Replace `-depth` -> `-maxdepth` in boot_dev (PR #14046)
The -depth flag is incorrect on Linux, it does not take an argument and causes an error and results in no plugins ever being found.
Copied from man find:
The global options occur after the list of start points, and so are not the same kind of option as -L, for example.
       -d     A synonym for -depth, for compatibility with FreeBSD, NetBSD, MacOS X and OpenBSD.
       -depth Process each directory's contents before the directory itself.  The -delete action also implies -depth.
       -maxdepth levels
              Descend at most levels (a non-negative integer) levels of directories below the starting-points.  Using -maxdepth 0  means
              only apply the tests and actions to the starting-points themselves.
GitHub
CLA assistant check
Thank you for your submission! We really appreciate it. Like many open source projects, we ask that you sign our Contributor License Agreement before we can accept your contribution.
You have signed the CLA already but the status is still pending? Let us recheck it.
This looks good to me. Thank you @jacobmischka for your contributions to Discourse :+1:
