Revert "DEV: Drop old IE11 intersection-observer references" (#13017)
Revert “DEV: Drop old IE11 intersection-observer references” (#13017)
This reverts commit 7360a0f70fae59bb065dffb9b1ad42d13ff38f46.
iOS still wants this sometimes. Probably best to revert for now and we can always remove this again later.
See: https://meta.discourse.org/t/189799/11?u=blake
diff --git a/app/assets/javascripts/vendor.js b/app/assets/javascripts/vendor.js
index d49ec43..d001928 100644
--- a/app/assets/javascripts/vendor.js
+++ b/app/assets/javascripts/vendor.js
@@ -23,4 +23,5 @@
 //= require jquery.autoellipsis-1.0.10
 //= require virtual-dom
 //= require virtual-dom-amd
+//= require intersection-observer
 //= require discourse-shims
diff --git a/lib/tasks/javascript.rake b/lib/tasks/javascript.rake
index a40bd98..2ab50b5 100644
--- a/lib/tasks/javascript.rake
+++ b/lib/tasks/javascript.rake
@@ -141,6 +141,9 @@ def dependencies
       source: 'resumablejs/resumable.js'
+      # TODO: drop when we eventually drop IE11, this will land in iOS in version 13
+      source: 'intersection-observer/intersection-observer.js'
       source: 'workbox-sw/build/.',
       destination: 'workbox',
       public: true,
diff --git a/package.json b/package.json
index 0684f15..8b9d3ca 100644
--- a/package.json
+++ b/package.json
@@ -19,6 +19,7 @@
     "eslint-config-discourse": "^1.1.8",
     "handlebars": "^4.7.0",
     "@highlightjs/cdn-assets": "^10.6.0",
+    "intersection-observer": "^0.5.1",
     "jquery": "3.5.1",
     "jquery-color": "3.0.0-alpha.1",
     "jquery-tags-input": "1.3.5",
diff --git a/vendor/assets/javascripts/intersection-observer.js b/vendor/assets/javascripts/intersection-observer.js
new file mode 100644
index 0000000..7a07965
--- /dev/null
+++ b/vendor/assets/javascripts/intersection-observer.js
@@ -0,0 +1,726 @@
+ * Copyright 2016 Google Inc. All Rights Reserved.
+ * Licensed under the W3C SOFTWARE AND DOCUMENT NOTICE AND LICENSE.
+ *  https://www.w3.org/Consortium/Legal/2015/copyright-software-and-document
+(function(window, document) {
+'use strict';
+// Exits early if all IntersectionObserver and IntersectionObserverEntry
+// features are natively supported.
+if ('IntersectionObserver' in window &&
+    'IntersectionObserverEntry' in window &&
+    'intersectionRatio' in window.IntersectionObserverEntry.prototype) {
+  // Minimal polyfill for Edge 15's lack of `isIntersecting`
+  // See: https://github.com/w3c/IntersectionObserver/issues/211
+  if (!('isIntersecting' in window.IntersectionObserverEntry.prototype)) {
+    Object.defineProperty(window.IntersectionObserverEntry.prototype,
+      'isIntersecting', {
+      get: function () {
+        return this.intersectionRatio > 0;
+  return;
+ * An IntersectionObserver registry. This registry exists to hold a strong
+ * reference to IntersectionObserver instances currently observing a target
+ * element. Without this registry, instances without another reference may be
+ * garbage collected.
+var registry = [];
+ * Creates the global IntersectionObserverEntry constructor.
+ * https://w3c.github.io/IntersectionObserver/#intersection-observer-entry
+ * @param {Object} entry A dictionary of instance properties.
+ * @constructor
+function IntersectionObserverEntry(entry) {
+  this.time = entry.time;
+  this.target = entry.target;
+  this.rootBounds = entry.rootBounds;
+  this.boundingClientRect = entry.boundingClientRect;
+  this.intersectionRect = entry.intersectionRect || getEmptyRect();
+  this.isIntersecting = !!entry.intersectionRect;
+  // Calculates the intersection ratio.
+  var targetRect = this.boundingClientRect;
+  var targetArea = targetRect.width * targetRect.height;
+  var intersectionRect = this.intersectionRect;
+  var intersectionArea = intersectionRect.width * intersectionRect.height;
+  // Sets intersection ratio.
+  if (targetArea) {
+    // Round the intersection ratio to avoid floating point math issues:
+    // https://github.com/w3c/IntersectionObserver/issues/324
+    this.intersectionRatio = Number((intersectionArea / targetArea).toFixed(4));
+  } else {
+    // If area is zero and is intersecting, sets to 1, otherwise to 0
+    this.intersectionRatio = this.isIntersecting ? 1 : 0;
+ * Creates the global IntersectionObserver constructor.
+ * https://w3c.github.io/IntersectionObserver/#intersection-observer-interface
+ * @param {Function} callback The function to be invoked after intersection
+ *     changes have queued. The function is not invoked if the queue has
+ *     been emptied by calling the `takeRecords` method.
+ * @param {Object=} opt_options Optional configuration options.
+ * @constructor
+function IntersectionObserver(callback, opt_options) {
+  var options = opt_options || {};
+  if (typeof callback != 'function') {
+    throw new Error('callback must be a function');
+  if (options.root && options.root.nodeType != 1) {
+    throw new Error('root must be an Element');
+  // Binds and throttles `this._checkForIntersections`.
+  this._checkForIntersections = throttle(
+      this._checkForIntersections.bind(this), this.THROTTLE_TIMEOUT);
+  // Private properties.
+  this._callback = callback;
+  this._observationTargets = [];
+  this._queuedEntries = [];
+  this._rootMarginValues = this._parseRootMargin(options.rootMargin);
+  // Public properties.
+  this.thresholds = this._initThresholds(options.threshold);
+  this.root = options.root || null;
+  this.rootMargin = this._rootMarginValues.map(function(margin) {
+    return margin.value + margin.unit;
+  }).join(' ');
+ * The minimum interval within which the document will be checked for
+ * intersection changes.
+IntersectionObserver.prototype.THROTTLE_TIMEOUT = 100;
+ * The frequency in which the polyfill polls for intersection changes.
+ * this can be updated on a per instance basis and must be set prior to
+ * calling `observe` on the first target.
+IntersectionObserver.prototype.POLL_INTERVAL = null;
+ * Use a mutation observer on the root element
+ * to detect intersection changes.
+IntersectionObserver.prototype.USE_MUTATION_OBSERVER = true;
+ * Starts observing a target element for intersection changes based on
+ * the thresholds values.
+ * @param {Element} target The DOM element to observe.
+IntersectionObserver.prototype.observe = function(target) {
+  var isTargetAlreadyObserved = this._observationTargets.some(function(item) {
+    return item.element == target;
+  if (isTargetAlreadyObserved) {
+    return;
+  if (!(target && target.nodeType == 1)) {
+    throw new Error('target must be an Element');
+  this._registerInstance();
+  this._observationTargets.push({element: target, entry: null});
+  this._monitorIntersections();
+  this._checkForIntersections();
+ * Stops observing a target element for intersection changes.
+IntersectionObserver.prototype.unobserve = function(target) {
+      this._observationTargets.filter(function(item) {
+    return item.element != target;
+  if (!this._observationTargets.length) {
+    this._unmonitorIntersections();
+    this._unregisterInstance();
+ * Stops observing all target elements for intersection changes.
+IntersectionObserver.prototype.disconnect = function() {
+ * Returns any queue entries that have not yet been reported to the
+ * callback and clears the queue. This can be used in conjunction with the
+ * callback to obtain the absolute most up-to-date intersection information.
+ * @return {Array} The currently queued entries.
+IntersectionObserver.prototype.takeRecords = function() {
+  var records = this._queuedEntries.slice();
+  return records;
+ * Accepts the threshold value from the user configuration object and
+ * returns a sorted array of unique threshold values. If a value is not
+ * between 0 and 1 and error is thrown.
+ * @private
GitHub sha: 37812b8e
This commit appears in #13017 which was approved by SamSaffron. It was merged by blake.
