Rename house ad routes so ad blockers don't detect them
Rename house ad routes so ad blockers don’t detect them
adplugin, house_ads, house_ad_settings become pluginad, house_creatives, and house_settings.
diff --git a/assets/javascripts/discourse/adplugin-route-map.js.es6 b/assets/javascripts/discourse/adplugin-route-map.js.es6
index e68edbc..5bdd864 100644
--- a/assets/javascripts/discourse/adplugin-route-map.js.es6
+++ b/assets/javascripts/discourse/adplugin-route-map.js.es6
@@ -2,7 +2,7 @@ export default {
   resource: "admin.adminPlugins",
   path: "/plugins",
   map() {
-    this.route("houseAds", { path: "/adplugin/house_ads" }, function() {
+    this.route("houseAds", { path: "/pluginad/house_creatives" }, function() {
       this.route("index", { path: "/" });
       this.route("show", { path: "/:ad_id" });
diff --git a/assets/javascripts/discourse/components/house-ads-setting.js.es6 b/assets/javascripts/discourse/components/house-ads-setting.js.es6
index fdf81f6..7689d01 100644
--- a/assets/javascripts/discourse/components/house-ads-setting.js.es6
+++ b/assets/javascripts/discourse/components/house-ads-setting.js.es6
@@ -25,7 +25,7 @@ export default Ember.Component.extend({
         ajax(
-          `/admin/plugins/adplugin/house_ad_settings/${this.get("name")}.json`,
+          `/admin/plugins/pluginad/house_settings/${this.get("name")}.json`,
             type: "PUT",
             data: { value: this.get("adValue") }
diff --git a/assets/javascripts/discourse/controllers/admin-plugins-house-ads-show.js.es6 b/assets/javascripts/discourse/controllers/admin-plugins-house-ads-show.js.es6
index eccf86a..4326762 100644
--- a/assets/javascripts/discourse/controllers/admin-plugins-house-ads-show.js.es6
+++ b/assets/javascripts/discourse/controllers/admin-plugins-house-ads-show.js.es6
@@ -34,8 +34,8 @@ export default Ember.Controller.extend(bufferedProperty("model"), {
         ajax(
           newRecord
-            ? `/admin/plugins/adplugin/house_ads`
-            : `/admin/plugins/adplugin/house_ads/${buffered.get("id")}`,
+            ? `/admin/plugins/pluginad/house_creatives`
+            : `/admin/plugins/pluginad/house_creatives/${buffered.get("id")}`,
             type: newRecord ? "POST" : "PUT",
             data
@@ -80,7 +80,7 @@ export default Ember.Controller.extend(bufferedProperty("model"), {
         return;
-      ajax(`/admin/plugins/adplugin/house_ads/${model.get("id")}`, {
+      ajax(`/admin/plugins/pluginad/house_creatives/${model.get("id")}`, {
         type: "DELETE"
         .then(() => {
diff --git a/assets/javascripts/discourse/routes/admin-plugins-house-ads.js.es6 b/assets/javascripts/discourse/routes/admin-plugins-house-ads.js.es6
index bc03d17..1c0cda6 100644
--- a/assets/javascripts/discourse/routes/admin-plugins-house-ads.js.es6
+++ b/assets/javascripts/discourse/routes/admin-plugins-house-ads.js.es6
@@ -4,7 +4,7 @@ export default Discourse.Route.extend({
   settings: null,
   model() {
-    return ajax("/admin/plugins/adplugin/house_ads.json").then(data => {
+    return ajax("/admin/plugins/pluginad/house_creatives.json").then(data => {
       this.set("settings", Ember.Object.create(data.settings));
       return data.house_ads.map(ad => Ember.Object.create(ad));
index 73d892f..05f119e 100755
--- a/plugin.rb
+++ b/plugin.rb
@@ -71,12 +71,12 @@ after_initialize do
   AdPlugin::Engine.routes.draw do
     root to: 'house_ads#index'
-    resources :house_ads, only: [:index, :show, :create, :update, :destroy]
-    resources :house_ad_settings, only: [:update]
+    resources :house_creatives, only: [:index, :show, :create, :update, :destroy], controller: 'house_ads'
+    resources :house_settings, only: [:update], controller: 'house_ad_settings'
   Discourse::Application.routes.append do
     get '/ads.txt' => "adstxt#index"
-    mount ::AdPlugin::Engine, at: '/admin/plugins/adplugin', constraints: AdminConstraint.new
+    mount ::AdPlugin::Engine, at: '/admin/plugins/pluginad', constraints: AdminConstraint.new
diff --git a/spec/requests/house_ad_settings_controller_spec.rb b/spec/requests/house_ad_settings_controller_spec.rb
index 76f652e..19ec0b1 100644
--- a/spec/requests/house_ad_settings_controller_spec.rb
+++ b/spec/requests/house_ad_settings_controller_spec.rb
@@ -13,13 +13,13 @@ describe AdPlugin::HouseAdSettingsController do
     let(:valid_params) { { value: 'Banner' } }
     it "error if not logged in" do
-      put '/admin/plugins/adplugin/house_ad_settings/topic_list_top.json', params: valid_params
+      put '/admin/plugins/pluginad/house_settings/topic_list_top.json', params: valid_params
       expect(response.status).to eq(404)
     it "error if not staff" do
       sign_in(Fabricate(:user))
@@ -29,18 +29,18 @@ describe AdPlugin::HouseAdSettingsController do
       it "changes the setting" do
         expect(response.status).to eq(200)
         expect(AdPlugin::HouseAdSetting.all[:topic_list_top]).to eq(valid_params[:value])
       it "errors on invalid setting name" do
-        put '/admin/plugins/adplugin/house_ad_settings/nope-nope.json', params: valid_params
+        put '/admin/plugins/pluginad/house_settings/nope-nope.json', params: valid_params
       it "errors on invalid setting value" do
-        put '/admin/plugins/adplugin/house_ad_settings/topic_list_top.json', params: valid_params.merge(value: "Banner|<script>")
+        put '/admin/plugins/pluginad/house_settings/topic_list_top.json', params: valid_params.merge(value: "Banner|<script>")
         expect(response.status).to eq(400)
GitHub sha: 8d4df6df
