Revert "FEATURE: Add custom theme for code review categories (#26)"
Revert “FEATURE: Add custom theme for code review categories (#26)”
This reverts commit 5a88bc298f014a1a68f0ae0e164275cae8417c3a because it breaks texts without any explaination.
diff --git a/assets/javascripts/discourse/components/review-topic-list-item.js.es6 b/assets/javascripts/discourse/components/review-topic-list-item.js.es6
deleted file mode 100644
index 31ca665..0000000
--- a/assets/javascripts/discourse/components/review-topic-list-item.js.es6
+++ /dev/null
@@ -1,13 +0,0 @@
-import { findRawTemplate } from "discourse-common/lib/raw-templates";
-import { observes } from "discourse-common/utils/decorators";
-import TopicListItem from "discourse/components/topic-list-item";
-export default TopicListItem.extend({
-  @observes("topic.pinned")
-  renderTopicListItem() {
-    const template = findRawTemplate("list/review-topic-list-item");
-    if (template) {
-      this.set("topicListItemContents", template(this).htmlSafe());
diff --git a/assets/javascripts/discourse/initializers/theme.js.es6 b/assets/javascripts/discourse/initializers/theme.js.es6
index 2fa5cd2..0000000
--- a/assets/javascripts/discourse/initializers/theme.js.es6
+++ /dev/null
@@ -1,61 +0,0 @@
-import discourseComputed from "discourse-common/utils/decorators";
-import TopicListComponent from "discourse/components/topic-list";
-import { withPluginApi } from "discourse/lib/plugin-api";
-export default {
-  name: "discourse-code-review-theme",
-  initialize(container) {
-    const siteSettings = container.lookup("site-settings:main");
-    if (!siteSettings.code_review_theme) {
-      return;
-    withPluginApi("0.8.28", () => {
-      TopicListComponent.reopen({
-        @discourseComputed("filteredTopics.[]")
-        filteredTopicsByDate(filteredTopics) {
-          if (
-            !this.category ||
-            !this.category.custom_fields["GitHub Repo Name"]
-            return;
-          const topicsByDate = {};
-          filteredTopics.forEach(topic => {
-            topic.setProperties({
-              approved: topic.tags.includes(
-                this.siteSettings.code_review_approved_tag
-              followup: topic.tags.includes(
-                this.siteSettings.code_review_followup_tag
-              pending: topic.tags.includes(
-                this.siteSettings.code_review_pending_tag
-            const date = moment(topic.created_at).format("YYYY-MM-DD");
-            if (!topicsByDate[date]) {
-              topicsByDate[date] = [];
-            topicsByDate[date].push(topic);
-          const filteredTopicsByDate = [];
-          Object.keys(topicsByDate)
-            .sort()
-            .reverse()
-            .forEach(date => {
-              filteredTopicsByDate.push({
-                date: moment(date).format("MMMM D, YYYY"),
-                topics: topicsByDate[date]
-          return filteredTopicsByDate;
diff --git a/assets/javascripts/discourse/templates/components/review-topic-list-item.hbs b/assets/javascripts/discourse/templates/components/review-topic-list-item.hbs
index 556c017..0000000
--- a/assets/javascripts/discourse/templates/components/review-topic-list-item.hbs
+++ /dev/null
@@ -1 +0,0 @@
-{{topicListItemContents}}
diff --git a/assets/javascripts/discourse/templates/components/topic-list.hbs b/assets/javascripts/discourse/templates/components/topic-list.hbs
index 73e0321..0000000
--- a/assets/javascripts/discourse/templates/components/topic-list.hbs
+++ /dev/null
@@ -1,101 +0,0 @@
-{{#if filteredTopicsByDate}}
-  {{#each filteredTopicsByDate as |topicsByDate|}}
-    {{#unless skipHeader}}
-      <thead class="code-review">
-        {{raw "review-topic-list-header"
-          topicsDate=topicsByDate.date
-          canBulkSelect=canBulkSelect
-          toggleInTitle=toggleInTitle
-          hideCategory=hideCategory
-          showPosters=showPosters
-          showLikes=showLikes
-          showOpLikes=showOpLikes
-          order=order
-          ascending=ascending
-          sortable=sortable
-          listTitle=listTitle
-          bulkSelectEnabled=bulkSelectEnabled}}
-      </thead>
-    {{/unless}}
-    {{plugin-outlet
-      name="before-topic-list-body"
-      args=(hash
-        topics=topics
-        selected=selected
-        lastVisitedTopic=lastVisitedTopic
-        discoveryList=discoveryList
-        hideCategory=hideCategory)
-      tagName=""
-      connectorTagName=""}}
-    <tbody class="code-review">
-      {{#each topicsByDate.topics as |topic|}}
-        {{review-topic-list-item topic=topic
-                                showTopicPostBadges=showTopicPostBadges
-                                expandGloballyPinned=expandGloballyPinned
-                                expandAllPinned=expandAllPinned
-                                selected=selected
-                                tagsForUser=tagsForUser}}
-        {{raw "list/visited-line" lastVisitedTopic=lastVisitedTopic topic=topic}}
-      {{/each}}
-    </tbody>
-  {{/each}}
-{{else}}
-{{! original app/templates/components/topic-list.hbs }}
-{{#unless skipHeader}}
-  <thead>
-    {{raw "topic-list-header"
-      order=order
-      sortable=sortable
-  </thead>
-{{/unless}}
-{{plugin-outlet
-  args=(hash
-    topics=topics
-    selected=selected
-  tagName=""
-<tbody>
-  {{#each filteredTopics as |topic|}}
-    {{topic-list-item topic=topic
-                      selected=selected
-  {{/each}}
-</tbody>
-{{/if}}
\ No newline at end of file
diff --git a/assets/javascripts/discourse/templates/list/review-topic-list-item.hbr b/assets/javascripts/discourse/templates/list/review-topic-list-item.hbr
index f91f248..0000000
--- a/assets/javascripts/discourse/templates/list/review-topic-list-item.hbr
+++ /dev/null
@@ -1,83 +0,0 @@
-{{~raw-plugin-outlet name="topic-list-before-columns"}}
-{{#if bulkSelectEnabled}}
-  <td class="bulk-select">
-    <input type="checkbox" class="bulk-select">
-  </td>
-{{/if}}
-  The `~` syntax strip spaces between the elements, making it produce
-  `<a class=topic-post-badges>Some text</a><span class=topic-post-badges>`,
-  with no space between them.
-  This causes the topic-post-badge to be considered the same word as "text"
-  at the end of the link, preventing it from line wrapping onto its own line.
-<td class='main-link clearfix' colspan="1">
GitHub sha: 5384a053
