Revert “FEATURE: Introduce theme/component QUnit tests (#12517)” (#12632)
This reverts commit https://github.com/discourse/discourse/commit/a53d8d3e61d33dde22628a8ceb94b6a27cb0a99a and https://github.com/discourse/discourse/commit/105634435fe605f122e4a0a4a4293cc37a6747c6.
Reverted because the change broke some components. Will be added back in a few days.
diff --git a/app/assets/javascripts/discourse/app/helpers/theme-helpers.js b/app/assets/javascripts/discourse/app/helpers/theme-helpers.js
index 477b89b..9898775 100644
--- a/app/assets/javascripts/discourse/app/helpers/theme-helpers.js
+++ b/app/assets/javascripts/discourse/app/helpers/theme-helpers.js
@@ -1,7 +1,6 @@
-import { registerUnbound } from "discourse-common/lib/helpers";
+import { helperContext, registerUnbound } from "discourse-common/lib/helpers";
import I18n from "I18n";
import deprecated from "discourse-common/lib/deprecated";
-import { getSetting as getThemeSetting } from "discourse/lib/theme-settings-store";
registerUnbound("theme-i18n", (themeId, key, params) => {
return I18n.t(`theme_translations.${themeId}.${key}`, params);
@@ -19,6 +18,5 @@ registerUnbound("theme-setting", (themeId, key, hash) => {
{ since: "v2.2.0.beta8", dropFrom: "v2.3.0" }
- return getThemeSetting(themeId, key);
+ return helperContext().themeSettings.getSetting(themeId, key);
diff --git a/app/assets/javascripts/discourse/app/initializers/auto-load-modules.js b/app/assets/javascripts/discourse/app/initializers/auto-load-modules.js
index fa2ca51..b985d85 100644
--- a/app/assets/javascripts/discourse/app/initializers/auto-load-modules.js
+++ b/app/assets/javascripts/discourse/app/initializers/auto-load-modules.js
@@ -19,6 +19,7 @@ export function autoLoadModules(container, registry) {
let context = {
siteSettings: container.lookup("site-settings:main"),
+ themeSettings: container.lookup("service:theme-settings"),
keyValueStore: container.lookup("key-value-store:main"),
capabilities: container.lookup("capabilities:main"),
currentUser: container.lookup("current-user:main"),
diff --git a/app/assets/javascripts/discourse/app/lib/theme-settings-store.js b/app/assets/javascripts/discourse/app/lib/theme-settings-store.js
deleted file mode 100644
index 6503d6b..0000000
--- a/app/assets/javascripts/discourse/app/lib/theme-settings-store.js
+++ /dev/null
@@ -1,47 +0,0 @@
-import { get } from "@ember/object";
-const originalSettings = {};
-const settings = {};
-export function registerSettings(
- themeId,
- settingsObject,
- { force = false } = {}
- if (settings[themeId] && !force) {
- return;
- originalSettings[themeId] = Object.assign({}, settingsObject);
- const s = {};
- Object.keys(settingsObject).forEach((key) => {
- Object.defineProperty(s, key, {
- enumerable: true,
- get() {
- return settingsObject[key];
- set(newVal) {
- settingsObject[key] = newVal;
- settings[themeId] = s;
-export function getSetting(themeId, settingKey) {
- if (settings[themeId]) {
- return get(settings[themeId], settingKey);
- return null;
-export function getObjectForTheme(themeId) {
- return settings[themeId];
-export function resetSettings() {
- Object.keys(originalSettings).forEach((themeId) => {
- Object.keys(originalSettings[themeId]).forEach((key) => {
- settings[themeId][key] = originalSettings[themeId][key];
diff --git a/app/assets/javascripts/discourse/app/services/theme-settings.js b/app/assets/javascripts/discourse/app/services/theme-settings.js
new file mode 100644
index 0000000..3a1afbd
--- /dev/null
+++ b/app/assets/javascripts/discourse/app/services/theme-settings.js
@@ -0,0 +1,26 @@
+import Service from "@ember/service";
+import { get } from "@ember/object";
+export default Service.extend({
+ settings: null,
+ init() {
+ this._super(...arguments);
+ this._settings = {};
+ registerSettings(themeId, settingsObject) {
+ this._settings[themeId] = settingsObject;
+ getSetting(themeId, settingsKey) {
+ if (this._settings[themeId]) {
+ return get(this._settings[themeId], settingsKey);
+ return null;
+ getObjectForTheme(themeId) {
+ return this._settings[themeId];
diff --git a/app/assets/javascripts/discourse/tests/setup-tests.js b/app/assets/javascripts/discourse/tests/setup-tests.js
index df1c06c..066d4ff 100644
--- a/app/assets/javascripts/discourse/tests/setup-tests.js
+++ b/app/assets/javascripts/discourse/tests/setup-tests.js
@@ -17,7 +17,6 @@ import { setupS3CDN, setupURL } from "discourse-common/lib/get-url";
import Application from "../app";
import MessageBus from "message-bus-client";
import PreloadStore from "discourse/lib/preload-store";
-import { resetSettings as resetThemeSettings } from "discourse/lib/theme-settings-store";
import QUnit from "qunit";
import { ScrollingDOMMethods } from "discourse/mixins/scrolling";
import Session from "discourse/models/session";
@@ -155,7 +154,6 @@ function setupTestsCommon(application, container, config) {
QUnit.testStart(function (ctx) {
bootbox.$body = $("#ember-testing");
let settings = resetSettings();
- resetThemeSettings();
if (config) {
// Ember CLI testing environment
@@ -253,8 +251,6 @@ function setupTestsCommon(application, container, config) {
let pluginPath = getUrlParameter("qunit_single_plugin")
? "/" + getUrlParameter("qunit_single_plugin") + "/"
: "/plugins/";
- let themeOnly = getUrlParameter("theme_name") || getUrlParameter("theme_url");
if (getUrlParameter("qunit_disable_auto_start") === "1") {
QUnit.config.autostart = false;
@@ -263,20 +259,8 @@ function setupTestsCommon(application, container, config) {
let isTest = /\-test/.test(entry);
let regex = new RegExp(pluginPath);
let isPlugin = regex.test(entry);
- let isTheme = /^discourse\/theme\-\d+\/.+/.test(entry);
- if (!isTest) {
- return;
- if (themeOnly) {
- if (isTheme) {
- require(entry, null, null, true);
- return;
- if (!skipCore || isPlugin) {
+ if (isTest && (!skipCore || isPlugin)) {
diff --git a/app/assets/javascripts/discourse/tests/test_helper.js b/app/assets/javascripts/discourse/tests/test_helper.js
index affd1b3..595e95e 100644
--- a/app/assets/javascripts/discourse/tests/test_helper.js
+++ b/app/assets/javascripts/discourse/tests/test_helper.js
@@ -41,3 +41,13 @@
//= require setup-tests
//= require test-shims
//= require jquery.magnific-popup.min.js
+document.write(
+ '<div id="ember-testing-container"><div id="ember-testing"></div></div>'
+document.write(
+ "<style>#ember-testing-container { position: fixed; background: white; bottom: 0; right: 0; width: 640px; height: 384px; overflow: auto; z-index: 9999; border: 1px solid #ccc; transform: translateZ(0)} #ember-testing { zoom: 50%; }</style>"
+let setupTestsLegacy = require("discourse/tests/setup-tests").setupTestsLegacy;
+setupTestsLegacy(window.Discourse);
diff --git a/app/assets/javascripts/discourse/tests/test_starter.js b/app/assets/javascripts/discourse/tests/test_starter.js
index 77b69af..0000000
--- a/app/assets/javascripts/discourse/tests/test_starter.js
+++ /dev/null
@@ -1,11 +0,0 @@
-// discourse-skip-module
-document.write(
- '<div id="ember-testing-container"><div id="ember-testing"></div></div>'
-document.write(
- "<style>#ember-testing-container { position: fixed; background: white; bottom: 0; right: 0; width: 640px; height: 384px; overflow: auto; z-index: 9999; border: 1px solid #ccc; transform: translateZ(0)} #ember-testing { zoom: 50%; }</style>"
-let setupTestsLegacy = require("discourse/tests/setup-tests").setupTestsLegacy;
-setupTestsLegacy(window.Discourse);
diff --git a/app/controllers/qunit_controller.rb b/app/controllers/qunit_controller.rb
index 5e71847..f042d0a 100644
--- a/app/controllers/qunit_controller.rb
+++ b/app/controllers/qunit_controller.rb
@@ -1,26 +1,11 @@
# frozen_string_literal: true
class QunitController < ApplicationController
- skip_before_action *%i{
- check_xhr
- preload_json
GitHub sha: 2b9ab3a0
