Removing unused bootstrap.scss file
diff --git a/app/assets/stylesheets/vendor/bootstrap.scss b/app/assets/stylesheets/vendor/bootstrap.scss
deleted file mode 100644
index 6ca0cac..0000000
--- a/app/assets/stylesheets/vendor/bootstrap.scss
+++ /dev/null
@@ -1,700 +0,0 @@
- * Bootstrap v2.0.4
- * Copyright 2012 Twitter, Inc
- * Licensed under the Apache License v2.0
- * http://www.apache.org/licenses/LICENSE-2.0
- * Designed and built with all the love in the world @twitter by @mdo and @fat.
- * NOTE: THIS IS NOT A CLEAN VERSION OF BOOTSTRAP. As we work toward removing the
- * default theme's dependency on Bootstrap, we are deleting code from here that is
- * no longer required.
- @import "common/foundation/mixins";
-//noinspection CssOverwrittenProperties
-a:focus {
-  outline: thin dotted #333;
-  outline: 5px auto -webkit-focus-ring-color;
-  outline-offset: -2px;
-img {
-  max-width: 100%;
-.row {
-  margin-left: -12px;
-.row:before,
-.row:after {
-  display: table;
-  content: "";
-.row:after {
-  clear: both;
-[class*="span"] {
-  float: left;
-  margin-left: 12px;
-.span24 {
-  width: 1236px;
-.span15 {
-  width: 768px;
-.span13 {
-  width: 664px;
-.span10 {
-  width: 508px;
-.span8 {
-  width: 404px;
-.span6 {
-  width: 300px;
-.span4 {
-  width: 196px;
-.offset2 {
-  margin-left: 116px;
-.offset1 {
-  margin-left: 64px;
-button.btn::-moz-focus-inner,
-input[type="submit"].btn::-moz-focus-inner {
-  padding: 0;
-  border: 0;
-.btn-group {
-  position: relative;
-.btn-group:before,
-.btn-group:after {
-  display: table;
-  content: " ";
-.btn-group:after {
-  clear: both;
-.btn-group + .btn-group {
-  margin-left: 5px;
-.btn-group > .btn {
-  float: left;
-.btn-group > .btn:hover,
-.btn-group > .btn:focus,
-.btn-group > .btn:active,
-.btn-group > .btn.active {
-  z-index: 2;
-.btn-group .dropdown-toggle:active,
-.btn-group.open .dropdown-toggle {
-  outline: 0;
-.dropdown {
-.dropdown-toggle:active,
-.open .dropdown-toggle {
-  outline: 0;
-.caret {
-  display: inline-block;
-  width: 0;
-  height: 0;
-  vertical-align: middle;
-  border-top: 4px solid #000000;
-  border-right: 4px solid transparent;
-  border-left: 4px solid transparent;
-  content: "";
-.dropdown-menu {
-  position: absolute;
-  top: 100%;
-  left: 0;
-  z-index: 1000;
-  display: none;
-  float: left;
-  min-width: 160px;
-  padding: 4px 0;
-  margin: 1px 0 0;
-  list-style: none;
-  background-color: #ffffff;
-  border: 1px solid rgba(0, 0, 0, 0.2);
-  border-radius: 5px;
-  box-shadow: 0 5px 10px rgba(0, 0, 0, 0.2);
-  background-clip: padding-box;
-.dropdown-menu a {
-  display: block;
-  padding: 3px 15px;
-  clear: both;
-  font-weight: normal;
-  line-height: 18px;
-  color: #333333;
-  white-space: nowrap;
-.dropdown-menu li > a:hover,
-.dropdown-menu .active > a,
-.dropdown-menu .active > a:hover {
-  color: #ffffff;
-  text-decoration: none;
-  background-color: #0088cc;
-.open > .dropdown-menu {
-  display: block;
-.fade {
-  opacity: 0;
-  transition: opacity 0.15s linear;
-.fade.in {
-  opacity: 1;
-body {
-  input, textarea, select {
-    color: #222222;
-  p, pre, li, ul {
-    font-size: 1em;
-  p {
-    line-height: 20px;
-  code, pre {
-    font-family: Consolas, Menlo, Monaco, "Lucida Console", "Liberation Mono", "DejaVu Sans Mono", "Bitstream Vera Sans Mono", "Courier New", monospace, serif;
-  h1, h2, h3, h4, h5, h6 {
-    margin: 0;
-    font-family: inherit;
-    font-weight: bold;
-    color: inherit;
-  h1 {
-    font-size: 2.143em;
-    line-height: 36px;
-  h2 {
-    font-size: 1.7511em;
-  h3 {
-    font-size: 1.3195em;
-    line-height: 27px;
-  h4, h5, h6 {
-  h4 {
-    font-size: 1em;
-  h5 {
-    font-size: 0.857em;
-  h6 {
-    font-size: 11px;
-    color: #999999;
-  // this removes the unwanted top margin on a paragraph under a heading
-  h1+p, h2+p, h3+p, h4+p, h5+p, h6+p {
-    margin-top:0;
-  blockquote {
-    margin: 15px 0 8px;
-  li {
-  form {
-    margin: 0 0 18px;
-  label, input, button, select, textarea {
-    font-size: 0.929em;
-  input, button, select, textarea {
-    font-family: "Helvetica Neue", Helvetica, Arial, sans-serif;
-  label {
-    display: block;
-    margin-bottom: 5px;
-  select, textarea {
-    padding: 4px;
-    margin-bottom: 9px;
-    color: #555555;
-  input {
-    &[type="text"], &[type="password"], &[type="datetime"], &[type="datetime-local"], &[type="date"], &[type="month"], &[type="time"], &[type="week"], &[type="number"], &[type="email"], &[type="url"], &[type="search"], &[type="tel"], &[type="color"] {
-      height: 18px;
-      padding: 4px;
-      color: #555555;
-  input {
-    width: 210px;
-  textarea {
-    width: 210px;
-    height: auto;
-    background-color: white;
-    border: 1px solid #cccccc;
-    border-radius: 3px;
-    box-shadow: inset 0 1px 1px rgba(0, 0, 0, 0.075);
-    transition: border linear 0.2s, box-shadow linear 0.2s;
-  input {
-  textarea:focus {
-    border-color: rgba(82, 168, 236, 0.8);
-    outline: 0;
-    box-shadow: inset 0 1px 1px rgba(0, 0, 0, 0.075), 0 0 8px rgba(82, 168, 236, 0.6);
-  input {
-    &[type="text"]:focus, &[type="password"]:focus, &[type="datetime"]:focus, &[type="datetime-local"]:focus, &[type="date"]:focus, &[type="month"]:focus, &[type="time"]:focus, &[type="week"]:focus, &[type="number"]:focus, &[type="email"]:focus, &[type="url"]:focus, &[type="search"]:focus, &[type="tel"]:focus, &[type="color"]:focus {
-      outline: 0;
-  input {
-    &[type="radio"], &[type="checkbox"] {
-      margin: 3px 0;
-      line-height: normal;
-      cursor: pointer;
-    &[type="submit"], &[type="reset"], &[type="button"], &[type="radio"], &[type="checkbox"] {
-      width: auto;
-  select, input[type="file"] {
-    line-height: 28px;
-  select {
-    width: 220px;
-    border: 1px solid #bbbbbb;
-    &[multiple], &[size] {
-      height: auto;
-    &:focus {
-      outline: thin dotted #333333;
-  input {
-    &[type="file"]:focus, &[type="radio"]:focus, &[type="checkbox"]:focus {
-  .radio, .checkbox {
-    min-height: 18px;
-    padding-left: 18px;
-  .radio input[type="radio"], .checkbox input[type="checkbox"] {
-    float: left;
-    margin-left: -18px;
-  .controls > {
-    .radio:first-child, .checkbox:first-child {
-      padding-top: 5px;
-  .radio.inline, .checkbox.inline {
-    padding-top: 5px;
-    margin-bottom: 0;
-  .radio.inline .radio.inline, .checkbox.inline .checkbox.inline {
-    margin-left: 10px;
-  .input-xxlarge {
-    width: 530px;
GitHub sha: 9a594fed
Noice !
