remove rubocop.yml
remove rubocop.yml
diff --git a/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml b/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
deleted file mode 100644
index 0cb02e3..0000000
--- a/.rubocop-https---raw-githubusercontent-com-discourse-discourse-master--rubocop-yml
+++ /dev/null
@@ -1,357 +0,0 @@
-require:
-  - rubocop-discourse
-  - rubocop-rspec
-AllCops:
-  TargetRubyVersion: 2.6
-  DisabledByDefault: true
-  Exclude:
-    - "db/schema.rb"
-    - "bundle/**/*"
-    - "vendor/**/*"
-    - "node_modules/**/*"
-    - "public/**/*"
-    - "plugins/**/gems/**/*"
-Discourse:
-  Enabled: true
-Discourse/NoChdir:
-  Exclude:
-    - 'spec/**/*' # Specs are run sequentially, so chdir can be used
-    - 'plugins/*/spec/**/*'
-# Prefer &&/|| over and/or.
-Style/AndOr:
-  Enabled: true
-Style/FrozenStringLiteralComment:
-  Enabled: true
-# Align `when` with `case`.
-Layout/CaseIndentation:
-  Enabled: true
-# Align comments with method definitions.
-Layout/CommentIndentation:
-  Enabled: true
-# No extra empty lines.
-Layout/EmptyLines:
-  Enabled: true
-# Use Ruby >= 1.9 syntax for hashes. Prefer { a: :b } over { :a => :b }.
-Style/HashSyntax:
-  Enabled: true
-# Two spaces, no tabs (for indentation).
-Layout/IndentationWidth:
-  Enabled: true
-Layout/SpaceAfterColon:
-  Enabled: true
-Layout/SpaceAfterComma:
-  Enabled: true
-Layout/SpaceAroundEqualsInParameterDefault:
-  Enabled: true
-Layout/SpaceAroundKeyword:
-  Enabled: true
-Layout/SpaceAroundOperators:
-  Enabled: true
-Layout/SpaceBeforeFirstArg:
-  Enabled: true
-# Defining a method with parameters needs parentheses.
-Style/MethodDefParentheses:
-  Enabled: true
-# Use `foo {}` not `foo{}`.
-Layout/SpaceBeforeBlockBraces:
-  Enabled: true
-# Use `foo { bar }` not `foo {bar}`.
-Layout/SpaceInsideBlockBraces:
-  Enabled: true
-# Use `{ a: 1 }` not `{a:1}`.
-Layout/SpaceInsideHashLiteralBraces:
-  Enabled: true
-Layout/SpaceInsideParens:
-  Enabled: true
-# Detect hard tabs, no hard tabs.
-Layout/IndentationStyle:
-  Enabled: true
-# Blank lines should not have any spaces.
-Layout/TrailingEmptyLines:
-  Enabled: true
-# No trailing whitespace.
-Layout/TrailingWhitespace:
-  Enabled: true
-Lint/Debugger:
-  Enabled: true
-Layout/BlockAlignment:
-  Enabled: true
-# Align `end` with the matching keyword or starting expression except for
-# assignments, where it should be aligned with the LHS.
-Layout/EndAlignment:
-  Enabled: true
-  EnforcedStyleAlignWith: variable
-# Use my_method(my_arg) not my_method( my_arg ) or my_method my_arg.
-Lint/RequireParentheses:
-  Enabled: true
-Lint/ShadowingOuterLocalVariable:
-  Enabled: true
-Layout/MultilineMethodCallIndentation:
-  Enabled: true
-  EnforcedStyle: indented
-Layout/HashAlignment:
-  Enabled: true
-Bundler/OrderedGems:
-  Enabled: false
-Style/SingleLineMethods:
-  Enabled: true
-Style/Semicolon:
-  Enabled: true
-  AllowAsExpressionSeparator: true
-Style/RedundantReturn:
-  Enabled: true
-Style/GlobalVars:
-  Enabled: true
-  Severity: warning
-  Exclude:
-    - 'lib/tasks/**/*'
-    - 'script/**/*'
-    - 'spec/**/*.rb'
-# Specs
-RSpec/AnyInstance:
-  Enabled: false # To be decided
-RSpec/AroundBlock:
-  Enabled: true
-RSpec/BeforeAfterAll:
-RSpec/ContextMethod:
-  Enabled: false # TODO
-RSpec/ContextWording:
-RSpec/DescribeClass:
-RSpec/DescribeMethod:
-  Enabled: true
-RSpec/DescribeSymbol:
-RSpec/DescribedClass:
-RSpec/DescribedClassModuleWrapping:
-RSpec/EmptyExampleGroup:
-  Enabled: true
-  Exclude:
-    - 'spec/requests/api/*'
-RSpec/EmptyLineAfterExample:
-RSpec/EmptyLineAfterExampleGroup:
-RSpec/EmptyLineAfterFinalLet:
-RSpec/EmptyLineAfterHook:
-RSpec/EmptyLineAfterSubject:
-RSpec/ExampleLength:
-RSpec/ExampleWithoutDescription:
-  Enabled: true
-RSpec/ExampleWording:
-RSpec/ExpectActual:
-  Enabled: true
-RSpec/ExpectChange:
-RSpec/ExpectInHook:
-RSpec/ExpectOutput:
-  Enabled: true
-RSpec/FilePath:
-RSpec/Focus:
-  Enabled: true
-RSpec/HookArgument:
-RSpec/HooksBeforeExamples:
-RSpec/ImplicitBlockExpectation:
-  Enabled: true
-RSpec/ImplicitExpect:
-RSpec/ImplicitSubject:
-RSpec/InstanceSpy:
-  Enabled: true
-RSpec/InstanceVariable:
-RSpec/InvalidPredicateMatcher:
-  Enabled: true
-RSpec/ItBehavesLike:
-  Enabled: true
-RSpec/IteratedExpectation:
-RSpec/LeadingSubject:
-RSpec/LeakyConstantDeclaration:
-RSpec/LetBeforeExamples:
-RSpec/LetSetup:
-RSpec/MessageChain:
-  Enabled: true
-RSpec/MessageSpies:
-  Enabled: true
-RSpec/MissingExampleGroupArgument:
-  Enabled: true
-RSpec/MultipleDescribes:
-RSpec/MultipleSubjects:
-  Enabled: true
-RSpec/NamedSubject:
-RSpec/NestedGroups:
-RSpec/OverwritingSetup:
-  Enabled: true
-RSpec/ReceiveCounts:
-  Enabled: true
-RSpec/ReceiveNever:
-  Enabled: true
-RSpec/RepeatedDescription:
-RSpec/RepeatedExample:
-RSpec/RepeatedExampleGroupBody:
-RSpec/RepeatedExampleGroupDescription:
-RSpec/ReturnFromStub:
-  Enabled: true
-RSpec/ScatteredSetup:
-RSpec/SharedContext:
-  Enabled: true
-RSpec/SharedExamples:
-  Enabled: true
-RSpec/SingleArgumentMessageChain:
-  Enabled: true
-RSpec/SubjectStub:
-  Enabled: true
-RSpec/UnspecifiedException:
-  Enabled: true
-RSpec/VerifiedDoubles:
-  Enabled: true
-RSpec/VoidExpect:
-  Enabled: true
-RSpec/Yield:
-  Enabled: true
-Capybara/CurrentPathExpectation:
-  Enabled: true
-Capybara/FeatureMethods:
-  Enabled: true
-FactoryBot/AttributeDefinedStatically:
-  Enabled: true
-FactoryBot/CreateList:
-  Enabled: true
-FactoryBot/FactoryClassName:
-  Enabled: true
-Rails/HttpStatus:
-  Enabled: true
GitHub sha: e5bba1a7
