Reverse the order of nested templates. (#531)
Reverses the order of nested template declaration.
This way templates that depend nested templates over the same hook are ensured to run in the proper order.
Ensures consistency of run-order template includes, for both base yml files, and nested template yml
eg:
base.yml
templates:
- "templates/template1.yml"
hooks:
after_code:
- exec: cat "/tmp/file_made_from_template1.yml.txt"
template1.yml
templates:
- "templates/template2.yml"
hooks:
after_code:
- exec: cat "/tmp/file_made_from_template2.yml.txt"
- exec: echo "data from template1" > /tmp/file_made_from_template1.yml.txt
template2.yml
hooks:
after_code:
- exec: echo "data from template2" > /tmp/file_made_from_template2.yml.txt
diff --git a/launcher b/launcher
index d5a6e4c..173a1d6 100755
--- a/launcher
+++ b/launcher
@@ -280,7 +280,7 @@ find_templates() {
local nested_templates=$(find_templates $template)
if [ ! -z "$nested_templates" ]; then
- templates="$templates $nested_templates"
+ templates="$nested_templates $templates"
fi
done
GitHub sha: 0c263ec4
