Remove unused translations
The migration for the ToS signup field happend in 2014. Everyone who hasn’t updated yet needs to live with the English text “Terms of Service”. There’s no need to keep these unused translations forever.
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index b92d635..3cd45e9 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -3496,10 +3496,6 @@ en:
       ## [Welcome to %{title}](#welcome)
       An account is required. Please ask an existing member for an invite or log in to continue.
-  terms_of_service:
-    title: "Terms of Service"
-    signup_form_message: 'I have read and accept the <a href="%{base_path}/tos" target="_blank">Terms of Service</a>.'
   deleted: "deleted"
   image: "image"
diff --git a/db/migrate/20140929204155_migrate_tos_setting.rb b/db/migrate/20140929204155_migrate_tos_setting.rb
index 66cf689..3ee0ccb 100644
--- a/db/migrate/20140929204155_migrate_tos_setting.rb
+++ b/db/migrate/20140929204155_migrate_tos_setting.rb
@@ -4,11 +4,7 @@ class MigrateTosSetting < ActiveRecord::Migration[4.2]
   def up
     res = execute("SELECT * FROM site_settings WHERE name = 'tos_accept_required' AND value = 't'")
     if res.present? && res.cmd_tuples > 0
-      label = nil
-      I18n.overrides_disabled do
-        label = I18n.t("terms_of_service.signup_form_message", base_path: "")
-      end
+      label = 'Terms of Service'
       res = execute("SELECT value FROM site_texts WHERE text_type = 'tos_signup_form_message'")
       if res.present? && res.cmd_tuples == 1
diff --git a/db/migrate/20141014191645_fix_tos_name.rb b/db/migrate/20141014191645_fix_tos_name.rb
index 7186b51..b9e38f8 100644
--- a/db/migrate/20141014191645_fix_tos_name.rb
+++ b/db/migrate/20141014191645_fix_tos_name.rb
@@ -2,9 +2,10 @@
 class FixTosName < ActiveRecord::Migration[4.2]
   def up
-      execute DB.sql_fragment('UPDATE user_fields SET name = ? WHERE name = ?', I18n.t('terms_of_service.title'), I18n.t("terms_of_service.signup_form_message", base_path: ""))
-    end
+    execute <<~SQL
+      UPDATE user_fields
+      SET name = 'Terms of Service'
+      WHERE name = 'I have read and accept the <a href="/tos" target="_blank">Terms of Service</a>.'
+    SQL
GitHub sha: 98a17edc
