Remove Internet Explorer reference (#14879)
Discourse no longer supports Internet Explorer, so we can remove the IE-specific warning in this site setting description.
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index e9d26ed..6249277 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -2165,7 +2165,7 @@ en:
     warn_reviving_old_topic_age: "When someone starts replying to a topic where the last reply is older than this many days, a warning will be displayed. Disable by setting to 0."
     autohighlight_all_code: "Force apply code highlighting to all preformatted code blocks even when they didn't explicitly specify the language."
     highlighted_languages: "Included syntax highlighting rules. (Warning: including too many languages may impact performance) see: <a href='https://highlightjs.org/static/demo/' target='_blank'>https://highlightjs.org/static/demo</a> for a demo"
-    show_copy_button_on_codeblocks: "Add a button to codeblocks to copy the block contents to the user's clipboard. This feature is not supported on Internet Explorer."
+    show_copy_button_on_codeblocks: "Add a button to codeblocks to copy the block contents to the user's clipboard."
     embed_any_origin: "Allow embeddable content regardless of origin. This is required for mobile apps with static HTML."
     embed_topics_list: "Support HTML embedding of topics lists"
GitHub sha: 5467bfb7d649808fe298aed819e0f8e4728fd77b
This commit appears in #14879 which was approved by tgxworld. It was merged by tgxworld.
