Remove jQuery (#399)
  • Remove jQuery dependency
  • Replace jQuery templating library with doT.js
  • Remove Mousetrap
  • Convert X-MiniProfiler-Ids header to comma separated
diff --git a/Rakefile b/Rakefile
index 42ef68c..f5e3265 100644
--- a/Rakefile
+++ b/Rakefile
@@ -24,7 +24,10 @@ end
 desc "compile sass"
 task compile_sass: :copy_files do
-  `sass lib/html/includes.scss > lib/html/includes.css`
+  require "sassc"
+  scss = File.read("lib/html/includes.scss")
+  css = SassC::Engine.new(scss).render
+  File.write("lib/html/includes.css", css)
 desc "update asset version file"
diff --git a/lib/html/dot.1.1.2.min.js b/lib/html/dot.1.1.2.min.js
new file mode 100644
index 0000000..245d000
--- /dev/null
+++ b/lib/html/dot.1.1.2.min.js
@@ -0,0 +1,2 @@
+/* Laura Doktorova https://github.com/olado/doT */
+!function(){"use strict";function e(n,t,r){return("string"==typeof t?t:t.toString()).replace(n.define||a,function(e,t,o,a){return 0===t.indexOf("def.")&&(t=t.substring(4)),t in r||(":"===o?(n.defineParams&&a.replace(n.defineParams,function(e,n,o){r[t]={arg:n,text:o}}),t in r||(r[t]=a)):new Function("def","def['"+t+"']="+a)(r)),""}).replace(n.use||a,function(t,o){n.useParams&&(o=o.replace(n.useParams,function(e,n,t,o){if(r[t]&&r[t].arg&&o){var a=(t+":"+o).replace(/'|\\/g,"_");return r.__exp=r.__exp||{},r.__exp[a]=r[t].text.replace(new RegExp("(^|[^\\w$])"+r[t].arg+"([^\\w$])","g"),"$1"+o+"$2"),n+"def.__exp['"+a+"']"}}));var a=new Function("def","return "+o)(r);return a?e(n,a,r):a})}function n(e){return e.replace(/\\('|\\)/g,"$1").replace(/[\r\t\n]/g," ")}var t,r={engine:"doT",version:"1.1.1",templateSettings:{evaluate:/\{\{([\s\S]+?(\}?)+)\}\}/g,interpolate:/\{\{=([\s\S]+?)\}\}/g,encode:/\{\{!([\s\S]+?)\}\}/g,use:/\{\{#([\s\S]+?)\}\}/g,useParams:/(^|[^\w$])def(?:\.|\[[\'\"])([\w$\.]+)(?:[\'\"]\])?\s*\:\s*([\w$\.]+|\"[^\"]+\"|\'[^\']+\'|\{[^\}]+\})/g,define:/\{\{##\s*([\w\.$]+)\s*(\:|=)([\s\S]+?)#\}\}/g,defineParams:/^\s*([\w$]+):([\s\S]+)/,conditional:/\{\{\?(\?)?\s*([\s\S]*?)\s*\}\}/g,iterate:/\{\{~\s*(?:\}\}|([\s\S]+?)\s*\:\s*([\w$]+)\s*(?:\:\s*([\w$]+))?\s*\}\})/g,varname:"it",strip:!0,append:!0,selfcontained:!1,doNotSkipEncoded:!1},template:void 0,compile:void 0,log:!0};r.encodeHTMLSource=function(e){var n={"&":"&#38;","<":"&#60;",">":"&#62;",'"':"&#34;","'":"&#39;","/":"&#47;"},t=e?/[&<>"'\/]/g:/&(?!#?\w+;)|<|>|"|'|\//g;return function(e){return e?e.toString().replace(t,function(e){return n[e]||e}):""}},t=function(){return this||(0,eval)("this")}(),"undefined"!=typeof module&&module.exports?module.exports=r:"function"==typeof define&&define.amd?define(function(){return r}):t.doT=r;var o={append:{start:"'+(",end:")+'",startencode:"'+encodeHTML("},split:{start:"';out+=(",end:");out+='",startencode:"';out+=encodeHTML("}},a=/$^/;r.template=function(c,i,u){i=i||r.templateSettings;var d,s,p=i.append?o.append:o.split,l=0,f=i.use||i.define?e(i,c,u||{}):c;f=("var out='"+(i.strip?f.replace(/(^|\r|\n)\t* +| +\t*(\r|\n|$)/g," ").replace(/\r|\n|\t|\/\*[\s\S]*?\*\//g,""):f).replace(/'|\\/g,"\\$&").replace(i.interpolate||a,function(e,t){return p.start+n(t)+p.end}).replace(i.encode||a,function(e,t){return d=!0,p.startencode+n(t)+p.end}).replace(i.conditional||a,function(e,t,r){return t?r?"';}else if("+n(r)+"){out+='":"';}else{out+='":r?"';if("+n(r)+"){out+='":"';}out+='"}).replace(i.iterate||a,function(e,t,r,o){return t?(l+=1,s=o||"i"+l,t=n(t),"';var arr"+l+"="+t+";if(arr"+l+"){var "+r+","+s+"=-1,l"+l+"=arr"+l+".length-1;while("+s+"<l"+l+"){"+r+"=arr"+l+"["+s+"+=1];out+='"):"';} } out+='"}).replace(i.evaluate||a,function(e,t){return"';"+n(t)+"out+='"})+"';return out;").replace(/\n/g,"\\n").replace(/\t/g,"\\t").replace(/\r/g,"\\r").replace(/(\s|;|\}|^|\{)out\+='';/g,"$1").replace(/\+''/g,""),d&&(i.selfcontained||!t||t._encodeHTML||(t._encodeHTML=r.encodeHTMLSource(i.doNotSkipEncoded)),f="var encodeHTML = typeof _encodeHTML !== 'undefined' ? _encodeHTML : ("+r.encodeHTMLSource.toString()+"("+(i.doNotSkipEncoded||"")+"));"+f);try{return new Function(i.varname,f)}catch(e){throw"undefined"!=typeof console&&console.log("Could not create a template function: "+f),e}},r.compile=function(e,n){return r.template(e,null,n)}}();
diff --git a/lib/html/includes.css b/lib/html/includes.css
index b1f7587..3b28358 100644
--- a/lib/html/includes.css
+++ b/lib/html/includes.css
@@ -1,9 +1,29 @@
 @charset "UTF-8";
-.profiler-result, .profiler-queries {
+.profiler-result,
+.profiler-queries {
   color: #555;
   line-height: 1;
   font-size: 12px; }
-  .profiler-result pre, .profiler-result code, .profiler-result label, .profiler-result table, .profiler-result tbody, .profiler-result thead, .profiler-result tfoot, .profiler-result tr, .profiler-result th, .profiler-result td, .profiler-queries pre, .profiler-queries code, .profiler-queries label, .profiler-queries table, .profiler-queries tbody, .profiler-queries thead, .profiler-queries tfoot, .profiler-queries tr, .profiler-queries th, .profiler-queries td {
+  .profiler-result pre,
+  .profiler-result code,
+  .profiler-result label,
+  .profiler-result table,
+  .profiler-result tbody,
+  .profiler-result thead,
+  .profiler-result tfoot,
+  .profiler-result tr,
+  .profiler-result th,
+  .profiler-result td,
+  .profiler-queries pre,
+  .profiler-queries code,
+  .profiler-queries label,
+  .profiler-queries table,
+  .profiler-queries tbody,
+  .profiler-queries thead,
+  .profiler-queries tfoot,
+  .profiler-queries tr,
+  .profiler-queries th,
+  .profiler-queries td {
     margin: 0;
     padding: 0;
     border: 0;
@@ -13,15 +33,21 @@
     background-color: transparent;
     overflow: visible;
     max-height: none; }
-  .profiler-result table, .profiler-queries table {
+  .profiler-queries table {
     border-collapse: collapse;
     border-spacing: 0; }
-  .profiler-result a, .profiler-result a:hover, .profiler-queries a, .profiler-queries a:hover {
+  .profiler-result a,
+  .profiler-result a:hover,
+  .profiler-queries a,
+  .profiler-queries a:hover {
     cursor: pointer;
-    color: #0077CC; }
-  .profiler-result a, .profiler-queries a {
+    color: #0077cc; }
+  .profiler-queries a {
     text-decoration: none; }
-    .profiler-result a:hover, .profiler-queries a:hover {
       text-decoration: underline; }
 .profiler-result {
@@ -38,9 +64,13 @@
     color: #767676; }
   .profiler-result .profiler-trivial {
     display: none; }
-    .profiler-result .profiler-trivial td, .profiler-result .profiler-trivial td * {
+    .profiler-result .profiler-trivial td,
+    .profiler-result .profiler-trivial td * {
       color: #767676 !important; }
-  .profiler-result pre, .profiler-result code, .profiler-result .profiler-number, .profiler-result .profiler-unit {
+  .profiler-result .profiler-number,
+  .profiler-result .profiler-unit {
     font-family: Consolas, monospace, serif; }
   .profiler-result .profiler-number {
     color: #111; }
@@ -54,7 +84,8 @@
     background-color: #fff;
     color: #767676;
     text-align: right; }
-  .profiler-result .profiler-timings th, .profiler-result .profiler-timings td {
+  .profiler-result .profiler-timings th,
+  .profiler-result .profiler-timings td {
     white-space: nowrap; }
   .profiler-result .profiler-timings .profiler-duration-with-children {
     display: none; }
@@ -63,8 +94,9 @@
   .profiler-result .profiler-timings .profiler-indent {
     letter-spacing: 4px; }
-  .profiler-result .profiler-timings .profiler-queries-show .profiler-number, .profiler-result .profiler-timings .profiler-queries-show .profiler-unit {
-    color: #0077CC; }
+  .profiler-result .profiler-timings .profiler-queries-show .profiler-number,
+  .profiler-result .profiler-timings .profiler-queries-show .profiler-unit {
+    color: #0077cc; }
   .profiler-result .profiler-timings .profiler-queries-duration {
     padding-left: 6px; }
   .profiler-result .profiler-timings .profiler-percent-in-sql {
@@ -89,13 +121,15 @@
     .profiler-result .profiler-queries tbody tr {
GitHub sha: 71417bee
