Revert "FIX: Better emoji escaping for topic title"
approved
#1
Revert “FIX: Better emoji escaping for topic title”
This reverts commit 35426b5ad6b00c9047b9b7ba17d42d4f30bdb488.
diff --git a/app/assets/javascripts/pretty-text-bundle.js b/app/assets/javascripts/pretty-text-bundle.js
index ed5331b..41324ba 100644
--- a/app/assets/javascripts/pretty-text-bundle.js
+++ b/app/assets/javascripts/pretty-text-bundle.js
@@ -2,7 +2,6 @@
 //= require ./pretty-text/guid
 //= require ./pretty-text/censored-words
 //= require ./pretty-text/emoji/data
-//= require ./pretty-text/emoji/version
 //= require ./pretty-text/engines/discourse-markdown-it
 //= require xss.min
diff --git a/app/assets/javascripts/pretty-text/emoji.js.es6 b/app/assets/javascripts/pretty-text/emoji.js.es6
deleted file mode 100644
index d2c8503..0000000
--- a/app/assets/javascripts/pretty-text/emoji.js.es6
+++ /dev/null
@@ -1,175 +0,0 @@
-import {
-  emojis,
-  aliases,
-  searchAliases,
-  translations,
-  tonableEmojis,
-  replacements
-} from "pretty-text/emoji/data";
-import { IMAGE_VERSION } from "pretty-text/emoji/version";
-const extendedEmoji = {};
-export function registerEmoji(code, url) {
-  code = code.toLowerCase();
-  extendedEmoji[code] = url;
-export function extendedEmojiList() {
-  return extendedEmoji;
-const emojiHash = {};
-// add all default emojis
-emojis.forEach(code => (emojiHash[code] = true));
-// and their aliases
-const aliasHash = {};
-Object.keys(aliases).forEach(name => {
-  aliases[name].forEach(alias => (aliasHash[alias] = name));
-export function performEmojiUnescape(string, opts) {
-  if (!string) {
-    return;
-  return string.replace(/[\u1000-\uFFFF]+|\B:[^\s:]+(?::t\d)?:?\B/g, m => {
-    const isEmoticon = !!translations[m];
-    const isUnicodeEmoticon = !!replacements[m];
-    const emojiVal = isEmoticon
-      ? translations[m]
-      : isUnicodeEmoticon
-      ? replacements[m]
-      : m.slice(1, m.length - 1);
-    const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
-    const url = buildEmojiUrl(emojiVal, opts);
-    const classes = isCustomEmoji(emojiVal, opts)
-      ? "emoji emoji-custom"
-      : "emoji";
-    return url && (isEmoticon || hasEndingColon || isUnicodeEmoticon)
-      ? `<img src='${url}' ${
-          opts.skipTitle ? "" : `title='${emojiVal}'`
-        } alt='${emojiVal}' class='${classes}'>`
-      : m;
-  return string;
-export function performEmojiEscape(string) {
-  if (!string) {
-    return;
-    if (!!translations[m]) {
-      return ":" + translations[m] + ":";
-    } else if (!!replacements[m]) {
-      return ":" + replacements[m] + ":";
-    } else {
-      return m;
-  return string;
-export function isCustomEmoji(code, opts) {
-  if (extendedEmoji.hasOwnProperty(code)) return true;
-  if (opts && opts.customEmoji && opts.customEmoji.hasOwnProperty(code))
-    return true;
-  return false;
-export function buildEmojiUrl(code, opts) {
-  let url;
-  code = String(code).toLowerCase();
-  if (extendedEmoji.hasOwnProperty(code)) {
-    url = extendedEmoji[code];
-  if (opts && opts.customEmoji && opts.customEmoji[code]) {
-    url = opts.customEmoji[code];
-  const noToneMatch = code.match(/([^:]+):?/);
-  if (
-    noToneMatch &&
-    !url &&
-    (emojiHash.hasOwnProperty(noToneMatch[1]) ||
-      aliasHash.hasOwnProperty(noToneMatch[1]))
-    url = opts.getURL(
-      `/images/emoji/${opts.emojiSet}/${code.replace(/:t/, "/")}.png`
-  if (url) {
-    url = url + "?v=" + IMAGE_VERSION;
-  return url;
-export function emojiExists(code) {
-  return !!(
-    extendedEmoji.hasOwnProperty(code) ||
-    emojiHash.hasOwnProperty(code) ||
-    aliasHash.hasOwnProperty(code)
-let toSearch;
-export function emojiSearch(term, options) {
-  const maxResults = (options && options["maxResults"]) || -1;
-  if (maxResults === 0) {
-    return [];
-  toSearch =
-    toSearch ||
-    _.union(_.keys(emojiHash), _.keys(extendedEmoji), _.keys(aliasHash)).sort();
-  const results = [];
-  function addResult(t) {
-    const val = aliasHash[t] || t;
-    if (results.indexOf(val) === -1) {
-      results.push(val);
-  // if term matches from beginning
-  for (let i = 0; i < toSearch.length; i++) {
-    const item = toSearch[i];
-    if (item.indexOf(term) === 0) addResult(item);
-  if (searchAliases[term]) {
-    results.push.apply(results, searchAliases[term]);
-    if (item.indexOf(term) > 0) addResult(item);
-  if (maxResults === -1) {
-    return results;
-  } else {
-    return results.slice(0, maxResults);
-export function isSkinTonableEmoji(term) {
-  const match = _.compact(term.split(":"))[0];
-  if (match) {
-    return tonableEmojis.indexOf(match) !== -1;
-  return false;
diff --git a/app/assets/javascripts/pretty-text/emoji.js.es6.erb b/app/assets/javascripts/pretty-text/emoji.js.es6.erb
new file mode 100644
index 0000000..09ab4ce
--- /dev/null
+++ b/app/assets/javascripts/pretty-text/emoji.js.es6.erb
@@ -0,0 +1,127 @@
+import { emojis, aliases, searchAliases, translations, tonableEmojis } from 'pretty-text/emoji/data';
+// bump up this number to expire all emojis
+export const IMAGE_VERSION = "<%= Emoji::EMOJI_VERSION %>";
+const extendedEmoji = {};
+export function registerEmoji(code, url) {
+  code = code.toLowerCase();
+  extendedEmoji[code] = url;
+export function extendedEmojiList() {
+  return extendedEmoji;
+const emojiHash = {};
+// add all default emojis
+emojis.forEach(code => emojiHash[code] = true);
+// and their aliases
+const aliasHash = {};
+Object.keys(aliases).forEach(name => {
+  aliases[name].forEach(alias => aliasHash[alias] = name);
+export function performEmojiUnescape(string, opts) {
+  if (!string) { return; }
+  // this can be further improved by supporting matches of emoticons that don't begin with a colon
+  if (string.indexOf(":") >= 0) {
+    return string.replace(/\B:[^\s:]+(?::t\d)?:?\B/g, m => {
+      const isEmoticon = !!translations[m];
+      const emojiVal = isEmoticon ? translations[m] : m.slice(1, m.length - 1);
+      const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
+      const url = buildEmojiUrl(emojiVal, opts);
+      const classes = isCustomEmoji(emojiVal, opts) ? "emoji emoji-custom" : "emoji";
+      return url && (isEmoticon || hasEndingColon) ?
+             `<img src='${url}' ${opts.skipTitle ? '' : `title='${emojiVal}'`} alt='${emojiVal}' class='${classes}'>` : m;
+  return string;
+export function isCustomEmoji(code, opts) {
+  if (extendedEmoji.hasOwnProperty(code)) return true;
+  if (opts && opts.customEmoji && opts.customEmoji.hasOwnProperty(code)) return true;
+  return false;
+export function buildEmojiUrl(code, opts) {
+  let url;
+  code = String(code).toLowerCase();
+  if (extendedEmoji.hasOwnProperty(code)) {
+    url = extendedEmoji[code];
+  if (opts && opts.customEmoji && opts.customEmoji[code]) {
+    url = opts.customEmoji[code];
+  const noToneMatch = code.match(/([^:]+):?/);
+  if (noToneMatch && !url && (emojiHash.hasOwnProperty(noToneMatch[1]) || aliasHash.hasOwnProperty(noToneMatch[1]))) {
+    url = opts.getURL(`/images/emoji/${opts.emojiSet}/${code.replace(/:t/, '/')}.png`);
+  if (url) {
+    url = url + "?v=" + IMAGE_VERSION;
+  return url;
+export function emojiExists(code) {
+  return !!(extendedEmoji.hasOwnProperty(code) || emojiHash.hasOwnProperty(code) || aliasHash.hasOwnProperty(code));
+let toSearch;
+export function emojiSearch(term, options) {
+  const maxResults = (options && options["maxResults"]) || -1;
+  if (maxResults === 0) { return []; }
+  toSearch = toSearch || _.union(_.keys(emojiHash), _.keys(extendedEmoji), _.keys(aliasHash)).sort();
GitHub sha: d32557ea
#2
We suspect this commit from making our internal tests fail. Can‘t dig more for no, so reverted until we can sort it out.
Approved #3
#4
I am very sorry if I have caused something
#5
No worries, nothing you could have seen, I don’t even know why yet. The commit looks great, we will get to it.
#6
@venarius maybe start with a tiny PR here first for the file split, that is almost no risk, and if that destabilizes our test suite then we will know exactly what tiny change it was.
#7
@SamSaffron will do!
