Rename more es6 files to js
diff --git a/app/assets/javascripts/discourse.js b/app/assets/javascripts/discourse.js
new file mode 100644
index 0000000..10fb7dd
--- /dev/null
+++ b/app/assets/javascripts/discourse.js
@@ -0,0 +1,219 @@
+/*global Mousetrap:true*/
+import Application from "@ember/application";
+import EmberObject, { computed } from "@ember/object";
+import { buildResolver } from "discourse-common/resolver";
+import discourseComputed, { observes } from "discourse-common/utils/decorators";
+import FocusEvent from "discourse-common/mixins/focus-event";
+import deprecated from "discourse-common/lib/deprecated";
+const _pluginCallbacks = [];
+const Discourse = Application.extend(FocusEvent, {
+  rootElement: "#main",
+  _docTitle: document.title,
+  RAW_TEMPLATES: {},
+  __widget_helpers: {},
+  customEvents: {
+    paste: "paste"
+  reset() {
+    this._super(...arguments);
+    Mousetrap.reset();
+  getURL(url) {
+    if (!url) return url;
+    // if it's a non relative URL, return it.
+    if (url !== "/" && !/^\/[^\/]/.test(url)) return url;
+    if (url[0] !== "/") url = "/" + url;
+    if (url.startsWith(Discourse.BaseUri)) return url;
+    return Discourse.BaseUri + url;
+  getURLWithCDN(url) {
+    url = Discourse.getURL(url);
+    // only relative urls
+    if (Discourse.CDN && /^\/[^\/]/.test(url)) {
+      url = Discourse.CDN + url;
+    } else if (Discourse.S3CDN) {
+      url = url.replace(Discourse.S3BaseUrl, Discourse.S3CDN);
+    return url;
+  Resolver: buildResolver("discourse"),
+  @observes("_docTitle", "hasFocus", "contextCount", "notificationCount")
+  _titleChanged() {
+    let title = this._docTitle || Discourse.SiteSettings.title;
+    // if we change this we can trigger changes on document.title
+    // only set if changed.
+    if ($("title").text() !== title) {
+      $("title").text(title);
+    let displayCount = this.displayCount;
+    let dynamicFavicon = this.currentUser && this.currentUser.dynamic_favicon;
+    if (displayCount > 0 && !dynamicFavicon) {
+      title = `(${displayCount}) ${title}`;
+    document.title = title;
+  @discourseComputed("contextCount", "notificationCount")
+  displayCount() {
+    return this.currentUser &&
+      this.currentUser.get("title_count_mode") === "notifications"
+      ? this.notificationCount
+      : this.contextCount;
+  @observes("contextCount", "notificationCount")
+  faviconChanged() {
+    if (this.currentUser && this.currentUser.get("dynamic_favicon")) {
+      let url = Discourse.SiteSettings.site_favicon_url;
+      // Since the favicon is cached on the browser for a really long time, we
+      // append the favicon_url as query params to the path so that the cache
+      // is not used when the favicon changes.
+      if (/^http/.test(url)) {
+        url = Discourse.getURL("/favicon/proxied?" + encodeURIComponent(url));
+      var displayCount = this.displayCount;
+      new window.Favcount(url).set(displayCount);
+  updateContextCount(count) {
+    this.set("contextCount", count);
+  updateNotificationCount(count) {
+    if (!this.hasFocus) {
+      this.set("notificationCount", count);
+  incrementBackgroundContextCount() {
+      this.set("backgroundNotify", true);
+      this.set("contextCount", (this.contextCount || 0) + 1);
+  @observes("hasFocus")
+  resetCounts() {
+    if (this.hasFocus && this.backgroundNotify) {
+      this.set("contextCount", 0);
+    this.set("backgroundNotify", false);
+    if (this.hasFocus) {
+      this.set("notificationCount", 0);
+  authenticationComplete(options) {
+    // TODO, how to dispatch this to the controller without the container?
+    const loginController = Discourse.__container__.lookup("controller:login");
+    return loginController.authenticationComplete(options);
+  // Start up the Discourse application by running all the initializers we've defined.
+  start() {
+    $("noscript").remove();
+    Object.keys(requirejs._eak_seen).forEach(function(key) {
+      if (/\/pre\-initializers\//.test(key)) {
+        const module = requirejs(key, null, null, true);
+        if (!module) {
+          throw new Error(key + " must export an initializer.");
+        const init = module.default;
+        const oldInitialize = init.initialize;
+        init.initialize = function() {
+          oldInitialize.call(this, Discourse.__container__, Discourse);
+        Discourse.initializer(init);
+      if (/\/initializers\//.test(key)) {
+        if (!module) {
+        Discourse.instanceInitializer(init);
+    // Plugins that are registered via `<script>` tags.
+    const withPluginApi = requirejs("discourse/lib/plugin-api").withPluginApi;
+    let initCount = 0;
+    _pluginCallbacks.forEach(function(cb) {
+      Discourse.instanceInitializer({
+        name: "_discourse_plugin_" + ++initCount,
+        after: "inject-objects",
+        initialize() {
+          withPluginApi(cb.version, cb.code);
+  @discourseComputed("currentAssetVersion", "desiredAssetVersion")
+  requiresRefresh(currentAssetVersion, desiredAssetVersion) {
+    return desiredAssetVersion && currentAssetVersion !== desiredAssetVersion;
+  _registerPluginCode(version, code) {
+    _pluginCallbacks.push({ version, code });
+  assetVersion: computed({
+    get() {
+      return this.currentAssetVersion;
+    set(key, val) {
+      if (val) {
+        if (this.currentAssetVersion) {
+          this.set("desiredAssetVersion", val);
+        } else {
+          this.set("currentAssetVersion", val);
+}).create();
+Object.defineProperty(Discourse, "Model", {
+  get() {
+    deprecated("Use an `@ember/object` instead of Discourse.Model", {
+      since: "2.4.0",
+      dropFrom: "2.5.0"
+    return EmberObject;
+export default Discourse;
diff --git a/app/assets/javascripts/discourse.js.es6 b/app/assets/javascripts/discourse.js.es6
deleted file mode 100644
index 10fb7dd..0000000
--- a/app/assets/javascripts/discourse.js.es6
+++ /dev/null
@@ -1,219 +0,0 @@
-/*global Mousetrap:true*/
-import Application from "@ember/application";
-import EmberObject, { computed } from "@ember/object";
-import { buildResolver } from "discourse-common/resolver";
-import discourseComputed, { observes } from "discourse-common/utils/decorators";
-import FocusEvent from "discourse-common/mixins/focus-event";
-import deprecated from "discourse-common/lib/deprecated";
-const _pluginCallbacks = [];
-const Discourse = Application.extend(FocusEvent, {
-  rootElement: "#main",
-  _docTitle: document.title,
-  RAW_TEMPLATES: {},
-  __widget_helpers: {},
-  customEvents: {
-    paste: "paste"
-  reset() {
-    this._super(...arguments);
-    Mousetrap.reset();
-  getURL(url) {
-    if (!url) return url;
-    // if it's a non relative URL, return it.
-    if (url !== "/" && !/^\/[^\/]/.test(url)) return url;
-    if (url[0] !== "/") url = "/" + url;
-    if (url.startsWith(Discourse.BaseUri)) return url;
-    return Discourse.BaseUri + url;
-  getURLWithCDN(url) {
-    url = Discourse.getURL(url);
-    // only relative urls
-    if (Discourse.CDN && /^\/[^\/]/.test(url)) {
-      url = Discourse.CDN + url;
-    } else if (Discourse.S3CDN) {
GitHub sha: a11938d5
