REFACTOR: Use keyword argument for fallback_to_english flag
diff --git a/app/models/translation_override.rb b/app/models/translation_override.rb
index 52b959a..a2eeb1b 100644
--- a/app/models/translation_override.rb
+++ b/app/models/translation_override.rb
@@ -21,7 +21,7 @@ class TranslationOverride < ActiveRecord::Base
     data = { value: value }
     if key.end_with?('_MF')
-      _, filename = JsLocaleHelper.find_message_format_locale([locale], false)
+      _, filename = JsLocaleHelper.find_message_format_locale([locale], fallback_to_english: false)
       data[:compiled_js] = JsLocaleHelper.compile_message_format(filename, locale, value)
diff --git a/lib/i18n/locale_file_checker.rb b/lib/i18n/locale_file_checker.rb
index b9aa206..54b27d9 100644
--- a/lib/i18n/locale_file_checker.rb
+++ b/lib/i18n/locale_file_checker.rb
@@ -112,7 +112,7 @@ class LocaleFileChecker
   def check_message_format
-    mf_locale, mf_filename = JsLocaleHelper.find_message_format_locale([@locale], true)
+    mf_locale, mf_filename = JsLocaleHelper.find_message_format_locale([@locale], fallback_to_english: true)
     traverse_hash(@locale_yaml, []) do |keys, value|
       next unless keys.last.ends_with?("_MF")
diff --git a/lib/js_locale_helper.rb b/lib/js_locale_helper.rb
index 4e0cbc4..22fe03b 100644
--- a/lib/js_locale_helper.rb
+++ b/lib/js_locale_helper.rb
@@ -137,7 +137,7 @@ module JsLocaleHelper
     message_formats = strip_out_message_formats!(translations[locale_str]['js'])
     message_formats.merge!(strip_out_message_formats!(translations[locale_str]['admin_js']))
-    mf_locale, mf_filename = find_message_format_locale([locale_str], true)
+    mf_locale, mf_filename = find_message_format_locale([locale_str], fallback_to_english: true)
     result = generate_message_format(message_formats, mf_locale, mf_filename)
     translations.keys.each do |l|
@@ -167,15 +167,15 @@ module JsLocaleHelper
     # moment.js uses a different naming scheme for locale files
     locale_chain = locale_chain.map { |l| l.tr('_', '-').downcase }
-    find_locale(locale_chain, path, :moment_js, false)
+    find_locale(locale_chain, path, :moment_js, fallback_to_english: false)
-  def self.find_message_format_locale(locale_chain, fallback_to_english)
+  def self.find_message_format_locale(locale_chain, fallback_to_english:)
     path = "#{Rails.root}/lib/javascripts/locale"
-    find_locale(locale_chain, path, :message_format, fallback_to_english)
+    find_locale(locale_chain, path, :message_format, fallback_to_english: fallback_to_english)
-  def self.find_locale(locale_chain, path, type, fallback_to_english)
+  def self.find_locale(locale_chain, path, type, fallback_to_english:)
     locale_chain.each do |locale|
       plugin_locale = DiscoursePluginRegistry.locales[locale]
       return plugin_locale[type] if plugin_locale&.has_key?(type)
@@ -188,7 +188,7 @@ module JsLocaleHelper
     locale_chain = locale_chain.map { |l| l.split(/[-_]/)[0] }
       .uniq.reject { |l| locale_chain.include?(l) }
     unless locale_chain.empty?
-      locale_data = find_locale(locale_chain, path, type, false)
+      locale_data = find_locale(locale_chain, path, type, fallback_to_english: false)
       return locale_data if locale_data
diff --git a/lib/plugin/instance.rb b/lib/plugin/instance.rb
index 53552d0..940cc90 100644
--- a/lib/plugin/instance.rb
+++ b/lib/plugin/instance.rb
@@ -632,7 +632,7 @@ class Plugin::Instance
       path = File.join(lib_locale_path, "message_format")
       opts[:message_format] = find_locale_file(locale_chain, path)
-      opts[:message_format] = JsLocaleHelper.find_message_format_locale(locale_chain, false) unless opts[:message_format]
+      opts[:message_format] = JsLocaleHelper.find_message_format_locale(locale_chain, fallback_to_english: false) unless opts[:message_format]
       path = File.join(lib_locale_path, "moment_js")
       opts[:moment_js] = find_locale_file(locale_chain, path)
GitHub sha: 84c56e16
