REFACTOR: Replace global `find` with `queryAll`
REFACTOR: Replace global find with queryAll
In newer Embers jQuery is removed. There is a find but it only returns one element and not a jQuery selector. This patch migrates our code to a new helper queryAll which allows us to remove the global.
diff --git a/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-item-test.js b/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-item-test.js
index 70bace0..ff2356b 100644
--- a/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-item-test.js
+++ b/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-item-test.js
@@ -1,3 +1,4 @@
+import { queryAll } from "discourse/tests/helpers/qunit-helpers";
 import { moduleForComponent } from "ember-qunit";
 import I18n from "I18n";
 import componentTest from "discourse/tests/helpers/component-test";
@@ -13,7 +14,11 @@ componentTest("default theme", {
   test(assert) {
     assert.expect(1);
-    assert.equal(find(".d-icon-check").length, 1, "shows default theme icon");
+    assert.equal(
+      queryAll(".d-icon-check").length,
+      1,
+      "shows default theme icon"
@@ -28,7 +33,11 @@ componentTest("pending updates", {
   test(assert) {
     assert.expect(1);
-    assert.equal(find(".d-icon-sync").length, 1, "shows pending update icon");
+    assert.equal(
+      queryAll(".d-icon-sync").length,
+      1,
+      "shows pending update icon"
@@ -47,7 +56,7 @@ componentTest("broken theme", {
   test(assert) {
     assert.expect(1);
     assert.equal(
-      find(".d-icon-exclamation-circle").length,
+      queryAll(".d-icon-exclamation-circle").length,
       1,
       "shows broken theme icon"
@@ -75,7 +84,7 @@ componentTest("with children", {
   test(assert) {
     assert.expect(2);
     assert.deepEqual(
-      find(".components")
+      queryAll(".components")
         .text()
         .trim()
         .split(",")
@@ -88,7 +97,7 @@ componentTest("with children", {
       "lists the first 4 children"
     assert.deepEqual(
-      find(".others-count").text().trim(),
+      queryAll(".others-count").text().trim(),
       I18n.t("admin.customize.theme.and_x_more", { count: 1 }),
       "shows count of remaining children"
diff --git a/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-test.js b/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-test.js
index 7dc3779..0eaa6eb 100644
--- a/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-test.js
+++ b/app/assets/javascripts/admin/tests/admin/integration/components/themes-list-test.js
@@ -1,3 +1,4 @@
@@ -29,36 +30,40 @@ componentTest("current tab is themes", {
   test(assert) {
     assert.equal(
-      find(".themes-tab").hasClass("active"),
+      queryAll(".themes-tab").hasClass("active"),
       true,
       "themes tab is active"
     assert.equal(
-      find(".components-tab").hasClass("active"),
+      queryAll(".components-tab").hasClass("active"),
       false,
       "components tab is not active"
     assert.equal(
-      find(".inactive-indicator").index(),
+      queryAll(".inactive-indicator").index(),
       -1,
       "there is no inactive themes separator when all themes are inactive"
-    assert.equal(find(".themes-list-item").length, 5, "displays all themes");
+    assert.equal(
+      queryAll(".themes-list-item").length,
+      5,
+      "displays all themes"
     [2, 3].forEach((num) => this.themes[num].set("user_selectable", true));
     this.themes[4].set("default", true);
     this.set("themes", this.themes);
     const names = [4, 2, 3, 0, 1].map((num) => this.themes[num].get("name")); // default theme always on top, followed by user-selectable ones and then the rest
     assert.deepEqual(
-      Array.from(find(".themes-list-item").find(".name")).map((node) =>
+      Array.from(queryAll(".themes-list-item .name")).map((node) =>
         node.innerText.trim()
       names,
       "sorts themes correctly"
     assert.equal(
       3,
       "the separator is in the right location"
@@ -66,19 +71,19 @@ componentTest("current tab is themes", {
     this.themes.forEach((theme) => theme.set("user_selectable", true));
     assert.equal(
       -1,
       "there is no inactive themes separator when all themes are user-selectable"
     this.set("themes", []);
     assert.equal(
-      find(".themes-list-item").length,
       1,
       "shows one entry with a message when there is nothing to display"
     assert.equal(
-      find(".themes-list-item span.empty").text().trim(),
+      queryAll(".themes-list-item span.empty").text().trim(),
       I18n.t("admin.customize.theme.empty"),
       "displays the right message"
@@ -109,35 +114,35 @@ componentTest("current tab is components", {
   test(assert) {
     assert.equal(
       true,
       "components tab is active"
     assert.equal(
       false,
       "themes tab is not active"
     assert.equal(
       -1,
       "there is no separator"
     assert.equal(
       5,
       "displays all components"
     this.set("components", []);
     assert.equal(
       1,
     assert.equal(
diff --git a/app/assets/javascripts/discourse/tests/acceptance/account-created-test.js b/app/assets/javascripts/discourse/tests/acceptance/account-created-test.js
index 3c576b0..a7111dd 100644
--- a/app/assets/javascripts/discourse/tests/acceptance/account-created-test.js
+++ b/app/assets/javascripts/discourse/tests/acceptance/account-created-test.js
@@ -1,3 +1,4 @@
 import { exists } from "discourse/tests/helpers/qunit-helpers";
 import { visit, click, fillIn } from "@ember/test-helpers";
 import { test } from "qunit";
@@ -13,7 +14,7 @@ acceptance("Account Created", function () {
     assert.ok(exists(".account-created"));
     assert.equal(
-      find(".account-created .ac-message").text().trim(),
+      queryAll(".account-created .ac-message").text().trim(),
       "Hello World",
       "it displays the message"
@@ -32,7 +33,7 @@ acceptance("Account Created", function () {
     assert.equal(
       "Hello World",
@@ -40,7 +41,7 @@ acceptance("Account Created", function () {
     await click(".activation-controls .resend");
     assert.equal(currentPath(), "account-created.resent");
-    const email = find(".account-created .ac-message b").text();
+    const email = queryAll(".account-created .ac-message b").text();
     assert.equal(email, "eviltrout@example.com");
@@ -57,7 +58,7 @@ acceptance("Account Created", function () {
GitHub sha: 435a9913
This commit appears in #11059 which was approved by CvX. It was merged by eviltrout.
