REVERT: 'FEATURE: Add solved icon for topic titles in search results and other topic lists'
REVERT: ‘FEATURE: Add solved icon for topic titles in search results and other topic lists’
diff --git a/app/serializers/concerns/topic_answer_mixin.rb b/app/serializers/concerns/topic_answer_mixin.rb
deleted file mode 100644
index 23c8a22..0000000
--- a/app/serializers/concerns/topic_answer_mixin.rb
+++ /dev/null
@@ -1,19 +0,0 @@
-module TopicAnswerMixin
-  def self.included(klass)
-    klass.attributes :has_accepted_answer, :can_have_answer
-  end
-  def has_accepted_answer
-    object.custom_fields["accepted_answer_post_id"] ? true : false
-  end
-  def can_have_answer
-    return true if SiteSetting.allow_solved_on_all_topics
-    return false if object.closed || object.archived
-    return scope.allow_accepted_answers_on_category?(object.category_id)
-  end
-  def include_can_have_answer?
-    SiteSetting.empty_box_on_unsolved
-  end
-end
diff --git a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6 b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
index ae8391d..1aa1fe2 100644
--- a/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
+++ b/assets/javascripts/discourse/initializers/extend-for-solved-button.js.es6
@@ -1,7 +1,6 @@
 import Topic from "discourse/models/topic";
 import User from "discourse/models/user";
 import TopicStatus from "discourse/raw-views/topic-status";
-import TopicStatusIcons from "discourse/helpers/topic-status-icons";
 import { popupAjaxError } from "discourse/lib/ajax-error";
 import { withPluginApi } from "discourse/lib/plugin-api";
 import { ajax } from "discourse/lib/ajax";
@@ -65,12 +64,6 @@ function acceptPost(post) {
 function initializeWithApi(api) {
   const currentUser = api.getCurrentUser();
-  TopicStatusIcons.addObject([
-    "has_accepted_answer",
-    "check-square-o",
-    "solved"
   api.includePostAttributes(
     "can_accept_answer",
     "can_unaccept_answer",
@@ -226,7 +219,7 @@ export default {
           results.push({
             openTag: "span",
             closeTag: "span",
-            title: I18n.t("topic_statuses.solved.help"),
+            title: I18n.t("solved.has_accepted_answer"),
             icon: "check-square-o"
         } else if (
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 16abec3..4157acf 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -9,6 +9,7 @@ en:
       title: "Solved"
       allow_accepted_answers: "Allow topic owner and staff to mark a reply as the solution"
       accept_answer: "Select if this reply solves the problem"
+      has_accepted_answer: "This topic has a solution"
       has_no_accepted_answer: "This topic has no solution"
       unaccept_answer: "Unselect if this reply no longer solves the problem"
       accepted_answer: "Solution"
@@ -18,7 +19,3 @@ en:
         other: "solutions"
       accepted_html: "{{icon}} Solved <span class='by'>by <a href data-user-card='{{username_lower}}'>{{username}}</a></span> in <a href='{{post_path}}' class='back'>post #{{post_number}}</a>"
       accepted_notification: "<p><span>{{username}}</span> {{description}}</p>"
-    topic_statuses:
-      solved:
-        help: "This topic has a solution"
index 68af667..0514e45 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -18,10 +18,6 @@ register_asset 'stylesheets/solutions.scss'
 after_initialize do
-    '../app/serializers/concerns/topic_answer_mixin.rb'
-  ].each { |path| load File.expand_path(path, __FILE__) }
   # we got to do a one time upgrade
   if defined?(UserAction::SOLVED)
     unless $redis.get('solved_already_upgraded')
@@ -483,29 +479,42 @@ SQL
   require_dependency 'topic_list_item_serializer'
-  require_dependency 'search_topic_list_item_serializer'
-  require_dependency 'suggested_topic_serializer'
-  require_dependency 'category_detailed_serializer'
-  require_dependency 'user_summary_serializer'
+  require_dependency 'listable_topic_serializer'
   class ::TopicListItemSerializer
-    include TopicAnswerMixin
-  end
+    attributes :has_accepted_answer, :can_have_answer
-  class ::SearchTopicListItemSerializer
-  end
+    def has_accepted_answer
+      object.custom_fields["accepted_answer_post_id"] ? true : false
+    end
-  class ::SuggestedTopicSerializer
-  end
+    def can_have_answer
+      return true if SiteSetting.allow_solved_on_all_topics
+      return false if object.closed || object.archived
+      return scope.allow_accepted_answers_on_category?(object.category_id)
+    end
-  class ::CategoryDetailedSerializer
+    def include_can_have_answer?
+      SiteSetting.empty_box_on_unsolved
+    end
-  class ::UserSummarySerializer::TopicSerializer
+  class ::ListableTopicSerializer
+    end
+    end
+    end
   TopicList.preloaded_custom_fields << "accepted_answer_post_id" if TopicList.respond_to? :preloaded_custom_fields
GitHub sha: 6dbd420c
Revert "REVERT: 'FEATURE: Add solved icon for topic titles in search results and other topic lists'"
hmm what is the story with the revert and then the revert revert?
The core commit which this one depends is stuck for few hours in the build. I waited until its reach to “tests-passed”.
