Rename DiscourseChat to DiscourseChatIntegration (#82)
diff --git a/app/controllers/chat_controller.rb b/app/controllers/chat_controller.rb
index ca29495..fa1201d 100644
--- a/app/controllers/chat_controller.rb
+++ b/app/controllers/chat_controller.rb
@@ -1,14 +1,14 @@
 # frozen_string_literal: true
-class DiscourseChat::ChatController < ApplicationController
-  requires_plugin DiscourseChat::PLUGIN_NAME
+class DiscourseChatIntegration::ChatController < ApplicationController
+  requires_plugin DiscourseChatIntegration::PLUGIN_NAME
   def respond
     render
   def list_providers
-    providers = ::DiscourseChat::Provider.enabled_providers.map do |x|
+    providers = ::DiscourseChatIntegration::Provider.enabled_providers.map do |x|
@@ -24,11 +24,11 @@ class DiscourseChat::ChatController < ApplicationController
       channel_id = params[:channel_id].to_i
       topic_id = params[:topic_id].to_i
-      channel = DiscourseChat::Channel.find(channel_id)
+      channel = DiscourseChatIntegration::Channel.find(channel_id)
-      provider = ::DiscourseChat::Provider.get_by_name(channel.provider)
+      provider = ::DiscourseChatIntegration::Provider.get_by_name(channel.provider)
-      if !DiscourseChat::Provider.is_enabled(provider)
+      if !DiscourseChatIntegration::Provider.is_enabled(provider)
         raise Discourse::NotFound
@@ -39,7 +39,7 @@ class DiscourseChat::ChatController < ApplicationController
       render json: success_json
     rescue Discourse::InvalidParameters, ActiveRecord::RecordNotFound => e
       render json: { errors: [e.message] }, status: 422
-    rescue DiscourseChat::ProviderError => e
+    rescue DiscourseChatIntegration::ProviderError => e
       Rails.logger.error("Test provider failed #{e.info}")
       if e.info.key?(:error_key) && !e.info[:error_key].nil?
         render json: { error_key: e.info[:error_key] }, status: 422
@@ -50,18 +50,18 @@ class DiscourseChat::ChatController < ApplicationController
   def list_channels
-    providers = ::DiscourseChat::Provider.enabled_provider_names
+    providers = ::DiscourseChatIntegration::Provider.enabled_provider_names
     requested_provider = params[:provider]
     raise Discourse::InvalidParameters if !providers.include?(requested_provider)
-    channels = DiscourseChat::Channel.with_provider(requested_provider)
-    render_serialized channels, DiscourseChat::ChannelSerializer, root: 'channels'
+    channels = DiscourseChatIntegration::Channel.with_provider(requested_provider)
+    render_serialized channels, DiscourseChatIntegration::ChannelSerializer, root: 'channels'
   def create_channel
     begin
-      providers = ::DiscourseChat::Provider.enabled_providers.map { |x| x::PROVIDER_NAME }
+      providers = ::DiscourseChatIntegration::Provider.enabled_providers.map { |x| x::PROVIDER_NAME }
       if !defined?(params[:channel]) && defined?(params[:channel][:provider])
         raise Discourse::InvalidParameters, 'Provider is not valid'
@@ -73,17 +73,17 @@ class DiscourseChat::ChatController < ApplicationController
-      allowed_keys = DiscourseChat::Provider.get_by_name(requested_provider)::CHANNEL_PARAMETERS.map { |p| p[:key].to_sym }
+      allowed_keys = DiscourseChatIntegration::Provider.get_by_name(requested_provider)::CHANNEL_PARAMETERS.map { |p| p[:key].to_sym }
       hash = params.require(:channel).permit(:provider, data: allowed_keys)
-      channel = DiscourseChat::Channel.new(hash)
+      channel = DiscourseChatIntegration::Channel.new(hash)
       if !channel.save
         raise Discourse::InvalidParameters, 'Channel is not valid'
-      render_serialized channel, DiscourseChat::ChannelSerializer, root: 'channel'
+      render_serialized channel, DiscourseChatIntegration::ChannelSerializer, root: 'channel'
     rescue Discourse::InvalidParameters => e
@@ -91,10 +91,10 @@ class DiscourseChat::ChatController < ApplicationController
   def update_channel
     begin
-      channel = DiscourseChat::Channel.find(params[:id].to_i)
+      channel = DiscourseChatIntegration::Channel.find(params[:id].to_i)
       channel.error_key = nil # Reset any error on the rule
-      allowed_keys = DiscourseChat::Provider.get_by_name(channel.provider)::CHANNEL_PARAMETERS.map { |p| p[:key].to_sym }
+      allowed_keys = DiscourseChatIntegration::Provider.get_by_name(channel.provider)::CHANNEL_PARAMETERS.map { |p| p[:key].to_sym }
       hash = params.require(:channel).permit(data: allowed_keys)
@@ -102,14 +102,14 @@ class DiscourseChat::ChatController < ApplicationController
   def destroy_channel
-    rule = DiscourseChat::Channel.find_by(id: params[:id])
+    rule = DiscourseChatIntegration::Channel.find_by(id: params[:id])
     raise Discourse::InvalidParameters unless rule
     rule.destroy!
@@ -119,13 +119,13 @@ class DiscourseChat::ChatController < ApplicationController
   def create_rule
     begin
       hash = params.require(:rule).permit(:channel_id, :type, :filter, :group_id, :category_id, tags: [])
-      rule = DiscourseChat::Rule.new(hash)
+      rule = DiscourseChatIntegration::Rule.new(hash)
       if !rule.save
         raise Discourse::InvalidParameters, 'Rule is not valid'
-      render_serialized rule, DiscourseChat::RuleSerializer, root: 'rule'
+      render_serialized rule, DiscourseChatIntegration::RuleSerializer, root: 'rule'
@@ -133,21 +133,21 @@ class DiscourseChat::ChatController < ApplicationController
   def update_rule
     begin
-      rule = DiscourseChat::Rule.find(params[:id].to_i)
+      rule = DiscourseChatIntegration::Rule.find(params[:id].to_i)
       hash = params.require(:rule).permit(:type, :filter, :group_id, :category_id, tags: [])
       if !rule.update(hash)
   def destroy_rule
-    rule = DiscourseChat::Rule.find_by(id: params[:id])
+    rule = DiscourseChatIntegration::Rule.find_by(id: params[:id])
     raise Discourse::InvalidParameters.new unless rule
     rule.destroy!
diff --git a/app/controllers/public_controller.rb b/app/controllers/public_controller.rb
index d5a645d..1f78214 100644
--- a/app/controllers/public_controller.rb
+++ b/app/controllers/public_controller.rb
@@ -1,7 +1,7 @@
-class DiscourseChat::PublicController < ApplicationController
+class DiscourseChatIntegration::PublicController < ApplicationController
   def post_transcript
     params.require(:secret)
diff --git a/app/helpers/helper.rb b/app/helpers/helper.rb
index 3625ffb..3062df7 100644
--- a/app/helpers/helper.rb
+++ b/app/helpers/helper.rb
@@ -1,10 +1,10 @@
-module DiscourseChat
+module DiscourseChatIntegration
   module Helper
     def self.process_command(channel, tokens)
-      guardian = DiscourseChat::Manager.guardian
GitHub sha: a73f5da114d6d7adfac53bdd58b7f45a4e3ac31a
This commit appears in #82 which was approved by davidtaylorhq. It was merged by markvanlan.
