REFACTOR: Remove `_.range` and use ES6 instead
REFACTOR: Remove _.range and use ES6 instead
diff --git a/app/assets/javascripts/discourse/app/models/composer.js b/app/assets/javascripts/discourse/app/models/composer.js
index 41fca8f..f1913b0 100644
--- a/app/assets/javascripts/discourse/app/models/composer.js
+++ b/app/assets/javascripts/discourse/app/models/composer.js
@@ -23,7 +23,6 @@ import Site from "discourse/models/site";
 import User from "discourse/models/user";
 import deprecated from "discourse-common/lib/deprecated";
 import bootbox from "bootbox";
-import { isEmpty } from "@ember/utils";
 // The actions the composer can take
 export const CREATE_TOPIC = "createTopic",
diff --git a/app/assets/javascripts/discourse/app/models/post-stream.js b/app/assets/javascripts/discourse/app/models/post-stream.js
index c9b35f3..c36cf9a 100644
--- a/app/assets/javascripts/discourse/app/models/post-stream.js
+++ b/app/assets/javascripts/discourse/app/models/post-stream.js
@@ -362,7 +362,9 @@ export default RestModel.extend({
     if (this.isMegaTopic) {
       this.set("loadingBelow", true);
-      const fakePostIds = _.range(-1, -this.get("topic.chunk_size"), -1);
+      const fakePostIds = [
+        ...Array(this.get("topic.chunk_size") - 1).keys()
+      ].map(i => -i - 1);
       postsWithPlaceholders.appending(fakePostIds);
       return this.fetchNextWindow(
diff --git a/plugins/poll/assets/javascripts/controllers/poll-ui-builder.js.es6 b/plugins/poll/assets/javascripts/controllers/poll-ui-builder.js.es6
index 2c0c4ff..7c2c9e1 100644
--- a/plugins/poll/assets/javascripts/controllers/poll-ui-builder.js.es6
+++ b/plugins/poll/assets/javascripts/controllers/poll-ui-builder.js.es6
@@ -334,10 +334,11 @@ export default Controller.extend({
     return EmberObject.create(options);
-  _comboboxOptions(start_index, end_index) {
-    return _.range(start_index, end_index).map(number => {
-      return { value: number, name: number };
+  _comboboxOptions(startIndex, endIndex) {
+    return [...Array(endIndex - startIndex).keys()].map(number => ({
+      value: number + startIndex,
+      name: number + startIndex
   _setupPoll() {
diff --git a/test/javascripts/helpers/create-pretender.js b/test/javascripts/helpers/create-pretender.js
index 1ed9e4c..3b648b5 100644
--- a/test/javascripts/helpers/create-pretender.js
+++ b/test/javascripts/helpers/create-pretender.js
@@ -521,17 +521,15 @@ export function applyDefaultHandlers(pretender) {
         post_number: parseInt(p, 10)
     } else if (postNumber && request.queryParams.asc === "true") {
-      posts = _.range(postNumber + 1, postNumber + 6).map(p => ({
-        id: parseInt(p, 10),
-        post_number: parseInt(p, 10)
+      posts = [...Array(5).keys()].map(p => ({
+        id: p + postNumber + 1,
+        post_number: p + postNumber + 1
     } else if (postNumber && request.queryParams.asc === "false") {
-      posts = _.range(postNumber - 5, postNumber)
-        .reverse()
-        .map(p => ({
+        id: postNumber - p - 1,
+        post_number: postNumber - p - 1
     return response(200, { post_stream: { posts } });
GitHub sha: 55c9c54b
This commit appears in #10566 which was merged by eviltrout.
