REFACTOR: Resize controls (#9393)
diff --git a/app/assets/javascripts/pretty-text/engines/discourse-markdown/resize-controls.js b/app/assets/javascripts/pretty-text/engines/discourse-markdown/resize-controls.js
index 5a863bb..16e5a17 100644
--- a/app/assets/javascripts/pretty-text/engines/discourse-markdown/resize-controls.js
+++ b/app/assets/javascripts/pretty-text/engines/discourse-markdown/resize-controls.js
@@ -1,3 +1,5 @@
+const SCALES = ["100", "75", "50"];
 function isUpload(token) {
   return token.content.includes("upload://");
@@ -6,16 +8,8 @@ function hasMetadata(token) {
   return token.content.match(/(\d{1,4}x\d{1,4})/);
-function buildToken(state, type, tag, klass, nesting) {
-  const token = new state.Token(type, tag, nesting);
-  token.block = true;
-  token.attrs = [["class", klass]];
-  return token;
-function wrapImage(tokens, index, state, imgNumber) {
-  const imgToken = tokens[index];
-  const sizePart = imgToken.content
+function appendMetaData(index, token) {
+  const sizePart = token.content
     .split("|")
     .find(x => x.match(/\d{1,4}x\d{1,4}(,\s*\d{1,3}%)?/));
   let selectedScale =
@@ -23,114 +17,53 @@ function wrapImage(tokens, index, state, imgNumber) {
     sizePart
       .split(",")
       .pop()
-      .trim();
-  tokens.splice(
-    index,
-    0,
-    buildToken(state, "wrap_image_open", "span", "image-wrapper", 1)
-  const newElements = [];
-  const btnWrapper = buildToken(
-    state,
-    "wrap_button_open",
-    "span",
-    "button-wrapper",
-    1
-  btnWrapper.attrs.push(["data-image-index", imgNumber]);
-  newElements.push(btnWrapper);
-  const minimumScale = 50;
-  const scales = [100, 75, minimumScale];
-  const overwriteScale = !scales.find(scale => `${scale}%` === selectedScale);
-  if (overwriteScale) selectedScale = "100%";
-  scales.forEach(scale => {
-    const scaleText = `${scale}%`;
-    const btnClass =
-      scaleText === selectedScale ? "scale-btn active" : "scale-btn";
-    const scaleBtn = buildToken(
-      state,
-      "scale_button_open",
-      "span",
-      btnClass,
-      1
-    scaleBtn.attrs.push(["data-scale", scale]);
-    newElements.push(scaleBtn);
-    let textToken = buildToken(state, "text", "", "", 0);
-    textToken.content = scaleText;
-    newElements.push(textToken);
-    newElements.push(buildToken(state, "scale_button_close", "span", "", -1));
-    if (scale !== minimumScale) {
-      newElements.push(buildToken(state, "separator", "span", "separator", 1));
-      let separatorToken = buildToken(state, "text", "", "", 0);
-      separatorToken.content = " • ";
-      newElements.push(separatorToken);
-      newElements.push(buildToken(state, "separator_close", "span", "", -1));
-  newElements.push(buildToken(state, "wrap_button_close", "span", "", -1));
-  newElements.push(buildToken(state, "wrap_image_close", "span", "", -1));
-  const afterImageIndex = index + 2;
-  tokens.splice(afterImageIndex, 0, ...newElements);
+      .trim()
+      .replace("%", "");
-function updateIndexes(indexes, name) {
-  indexes[name].push(indexes.current);
-  indexes.current++;
+  const overwriteScale = !SCALES.find(scale => scale === selectedScale);
+  if (overwriteScale) selectedScale = "100";
-function wrapImages(tokens, tokenIndexes, state, imgNumberIndexes) {
-  //We do this in reverse order because it's easier for #wrapImage to manipulate the tokens array.
-  for (let j = tokenIndexes.length - 1; j >= 0; j--) {
-    let index = tokenIndexes[j];
-    wrapImage(tokens, index, state, imgNumberIndexes.pop());
+  token.attrs.push(["index-image", index]);
+  token.attrs.push(["scale", selectedScale]);
 function rule(state) {
-  let blockIndexes = [];
-  const indexNumbers = { current: 0, blocks: [], childrens: [] };
+  let currentIndex = 0;
   for (let i = 0; i < state.tokens.length; i++) {
     let blockToken = state.tokens[i];
     const blockTokenImage = blockToken.tag === "img";
     if (blockTokenImage && isUpload(blockToken) && hasMetadata(blockToken)) {
-      blockIndexes.push(i);
-      updateIndexes(indexNumbers, "blocks");
+      appendMetaData(currentIndex, blockToken);
+      currentIndex++;
     if (!blockToken.children) continue;
-    const childrenIndexes = [];
     for (let j = 0; j < blockToken.children.length; j++) {
       let token = blockToken.children[j];
       const childrenImage = token.tag === "img";
       if (childrenImage && isUpload(blockToken) && hasMetadata(token)) {
-        childrenIndexes.push(j);
-        updateIndexes(indexNumbers, "childrens");
+        appendMetaData(currentIndex, token);
+        currentIndex++;
-    wrapImages(
-      blockToken.children,
-      childrenIndexes,
-      state,
-      indexNumbers.childrens
-  wrapImages(state.tokens, blockIndexes, state, indexNumbers.blocks);
+function buildScaleButton(selectedScale, scale) {
+  const activeScaleClass = selectedScale === scale ? "active" : "";
+  return (
+    "<span class='scale-btn" +
+    activeScaleClass +
+    "' data-scale='" +
+    scale +
+    scale +
+    "%</span>"
 export function setup(helper) {
@@ -147,6 +80,35 @@ export function setup(helper) {
     helper.registerPlugin(md => {
+      const oldRule = md.renderer.rules.image;
+      md.renderer.rules.image = function(tokens, idx, options, env, slf) {
+        const token = tokens[idx];
+        const scaleIndex = token.attrIndex("scale");
+        const imageIndex = token.attrIndex("index-image");
+        if (scaleIndex !== -1) {
+          var selectedScale = token.attrs[scaleIndex][1];
+          var index = token.attrs[imageIndex][1];
+          let result = "<span class='image-wrapper'>";
+          result += oldRule(tokens, idx, options, env, slf);
+          result +=
+            "<span class='button-wrapper' data-image-index='" + index + "'>";
+          result += SCALES.map(scale =>
+            buildScaleButton(selectedScale, scale)
+          ).join("<span class='separator'>&nbsp;•&nbsp;</span>");
+          result += "</span></span>";
+          return result;
+        } else {
+          return oldRule(tokens, idx, options, env, slf);
       md.core.ruler.after("upload-protocol", "resize-controls", rule);
GitHub sha: 64ec771d
This commit appears in #9393 which was approved by udan11 and udan11. It was merged by romanrizzi.
