REFACTOR: Remove container from `DiscourseURL`
REFACTOR: Remove container from DiscourseURL
diff --git a/app/assets/javascripts/discourse/app/lib/url.js b/app/assets/javascripts/discourse/app/lib/url.js
index a7e5dcc..916a382 100644
--- a/app/assets/javascripts/discourse/app/lib/url.js
+++ b/app/assets/javascripts/discourse/app/lib/url.js
@@ -7,6 +7,7 @@ import { defaultHomepage } from "discourse/lib/utilities";
 import User from "discourse/models/user";
 import { default as getURL, withoutPrefix } from "discourse-common/lib/get-url";
 import Session from "discourse/models/session";
+import { setOwner } from "@ember/application";
 const rewrites = [];
 const TOPIC_REGEXP = /\/t\/([^\/]+)\/(\d+)\/?(\d+)?/;
@@ -189,7 +190,7 @@ const DiscourseURL = EmberObject.extend({
       // while URLs are loading. For example, while a topic loads it sets `currentPost`
       // which triggers a replaceState even though the topic hasn't fully loaded yet!
       next(() => {
-        const location = DiscourseURL.get("router.location");
+        const location = this.get("router.location");
         if (location && location.replaceURL) {
           location.replaceURL(path);
@@ -231,7 +232,7 @@ const DiscourseURL = EmberObject.extend({
     const pathname = path.replace(/(https?\:)?\/\/[^\/]+/, "");
-    if (!DiscourseURL.isInternal(path)) {
+    if (!this.isInternal(path)) {
       return redirectTo(path);
@@ -361,7 +362,7 @@ const DiscourseURL = EmberObject.extend({
       // If the topic_id is the same
       if (oldTopicId === newTopicId) {
-        DiscourseURL.replaceState(path);
+        this.replaceState(path);
         const container = Discourse.__container__;
         const topicController = container.lookup("controller:topic");
@@ -436,17 +437,6 @@ const DiscourseURL = EmberObject.extend({
     return window.location.origin + (prefix === "/" ? "" : prefix);
-  // TODO: These container calls can be replaced eventually if we migrate this to a service
-  // object.
-    @private
-    Get a handle on the application's router. Note that currently it uses `__container__` which is not
-    advised but there is no other way to access the router.
-    @property router
   get router() {
     return Discourse.__container__.lookup("router:main");
@@ -455,8 +445,6 @@ const DiscourseURL = EmberObject.extend({
     return Discourse.__container__.lookup("service:app-events");
-  // Get a controller. Note that currently it uses `__container__` which is not
-  // advised but there is no other way to access the router.
   controllerFor(name) {
     return Discourse.__container__.lookup("controller:" + name);
@@ -498,6 +486,12 @@ const DiscourseURL = EmberObject.extend({
     const promise = transition.promise || transition;
     promise.then(() => jumpToElement(elementId));
-}).create();
+let _urlInstance = DiscourseURL.create();
+export function setURLContainer(container) {
+  _urlInstance.container = container;
+  setOwner(_urlInstance, container);
-export default DiscourseURL;
+export default _urlInstance;
diff --git a/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
index 3cc3b0f..1f209be 100644
--- a/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
+++ b/app/assets/javascripts/discourse/app/pre-initializers/discourse-bootstrap.js
@@ -12,6 +12,7 @@ import { setupURL, setupS3CDN } from "discourse-common/lib/get-url";
 import deprecated from "discourse-common/lib/deprecated";
 import { setIconList } from "discourse-common/lib/icon-library";
 import { setPluginContainer } from "discourse/lib/plugin-api";
+import { setURLContainer } from "discourse/lib/url";
 export default {
@@ -19,6 +20,7 @@ export default {
   // The very first initializer to run
   initialize(container, app) {
     setPluginContainer(container);
+    setURLContainer(container);
     // Our test environment has its own bootstrap code
     if (isTesting()) {
diff --git a/test/javascripts/helpers/qunit-helpers.js b/test/javascripts/helpers/qunit-helpers.js
index 75c4102..8be26c0 100644
--- a/test/javascripts/helpers/qunit-helpers.js
+++ b/test/javascripts/helpers/qunit-helpers.js
@@ -28,6 +28,7 @@ import { mapRoutes } from "discourse/mapping-router";
 import { currentSettings, mergeSettings } from "helpers/site-settings";
 import { getOwner } from "discourse-common/lib/get-owner";
 import { setTopicList } from "discourse/lib/topic-list-tracker";
 export function currentUser() {
   return User.create(sessionFixtures["/session/current.json"].current_user);
@@ -174,6 +175,7 @@ export function acceptance(name, options) {
       Discourse.reset();
       this.container = getOwner(this);
       setPluginContainer(this.container);
+      setURLContainer(this.container);
       if (options.beforeEach) {
         options.beforeEach.call(this);
@@ -202,6 +204,7 @@ export function acceptance(name, options) {
       resetCustomPostMessageCallbacks();
       setTopicList(null);
       _clearSnapshots();
+      setURLContainer(null);
       Discourse._runInitializer(
         "instanceInitializers",
         (initName, initializer) => {
diff --git a/test/javascripts/test_helper.js b/test/javascripts/test_helper.js
index 692454e..6347854 100644
--- a/test/javascripts/test_helper.js
+++ b/test/javascripts/test_helper.js
@@ -165,7 +165,10 @@ QUnit.testStart(function(ctx) {
   Session.resetCurrent();
   User.resetCurrent();
   resetSite(settings);
-  createHelperContext({ siteSettings: settings });
+  createHelperContext({
+    siteSettings: settings,
+    capabilities: {}
   _DiscourseURL.redirectedTo = null;
   _DiscourseURL.redirectTo = function(url) {
GitHub sha: 98e5e1cd
This commit appears in #10480 which was merged by eviltrout.
