Revert "DEV: suppress assets logs from qunit tests (#13871)" (PR #13878)
This reverts commit 1b649016d91737ec666f73418ed4229bcbb24601.
Test is failing with the following message:
navigate to  http://localhost:60099/qunit?hidepassed=1&seed=312984199721107128645754962579661839397&qunit_disable_auto_start=1
2021-07-29T02:57:13.303Z - (type: network/error) message: Failed to load resource: the server responded with a status of 403 (Forbidden), url: http://localhost:60099/extra-locales/admin?v=eeeea38a700966a1a7fb600b23f3a222
2021-07-29T02:57:43.823Z - (type: network/error) message: Failed to load resource: net::ERR_EMPTY_RESPONSE, url: http://localhost:60099/assets/discourse/tests/test_helper.js
ReferenceError: define is not defined
    at eval (discourse/tests/acceptance/about-test:1:1)
    at http://localhost:60099/assets/discourse/tests/core_plugins_tests.js:1:1
ReferenceError: require is not defined
    at eval (discourse/tests/test_starter:5:24)
    at http://localhost:60099/assets/discourse/tests/test_starter.js:1:1
2021-07-29T02:57:43.891Z - (type: network/error) message: Failed to load resource: the server responded with a status of 403 (Forbidden), url: http://localhost:60099/extra-locales/admin?v=eeeea38a700966a1a7fb600b23f3a222
Tests timed out
GitHub
