Remove extremely confusing spec involving too many doubles
We should never use “double” in specs on mini profiler, it is fragile
confusing and had a tiny test surface.
Instead test the actual behavior of classes
From 18640ac1d9d196d0c6ebfbf3357e7a5ae6a5658a Mon Sep 17 00:00:00 2001
Date: Mon, 10 Dec 2018 14:22:18 +1100
Subject: [PATCH] Remove extremely confusing spec involving too many doubles
We should never use "double" in specs on mini profiler, it is fragile
diff --git a/lib/mini_profiler/storage/memory_store.rb b/lib/mini_profiler/storage/memory_store.rb
index 5d741ba..6a4936f 100644
--- a/lib/mini_profiler/storage/memory_store.rb
+++ b/lib/mini_profiler/storage/memory_store.rb
@@ -71,7 +71,7 @@ module Rack
         cleanup_cycle    = args.fetch(:cleanup_cycle)    { CLEANUP_CYCLE }
         t = CacheCleanupThread.new(cleanup_interval, cleanup_cycle, self) do
           until Thread.current[:should_exit] do
-            CacheCleanupThread.current.sleepy_run
+            t.sleepy_run
         at_exit { t[:should_exit] = true }
diff --git a/spec/lib/storage/memory_store_spec.rb b/spec/lib/storage/memory_store_spec.rb
index cc2ce77..bfcef2a 100644
--- a/spec/lib/storage/memory_store_spec.rb
+++ b/spec/lib/storage/memory_store_spec.rb
@@ -83,56 +83,4 @@ describe Rack::MiniProfiler::MemoryStore do
-  describe 'cache cleanup thread' do
-    let(:described) { Rack::MiniProfiler::MemoryStore::CacheCleanupThread }
-    before do
-      store = double()
-      allow(store).to receive(:cleanup_cache)
-      @cleaner = described.new(1, 2, store) do
-        self.sleepy_run
-      end
-    end
-    it "just run on start" do
-      expect(@cleaner.should_cleanup?).to eq(false)
-    end
-    it "when number of runs * interval gets bigger than cycle, it should cleanup" do
-      @cleaner.increment_cycle
-      expect(@cleaner.should_cleanup?).to eq(true)
-    end
-    describe 'cleanup' do
-      before do
-        store = double()
-        expect(store).to receive(:cleanup_cache) { true }
-          self.sleepy_run
-        end
-      end
-      it "calls store" do
-        @cleaner.cleanup
-      end
-      it "resets counter" do
-        expect(@cleaner.cycle_count).to eq(2)
-        @cleaner.cleanup
-        expect(@cleaner.cycle_count).to eq(1)
-      end
-    end
-    describe 'sleepy_run' do
-      before do
-        store = double()
-        @cleaner = described.new(0, 0, store) do
-          self.sleepy_run
-        end
-      end
-      it "works" do
-        @cleaner.sleepy_run
-      end
-    end
-  end
GitHub
