Remove old build script
From 208e5ee5469e465f05ebff9cc41096e4accbcef3 Mon Sep 17 00:00:00 2001
Date: Fri, 17 Aug 2018 17:08:14 -0300
Subject: [PATCH] Remove old build script
diff --git a/image/build.rb b/image/build.rb
deleted file mode 100644
index 8568375..0000000
--- a/image/build.rb
+++ /dev/null
@@ -1,100 +0,0 @@
-# simple build file to be used locally by Sam
-require 'pty'
-require 'optparse'
-def run(command)
-  lines = []
-  PTY.spawn(command) do |stdin, stdout, pid|
-    begin
-      stdin.each do |line|
-        lines << line
-        puts line
-      end
-    rescue Errno::EIO
-      # we are done
-    end
-  end
-  lines
-end
-def ensure_docker_squash
-  docker_squash = "https://github.com/goldmann/docker-squash/archive/master.zip"
-  run ("apt install python-pip")
-  run ("pip install '#{docker_squash}' --upgrade")
-end
-def build(image)
-  lines = run("cd #{image[:name]} && docker build .")
-  img = lines[-1]["successfully built ".length..-1].strip
-  if image[:squash]
-    if image[:layers_to_keep] == nil
-      run("docker-squash -t #{image[:tag]} --cleanup --verbose #{img}")
-    else
-      layers_to_squash = run("docker history #{img} | wc -l").first.to_i - (1 + image[:layers_to_keep])
-      run("docker-squash -t #{image[:tag]} --cleanup --verbose -f #{layers_to_squash} #{img}")
-    end
-    run("docker rmi #{img}")
-  else
-    run("docker tag #{img} #{image[:tag]}")
-  end
-end
-def bump(image, image_version)
-  run("echo #{image_version} > base/VERSION") if image == 'base'
-  run("sed -i '' -e 's/^\(# NAME:\).*$$/\1     discourse\/#{image}/' #{image}/Dockerfile")
-  run("sed -i '' -e 's/^\(# VERSION:\).*$$/\1  #{image_version}/' #{image}/Dockerfile")
-  run("sed -i '' -e 's/^\(FROM discourse\/[^:]*:\).*/\1#{image_version}/' #{image}/Dockerfile")
-end
-def dev_deps()
-  run("sed -e 's/\(db_name: discourse\)/\1_development/' ../templates/postgres.template.yml > discourse_dev/postgres.template.yml")
-  run("cp ../templates/redis.template.yml discourse_dev/redis.template.yml")
-end
-options = {}
-OptionParser.new do |parser|
-  parser.on("-i", "--image image",
-            "Build the image. No parameter means [base discourse discourse_test].") do |i|
-    options[:image] = [i.to_sym]
-  end
-  parser.on("-b", "--bump version",
-            "Bumps the version in the Dockerfiles specified by --image") do |v|
-    options[:version] = [v]
-  end
-end.parse!
-DEFAULT_IMAGES = %i[base discourse discourse_test discourse_dev discourse_bench]
-todo = options[:image] || DEFAULT_IMAGES
-version = options[:version] || '1.4.0'
-if ENV["USER"] != "root"
-  STDERR.puts "Build script must be ran as root due to docker-squash"
-  exit 1
-end
-ensure_docker_squash
-images = {
-  base: { name: 'base', tag: "discourse/base:#{version}", squash: true },
-  discourse: { name: 'discourse', tag: "discourse/discourse:#{version}", squash: true, layers_to_keep: 1 },
-  discourse_test: { name: 'discourse_test', tag: "discourse/discourse_test:#{version}", squash: true, layers_to_keep: 2 },
-  discourse_dev: { name: 'discourse_dev', tag: "discourse/discourse_dev:#{version}", squash: false },
-  discourse_bench: { name: 'discourse_bench', tag: "discourse/discourse_bench:#{version}", squash: false }
-todo.each do |image|
-  puts images[image]
-  bump(images[image][:name], options[:version]) if options[:version]
-  dev_deps() if image == :discourse_dev
-  build(images[image])
-end
GitHub
