-                this.set("deleting", false);
+              callback: () => this.set("deleting", false)
               label:
@@ -197,14 +182,15 @@ export default Ember.Controller.extend(
               class: "btn btn-danger",
               callback() {
                 model.delete().then(
-                  function() {
-                    bootbox.alert(I18n.t("user.deleted_yourself"), function() {
-                      window.location.pathname = Discourse.getURL("/");
+                    bootbox.alert(
+                      I18n.t("user.deleted_yourself"),
+                      () => (window.location.pathname = Discourse.getURL("/"))
-                  function() {
                     bootbox.alert(I18n.t("user.delete_yourself_not_allowed"));
-                    self.set("deleting", false);
+                    this.set("deleting", false);
@@ -214,25 +200,23 @@ export default Ember.Controller.extend(
       revokeAccount(account) {
         this.set("revoking", true);
-        model
+        this.model
           .revokeAssociatedAccount(account.name)
           .then(result => {
             if (result.success) {
-              model.get("associated_accounts").removeObject(account);
+              this.model.associated_accounts.removeObject(account);
             } else {
               bootbox.alert(result.message);
-          .finally(() => {
-            this.set("revoking", false);
+          .finally(() => this.set("revoking", false));
       toggleShowAllAuthTokens() {
-        this.set("showAllAuthTokens", !this.showAllAuthTokens);
+        this.toggleProperty("showAllAuthTokens");
       revokeAuthToken(token) {
GitHub sha: 69f75b2a
