Revert "FIX: Do not attempt to pull_hotlinked on emoji images when CDN enabled"
Revert “FIX: Do not attempt to pull_hotlinked on emoji images when CDN enabled”
This changed cause plugin spec failures and needs further investigation
This reverts commit 78626d2832d54c867e9d8c20e3e0c68fa5f2137e.
diff --git a/app/jobs/regular/pull_hotlinked_images.rb b/app/jobs/regular/pull_hotlinked_images.rb
index 415ce3b..9472da0 100644
--- a/app/jobs/regular/pull_hotlinked_images.rb
+++ b/app/jobs/regular/pull_hotlinked_images.rb
@@ -173,7 +173,7 @@ module Jobs
       # If file is on the forum or CDN domain or already has the
       # secure media url
-      if UrlHelper.is_local(src) || Upload.secure_media_url?(src)
+      if Discourse.store.has_been_uploaded?(src) || src =~ /\A\/[^\/]/i || Upload.secure_media_url?(src)
         return false if src =~ /\/images\/emoji\//
         # Someone could hotlink a file from a different site on the same CDN,
diff --git a/spec/jobs/pull_hotlinked_images_spec.rb b/spec/jobs/pull_hotlinked_images_spec.rb
index b589383..f0531b8 100644
--- a/spec/jobs/pull_hotlinked_images_spec.rb
+++ b/spec/jobs/pull_hotlinked_images_spec.rb
@@ -360,23 +360,6 @@ describe Jobs::PullHotlinkedImages do
-    it "returns false for emoji" do
-      src = Emoji.url_for("testemoji.png")
-      expect(subject.should_download_image?(src)).to eq(false)
-    end
-    it "returns false for emoji when app and S3 CDNs configured" do
-      set_cdn_url "https://mydomain.cdn/test"
-      SiteSetting.s3_upload_bucket = "some-bucket-on-s3"
-      SiteSetting.s3_access_key_id = "s3-access-key-id"
-      SiteSetting.s3_secret_access_key = "s3-secret-access-key"
-      SiteSetting.s3_cdn_url = "https://s3.cdn.com"
-      SiteSetting.enable_s3_uploads = true
-      src = UrlHelper.cook_url(Emoji.url_for("testemoji.png"))
-    end
     context "when download_remote_images_to_local? is false" do
       before do
         SiteSetting.download_remote_images_to_local = false
@@ -387,6 +370,11 @@ describe Jobs::PullHotlinkedImages do
         expect(subject.should_download_image?(src)).to eq(true)
+      it "returns false for emoji" do
+        src = Emoji.url_for("testemoji.png")
+        expect(subject.should_download_image?(src)).to eq(false)
+      end
       it 'returns false for valid remote URLs' do
         expect(subject.should_download_image?("http://meta.discourse.org")).to eq(false)
GitHub sha: a99bb0de
