Remove focus from specs
diff --git a/spec/components/discourse_diff_spec.rb b/spec/components/discourse_diff_spec.rb
index d1158aef20..d8683decc8 100644
--- a/spec/components/discourse_diff_spec.rb
+++ b/spec/components/discourse_diff_spec.rb
@@ -76,7 +76,7 @@ describe DiscourseDiff do
       expect(DiscourseDiff.new(before, after).side_by_side_html).to eq("<div class=\"revision-content\"><p>this is a paragraph</p></div><div class=\"revision-content\"><p>this is a <ins>great </ins>paragraph</p></div>")
-    it "adds <ins> and <del> tags on consecutive paragraphs", :focus do
+    it "adds <ins> and <del> tags on consecutive paragraphs" do
       before = "<p>this is one paragraph</p><p>here is yet another</p>"
       after = "<p>this is one great paragraph</p><p>here is another</p>"
       got = DiscourseDiff.new(before, after).side_by_side_html
diff --git a/spec/components/onpdiff_spec.rb b/spec/components/onpdiff_spec.rb
index 60b4039720..f59bd80cb0 100644
--- a/spec/components/onpdiff_spec.rb
+++ b/spec/components/onpdiff_spec.rb
@@ -49,7 +49,7 @@ describe ONPDiff do
       expect(ONPDiff.new("abc", "acd").paragraph_diff).to eq([["a", :common], ["b", :delete], ["c", :common], ["d", :add]])
-    it "pairs as many elements as possible", :focus do
+    it "pairs as many elements as possible" do
       expect(ONPDiff.new("abcd", "abef").paragraph_diff).to eq([
         ["a", :common], ["b", :common],
         ["e", :add], ["c", :delete],
GitHub sha: 61f6a6e8
